NS8: How to Block Top-Level Domains (TLD) and Email Addresses
  1. Access the leader node through SSH.
  2. Launch a shell in the rspamd container.
    sudo runagent -m mail1 podman exec -ti rspamd sh
  3. Create the directory “dynamic” in /var/lib/rspamd, if it does not exist.
    mkdir /var/lib/rspamd/dynamic
  4. Create the file multimap.conf in /var/lib/rspamd/dynamic.
    vi /var/lib/rspamd/dynamic/multimap.conf
  5. Insert the following content into the file multimap.conf. Save & Exit.
    BLOCK_SENDER_FROM_TLD {
        type = "from";
        filter = 'email:domain:tld';
        symbol = "BLOCK_SENDER_FROM_TLD";
        prefilter = true;
        map = ["${DBDIR}/local_bl_from_tld.map.inc"];
        regexp = true;
        description = "TLD from Blacklist";
        action = "reject";
        message = "Sender Domain REJECTED";
    BLOCK_SENDER_FROM {
        type = "header";
        header = "from";
        filter = 'email';
        symbol = "BLOCK_SENDER_FROM";
        map = ["${DBDIR}/local_bl_from.map.inc"];
        description = "Email Address from Blacklist";
        action = "reject";
        message = "Sender Email Address REJECTED";
  6. Set the owner on the directory /var/lib/rspamd/dynamic to ‘rspamd’.
    chown -R rspamd: /var/lib/rspamd/dynamic
  7. Set the permissions on the directory /var/lib/rspamd/dynamic.
    chmod -c 750 /var/lib/rspamd/dynamic
  8. Create the file local_bl_from_tld.map.inc /var/lib/rspamd.
    vi local_bl_from_tld.map.inc
  9. Add the top-level domain(s) to blacklist in the file. Save & Exit.
    [.]best
  10. Create the file local_bl_from.map.inc in /var/lib/rspamd.
    vi local_bl_from.map.inc
  11. Add the email address(es) to blacklist in the file. Save & Exit.
    info@publiclibrary.best
  12. Set the owner on the files to ‘rspamd’.
    chown rspamd: /var/lib/rspamd/local_bl_from_tld.map.inc
    chown rspamd: /var/lib/rspamd/local_bl_from.map.inc
  13. Set the permissions on the files.
    chmod -c 644 /var/lib/rspamd/local_bl_from_tld.map.inc
    chmod -c 644 /var/lib/rspamd/local_bl_from.map.inc
  14. Check the config of rspamd.
    rspamadm configtest
     If no errors, the result will be: syntax OK
  15. Reload the rspamd config.
    reload-config
  16. Exit the container shell.
    exit
  17. Exit the SSH session.
    exit
Hi Dominic,
Many thanks for your howto.
This addition is maybe handy
Herewith you can block spam by subject
Hopely all these setting willbe made standard in NS8 in the future and some options available in the ui
Hi All,
I’ve added some extra filters
Maybe overkill, but better this then too less filters;-)
# Whitelists
local_wl_domain {
        type = "from";
        filter = "email:domain";
        map = "${DBDIR}/local_wl_domain.inc";
        symbol = "LOCAL_WL_DOMAIN";
        regex = true;
        prefilter = true;
        score = -6.0;
        description = "Whitelist map on DOMAIN";
local_wl_from {
        type = "from";
        filter = "email:domain:tld";
        map = "${DBDIR}/local_wl_from.inc";
        symbol = "LOCAL_WL_FROM";
        regex = true;
        prefilter = true;
        score = -6.0;
        description = "Whitelist map on FROM";
local_wl_ip {
        type = "ip";
        map = "${DBDIR}/local_wl_ip.inc";
        symbol = "LOCAL_WL_IP";
        regex = true;
        prefilter = true;
        score = -6.0;
        description = "Whitelist map on IP";
local_wl_rcpt {
        type = "rcpt";
        map = "${DBDIR}/local_wl_rcpt.inc";
        symbol = "LOCAL_WL_RCPT";
        regex = true;
        prefilter = true;
        score = -6.0;
        description = "Whitelist map on RCPT";
# Blacklists
local_bl_domain {
        type = "from";
        map = "${DBDIR}/local_bl_domain.inc";
        prefilter = true;
        action = "reject";
        score = 10.0;
        description = "Blacklisted on DOMAIN";
local_bl_from {
        type = "from";
        map = "${DBDIR}/local_bl_from.inc";
        symbol = "LOCAL_BL_FROM";
        prefilter = true;
        action = "reject";
        score = 10.0;
        description = "Blacklist map on FROM";
local_bl_ip {
        type = "ip";
        map = "${DBDIR}/local_bl_ip.inc";
        symbol = "LOCAL_BL_IP";
        prefilter = true;
        action = "reject";
        score = 10.0;
        description = "Blacklist map on IP";
local_bl_rcpt {
        type = "rcpt";
        map = "${DBDIR}//local_bl_rcpt.inc";
        symbol = "LOCAL_BL_RCPT";
        prefilter = true;
        action = "reject";
        score = 10.0;
        description = "Blacklist map on RCPT";
BAD_SUBJECT {
  type = "header";
  header = "subject";
  map = ["${DBDIR}/local_bl_subject_regex.inc"];
  regexp = true;
  description = "Blacklist map on SUBJECT";
  score = 10.0;
Source:
gist.github.com/kvaps/25507a87dc287e6a6https://gist.github.com/kvaps/25507a87dc287e6a620e1eec2d60ebc1
