NethServer Version: NS8
Module: Samba
Anyone knows how do I set Roaming Profiles in v8?
Module: Samba
Hi and welcome to Nethserver Community,
I didn’t test it on NS8 but it should be possible.
You could edit /etc/samba/include.conf to add custom configuration, see also AD LDAP binding error (strong authentification required) - #2 by davidep
It’s also possible to use net conf setparm for configuration, check out Recycle Bin Samba NS8 - #4 by mrmarkuz
Instructions for configuring Roaming Profiles are in the Samba Wiki.
IIRC there’s also a thread about configuring Roaming Profiles in NS7 but I can’t find it.
Thank you so much. I appreciate your help!
Are there plans to add missing features from NS7 to NS8?
Check out the Roadmap on GitHub.
Which features are missing?
You could open a Feature request (if it doesn’t exist) and explain the feature you are missing.
I am following theses steps, but I am still not able to activate roaming profiles:
runagent -m samba1 podman exec -ti samba-dc mkdir /srv/profiles
runagent -m samba1 podman exec -ti samba-dc nano /etc/samba/include.conf
then I have added the following:
[profiles]
comment = Users profiles
path = /srv/profiles
browseable = No
read only = No
csc policy = disable
vfs objects = acl_xattr
But the /srv/profiles is disappearing when I restart samba1 with:
runagent -m samba1 systemctl --user restart samba-dc
What I am doing wrong?
Anyone knows the reason /srv/profiles is disappearing after restart samba? I have created the /srv/profiles directory several times with mkdir /srv/profiles, but it still being deleted.
Sorry for the late answer.
Only defined volumes are saved, other data gets lost after a container restart.
root@ns8node1:~# ls /home/samba1/.local/share/containers/storage/volumes
config data homes shares
So you could setup the profiles share in /srv/shares/profiles to make it persistent.
