As stated…
The Wiki can be used to extend the information given in the official documentation, with step by step guides, tips and tricks, general recommendations and best practices/strategies, things that are out of the scope of the official docs, etc. For NS8, NethSecurity…
How can you help?
Review old entries
- Check if the information of wiki pages is current, if it only applies to NS7 (or even previous versions) and if there’s any relevant NS8 information that can be included.
- As NS7 is defunct (kind of), consider adding a deprecation note/warning where needed.
- To have in mind: the wiki stores an history of changes, so old information still can be retrieved. That’s interesting, for instance, to (maybe in 6 months or in a year, to say something…) have the main wiki pages updated with just NS8 info but keep NS7 history (some NS7 servers might be around for longer than we expect).
Community Apps
- Keep an updated index of NS8 apps (and repos) maintained by community members. As we did with NS7.
- One wiki page per each NS8 community app (for starters, it can be the same info as in the readme file of the app, but can be extended over time with other useful information). You can check examples from NS7 wiki pages.
Unified Knowledge Base
On the community forum there is many NS8 information scattered around that could be ported to the wiki.
Here’s a small and incomplete list of topics -with no specific order- that are susceptible to be included in the wiki (extend it as you wish):
- Recycle Bin Samba NS8 - #4 by mrmarkuz
- Trying to connect TrueNAS-Scale to NS8-AD, Letsencrypt fails to obtain certificate - #4 by mrmarkuz
- NS8 - Third-Party Repositories? - #2 by dnutan
- Problem Migrate FileServer APP to NS8 - #6 by Andy_Wismer
- A Debian 12 based new Install of NS8, running on a low powered Proxmox 8.22 (Odroid H3+)
- ACL´s in local AD - #2 by dnutan
- Create a ns8 repository for developers
- Create a ns8 repository for developers - #18 by stephdl
- App Consumed Storage Space - #2 by davidep
- Restore a single file - #4 by Viking
- [WIP] NS7 vs NS8 Feature Comparison
- NS7 -> NS8 migration: LE certificates are not obtained - #5 by davidep
- NS7 -> NS8 migration: Loki keeps restarting - #7 by davidep
- Custom Certificate Management - #3 by davidep
- Custom Certificate Management - #6 by PerpetuumMobile
- AD - Roaming Profiles in NS8
- How do I prevent the administration page from being accessible from the Internet? - #2 by davidep
- No admin in NS8 Nextcloud - #5 by mrmarkuz (check if fixed by devs or is the same)
- Path to the certs? - #4 by mrmarkuz
- NS8 +SAMBA on VPS - Add virtual interface - #2 by mrmarkuz
- Ns8-mariadb: access to database for webapp/cli when you are remote
- Ns8 samba file permissions problems - #2 by Andy_Wismer
- NS8 - Starting/Stopping Apps (to review if there’s any inaccuracy)
- Size and rotation logs - #2 by davidep
- HowTo: NS8 / Debian / Proxmox users enlarging your NS8 swap
- What's the official method for expanding sda5 in the ns8-rocky image? - #3 by davidep
- NS 7.9 Migration problem & error - #2 by mrmarkuz
- NethServer 8 Group editing - #2 by davidep
- NS8 Add storage path setting like in minio to other apps - #10 by davidep
- Samba5 AD, DNS Nethserver8 - #2 by davidep
- NS8 system log empty [SOLVED]
- Canonical.db in NS8 - #2 by davidep
- NSecurity 8 - GEOIP Blocking - #2 by filippo_carletti
- Active directory: Couldn't join realm: Insufficient permissions to join the domain
- Automating ad cert migration on trigger - #2 by mrmarkuz
- NethSecurity 8 - Threat Shield Community Lists
- Connect NS8 crowdsec to opnsense - #2 by filippo_carletti
- Dovecot Certificate Expired - #3 by mrmarkuz
- NS8 /etc/aliases - #7 by davidep
- Samba5 AD, DNS Nethserver8 - #8 by davidep
- SOGo new features: configuration template and access/configure button - #12 by stephdl
- Mail server replication with dovecot
- NS8: How to Block Top-Level Domains (TLD) and Email Addresses
- LemonLDAP-NG in Podman - #2 by Shane_Treweek
- Backup failing, again - #2 by davidep
- Backup failing, again - #9 by davidep
- Migrating Dokuwiki to NS8? - #2 by mrmarkuz
- Migrating Dokuwiki to NS8? - #4 by dnutan
- Change recipient_delimiter in postfix
- NS8 update problem with old Samba instances - #7 by davidep
- https://community.nethserver.org/t/can-t-find-a-way-to-use-the-rspamd-learn-ham-feature-in-ns8/25028/2?u=dnutan
- https://community.nethserver.org/t/how-to-use-a-nethserver-leader-node-as-a-gateway-to-access-applications-on-private-worker-nodes/25030/2?u=dnutan
- https://community.nethserver.org/t/can-t-find-a-way-to-use-the-rspamd-learn-ham-feature-in-ns8/25028/5?u=dnutan
- https://community.nethserver.org/t/nethserver-8-i-am-not-able-to-log-into-nextcloud-with-any-email-address-but-i-can-log-in-with-same-email-addresses-into-webtop/24956/2?u=dnutan
- https://community.nethserver.org/t/nextcloud-fine-tune/25046/2?u=dnutan
- https://community.nethserver.org/t/email-notification-after-failed-backup/25077/2?u=dnutan
- https://community.nethserver.org/t/rspamd-module-loading-error-timeout-module-fontawesome/25091/2?u=dnutan
- https://community.nethserver.org/t/is-it-possible-to-reduce-the-used-space-by-loki/25103/4?u=dnutan
- https://community.nethserver.org/t/password-policy-configuration-and-file-server-auditing-in-nethserver-8/25176/3?u=dnutan
- https://community.nethserver.org/t/how-to-use-a-nethserver-leader-node-as-a-gateway-to-access-applications-on-private-worker-nodes/25030/4?u=dnutan
- https://community.nethserver.org/t/mail-domain-lookup-fail-after-migration-from-nethserver-7-to-8/25207/2?u=dnutan
- https://community.nethserver.org/t/rsync-to-virtual-host/25226/3?u=dnutan
- https://community.nethserver.org/t/ssh-into-a-podman-container-as-for-password/25240/2?u=dnutan
- https://community.nethserver.org/t/canonical-db-in-ns8/24602/4?u=dnutan
- https://community.nethserver.org/t/how-to-edit-trusted-domains-in-nextcloud-on-ns8/25296/2?u=dnutan
- https://community.nethserver.org/t/how-to-build-your-ui-online-while-you-are-coding/25345?u=dnutan (for Developers)
- [add more]
- If possible, test it to verify the information is correct and add it to the wiki with any missing steps.
- For any customization, add a deprecation note whenever the feature is officially implemented on NS8, and required steps to undo the changes, if any.
Ideas
- In my opinion, information related to migration procedures, tips and troubleshooting could be prioritized over other topics. Currently migration appears to be the main source of frustrations; while documenting things it is possible you find bugs or think of improvements that can be reported to devs; (…)
- Don’t underestimate some small commands given by devs or other members (log location info, config files location info inside apps, different ways to check logs, etc.) that are scattered around the forums. Remember the useful command wiki sections…
- If you are testing NS8, migration et all, consider sharing some of your notes on the wiki. Doesn’t matter if they aren’t completely pristine as long as they are accurate. If there’s something missing, like proper formatting and screenshots, not complete step by step for dummies et al and you cannot do it alone, publish in on the wiki (adding some warning note to readers) and ask for some help here in the forums. Although not granted, it’s quite possible someone chimes in as time allows.
