Just for info: The “vacumeing” took about 12 h… The database is still the same size, but at least now, it IS cleaned up. Verified that with PHP-PGadmin…
It’s now doing a dump of that 30+ GB Database.
Next steps would be delete the DB and recreate with same user and perms, and restoring the dump.
As the dump is so big, I can’t use phppgadmin for that, it times out way too soon!
I’m doing the dump to a local folder, that should also speed up the restore using just CLI…
Backup dump finished:
Before cleanup, dump size = 16 GB (!)
After Cleanup, dump size 200 MB
We’re getting there!
(The database in PG still uses 16 GB as shown by NethServer Diskusage…)
Basically I stuffed the prepared SVG file into Nethservers html folder, and refer to that in the url. As Zabbix and NethServer are on the same server, this isn’t an issue, it would not even be if run of a different web-server…
A gimmick, but thought you might like it: The ÖBB clock or DB version can also be set, if you prefer a “Wiener” ambiente…
Getting closer to the next Zabbix LTS release. Zabbix 5.0.0beta1 version is out!
Then on the same email:
(Zabbix + Zammad): Zammad is a free open source, a fully-featured web-based ticketing system for helpdesk or customer support. This guide describes how to integrate your Zabbix 5.0 installation with Zammad and provide instructions on setting up a media type, a user, and an action in Zabbix.
This guide describes how to integrate your Zabbix 5.0 installation with Zammad using the Zabbix webhook feature. This guide will provide instructions on setting up a media type, a user and an action in Zabbix.
Combining Zabbix/Zammad is a nice feature.
I assume preconfiguring both should be possible at least by editing the databases.
Should it be done automatically when both apps are installed or is there a reason to keep them separated?
What about integrating LDAP/AD to both Zammad and Zabbix so a member of the “support” group can access zabbix and zammad? Actually both apps run “next” to Nethserver.
Great! As regards Nethserver I think mattermost and even telegram are interesting for preconfiguration.
It looks like Zammad need a lot of memory, so if it is included with a webhook like André wrote, maybe it will take less memory all together. I don’t know enough about that. But since it will be only with Zammad 5, we need to wait for the final release…
For LDAP/AD, I think that you already worked a lot on those, so if all is integrated together on a single NethServer it will be quite a feature for NS.
I am working on translation for Zammad as the fr_FR or fr_CA is quite awfull as it looks like it is directly from Google translation and a lot of it is missing. Zammad should take .po/.mo instead of .yml as WordPress - it will be much easier for translation. Also a child theme will be the greatest think to do…
Also, the “black” theme is very hard to read. Yesterday, I was looking at the theme replacement and I think it doesn’t have other than the default one and I think one have to play with the css which is quite bad as it will be overwritten by updates.
Michel-André
P.S. I should have place my Zammad comments on the Zammad thread.
Webhooking enables also using external / hosted services, or simply to connect to the app on the same server or installed in a VM right next to NethServer / Zabbix…
So a simple template integrated might be in order…
Mattermost & Zammad are clear candidates.
I’m not sure, but I think on a fresh 4.4 install, the templates are included.
I am afraid it’s not a simple template as in case of Zabbix I need to edit the database for changing the configuration.
I’d like to integrate all for maximum flexibiliy but I have to consider effort and simplicity (like 10 switches for enabling webhooks are not simple anymore) too. You are always able to do the configuration (3 steps) in the user interfaces.
I saw that many modern apps provide a lot of interfaces/webhooks, see matrix for example. Integrating them all is just not efficient IMO.
If we see that some addon is used/needed, I’m always open to integrate it.
I would like it in combination with Moodle/Bigbluebutton to get a private video conferencing and collaboration system.
Mattherhost has a Bigbluebutton integration
In the current time it would be important for me to become independent from Facetime, Zoom, Whatsapp,… and the other proprietary systems.
