mrmarkuz
(Markus Neuberger)
March 25, 2020, 12:21am
1
Please test Zabbix and my new repo…
Release notes
Zabbix
Tested with Zabbix 4.4
New zabbix DBs are created with unicode
a warning was shown in newer Zabbix versions
Add db migrate script
use zabbixUnicode.sh to migrate old db to unicode
Add Zabbix application to cockpit - thanks to @flatspin for providing this wiki article
Updated device images
Add HTTPS redirect as newer versions don’t allow http login anymore
mrmarkuz Repository:
I added some features that are already included in @dan or @stephdl repos. Thanks guys for providing information and source code.
Update mail
root and domain admins get an update mail if there are new packages
Backup
repo is included in backup now
Metadata signing
a second key is used for metadata signing
Keys provided as file instead of http link
Server change
I use another VPS for my repo now and keep the old one as backup. If these tests are successful I’ll provide the new repo on the old server and with the next update everybody should use the new server. I keep the old server for backup repo so there should be no problem even if someone rarely updates.
Install procedure
You need to Install the new mrmarkuz repo first to get nethserver-zabbix.
yum -y install https://mrmarkuz.dynu.net/mirror/mrmarkuz/7/noarch/nethserver-mrmarkuz-0.0.1-4.ns7.noarch.rpm
Zabbix repo
Install the new Zabbix repo:
yum -y install https://repo.zabbix.com/zabbix/4.4/rhel/7/x86_64/zabbix-release-4.4-1.el7.noarch.rpm
yum clean all
Fresh install
To install nethserver-zabbix run following command:
yum -y install nethserver-zabbix
Update
To update nethserver-zabbix and Zabbix run the following command:
yum --enablerepo=mrmarkuz,zabbix update nethserver-zabbix zabbix-*
Testing
Open Zabbix by using the new server manager.
Check if Zabbix works in your environment.
If possible check fresh install and update
If you have old database and get a warning in dashboard, use the zabbixUnicode.sh script
Morning Markus!
Will test a little later, as soon as the caffein level is adequate…
Good work!
PS: Here’s the latest Zabbix-Images file:
https://www.anwi.ch/downloads/Zabbix_ANWI-Library_2020-03-25.zip
@mrmarkuz
Coffee level up to testing…
Installed the update:
Determining fastest mirrors
epel/x86_64/metalink | 28 kB 00:00:00
ce-base: repo.uk.bigstepcloud.com
ce-extras: repo.uk.bigstepcloud.com
ce-sclo-rh: repo.uk.bigstepcloud.com
ce-sclo-sclo: repo.uk.bigstepcloud.com
ce-updates: repo.uk.bigstepcloud.com
epel: ftp.fau.de
nethforge: mrmarkuz.dynu.net
nethserver-base: mrmarkuz.dynu.net
nethserver-updates: mrmarkuz.dynu.net
ce-base/7/x86_64/signature | 811 B 00:00:00
ce-base/7/x86_64/signature | 3.6 kB 00:00:00 !!!
ce-extras/7/x86_64/signature | 811 B 00:00:00
ce-extras/7/x86_64/signature | 2.9 kB 00:00:00 !!!
ce-sclo-rh | 3.0 kB 00:00:00
ce-sclo-sclo | 2.9 kB 00:00:00
ce-updates/7/x86_64/signature | 811 B 00:00:00
ce-updates/7/x86_64/signature | 2.9 kB 00:00:00 !!!
epel | 4.7 kB 00:00:00
mrmarkuz/7/signature | 490 B 00:00:00
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-mrmarkuz
Importing GPG key 0xF144E5A3:
Userid : “Markus Neuberger dev@markusneuberger.at ”
Fingerprint: b0ef d107 b433 ccf0 db12 c453 6a35 e5a2 f144 e5a3
Package : nethserver-mrmarkuz-0.0.1-4.ns7.noarch (@/nethserver-mrmarkuz-0.0.1-4.ns7.noarch)
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-mrmarkuz-2
mrmarkuz/7/signature | 2.9 kB 00:00:00 !!!
nethforge/7/x86_64/signature | 836 B 00:00:00
nethforge/7/x86_64/signature | 3.6 kB 00:00:00 !!!
nethserver-base/7/x86_64/signature | 836 B 00:00:00
nethserver-base/7/x86_64/signature | 2.9 kB 00:00:00 !!!
nethserver-updates/7/x86_64/signature | 836 B 00:00:00
nethserver-updates/7/x86_64/signature | 3.6 kB 00:00:00 !!!
stephdl | 2.9 kB 00:00:00
zabbix | 2.9 kB 00:00:00
Not using downloaded zabbix/repomd.xml because it is older than what we have:
*** Current : Mon Mar 23 11:54:34 2020***
*** Downloaded: Mon Mar 23 10:42:22 2020***
zabbix-non-supported | 951 B 00:00:00
(1/16): ce-base/7/x86_64/group_gz | 165 kB 00:00:00
(2/16): ce-extras/7/x86_64/primary_db | 164 kB 00:00:00
(3/16): ce-sclo-sclo/7/x86_64/primary_db | 344 kB 00:00:00
(4/16): ce-base/7/x86_64/primary_db | 6.0 MB 00:00:00
(5/16): ce-updates/7/x86_64/primary_db | 7.6 MB 00:00:00
(6/16): epel/x86_64/group_gz | 95 kB 00:00:00
(7/16): epel/x86_64/updateinfo | 1.0 MB 00:00:00
(8/16): nethforge/7/x86_64/group_gz | 1.7 kB 00:00:00
(9/16): nethserver-base/7/x86_64/primary_db | 353 kB 00:00:00
(10/16): nethserver-updates/7/x86_64/group_gz | 22 kB 00:00:00
(11/16): nethforge/7/x86_64/primary_db | 112 kB 00:00:00
(12/16): mrmarkuz/7/primary_db | 27 kB 00:00:00
(13/16): nethserver-updates/7/x86_64/primary_db | 653 kB 00:00:00
(14/16): epel/x86_64/primary_db | 6.7 MB 00:00:00
(15/16): stephdl/7/primary_db | 219 kB 00:00:00
(16/16): ce-sclo-rh/7/x86_64/primary_db | 4.2 MB 00:00:03
Package nethserver-zabbix-0.0.1-7.ns7.noarch already installed and latest version
Nothing to do
Seems to work, but I get this, which is a bit irritating:
Will observe further, and test on other installations…
Will also (later) test with a completly fresh installation.
The fresh installed Testserver is installing…
@mrmarkuz
Already found a few “Gotchas”, one is from the new Cockpit and has nothing to do with Zabbix:
On a freshly installed NethServer, Zabbix works as expected, and also displays the correct version:
The updated ones (tested 4 so far) display the same version as before the update.
Another issue i found, but not specific with your update:
On long running and mostly problemless systems, the Zabbix Database can get quite large…
I have a treuhand company, one of the first I installed your Zabbix package two years ago, where the database has grown to 30+ GB (!).
As is well known, the included clean up packages do not work very well. Part of the problem is PostgreSQL itself, it seems that after deleting the data in the tables, even when writing the database during shutdown, the used space is NOT recovered.
A backup / restore seems to be needed.
This could be included in a simple script, maybe with 1-2 options in the new cockpit GUI…
(Retend time frame / purge from date backwards / older…)
I haven’t been successful so far, need to optimize the database…
Any suggestions?
stephdl
(Stéphane de Labrusse)
March 25, 2020, 8:19am
8
A big thank you @mrmarkuz , I hope to share a beer with you soon
mrmarkuz
(Markus Neuberger)
March 25, 2020, 8:59am
9
Thanks for testing!
Just klick on Example.Org and edit.
I think zabbix repo is disabled and we need the following to update Zabbix too. (check /etc/yum.repos.d/zabbix.repo for enabled=0)
yum -y --enablerepo=mrmarkuz,zabbix install nethserver-zabbix
Thx!
The translation “Leistung” doesn’t quite fit with the english “Power”…
Some newbies might expect “overclocking” or other gags.
@mrmarkuz
Doesn’t work here, it’s needed 1-2 steps earlier already, methinks…
Any suggestions?
mrmarkuz
(Markus Neuberger)
March 25, 2020, 9:15am
12
Does update instead of install work?
yum -y --enablerepo=mrmarkuz,zabbix update nethserver-zabbix
Andy_Wismer:
Any suggestions?
mrmarkuz
(Markus Neuberger)
March 25, 2020, 9:20am
14
Also tried this:
yum -y --enablerepo=mrmarkuz,zabbix install https://repo.zabbix.com/zabbix/4.4/rhel/7/x86_64/zabbix-release-4.4-1.el7.noarch.rpm
zabbix-release-4.4-1.el7.noarch.rpm | 14 kB 00:00:00
Examining /var/tmp/yum-root-QAQAn4/zabbix-release-4.4-1.el7.noarch.rpm: zabbix-release-4.4-1.el7.noarch
/var/tmp/yum-root-QAQAn4/zabbix-release-4.4-1.el7.noarch.rpm: does not update installed package.
Error: Nothing to do
Even after a reboot, the old version is displayed in Zabbix:
Zabbix 4.0.19. © 2001–2020, Zabbix SIA
mrmarkuz
(Markus Neuberger)
March 25, 2020, 9:37am
16
We need a update command and define zabbix-* additionally. Please try
Not yet…
[root@awr7-nethserver ~]# yum --enablerepo=mrmarkuz,zabbix update nethserver-zabbix zabbix-*
another
yum clean all
then the same command works…
Seems to be an additional issue with the mirror…
Still testing…
mrmarkuz
(Markus Neuberger)
March 25, 2020, 9:42am
20
I think it’s a yum issue. The yum clean all just forces it to recognize new packages.
