Template for the verification process in redmine (QA)
If others testing team members are interested, i’m using this template for the verification process in redmine, i think it’s self-explanatory:
GENERAL WORKFLOW
    1. status of test box and list of packages/groups  currently installed
    2. replicate problem in detail
    3. install new package
    4. repeat testing above (2nd line)
    5. fixed/not fixed based on new testing, conclusion: VERIFIED or TRIAGED
    6. Misc Notes (Documentation Impact, other..)
VERIFICATION TEMPLATE
+System and  Package Version installed+
Package Installed: ...
Other Package installed: ...
+Test Original Problem+
+Install Updated Package+
<pre>
yum --enablerepo=nethserver-testing update ...
</pre>
+Test Results after update+
+Verified Or Reopen+
+Note+
AS AN EXAMPLE:
[description of test system (version, installation methods, upgrade history. etc).
Package Installed: [rpm -qa <package name>]
Other Package installed: [yum grouplist | sed  '1,/Installed/d;/Available/,$d']
[Reproduce bug if you can, showing steps taken]
[Update to new package, show steps taken]
<pre>
</pre>
[Repeat steps carried out under TESTING above.]
[Problem fixed, then VERIFIED - not fixed, then TRIAGE]
+Note+
[Documentation Impact]
[Other]
note: maybe to comply the point 2 of the workflow, it would be nice that when a new bug is opened it contains
  2. howto replicate problem in detail
IMVHO :sweat_smile:
EDIT: just updated by @alefattorini with last @dz00te updates
Yes! It might be so helpful! @vcc, @mabeleira, @medworthy, @fasttech
@vcc @nrauso @davidep @giacomo what do you think? Any advice? Could we extend it with some tips about QA? I really want Guidelines for a good QA process
I like it!
We can start from this good page:
http://wiki.contribs.org/SME_Server:Documentation:QA:Verification
yes, really good point. I like it it’s better and more detailed of what i’m using now.
a little update based on sme_qa and on the template i’m currently using:
GENERAL WORKFLOW
<pre>
</pre>
+Note+
AS AN EXAMPLE:
<pre>
</pre>
+Note+
[Other]
IMVHO :sweat_smile:
Good, like it. What do you think @vcc ?
Good,
It as all the information needed
I like it!
alefattorini
Alessio Fattorini
Community Manager
    July 10
To respond, reply to this email or visit http://community.nethserver.org/t/template-for-the-verification-process-in-redmine/1067/3 in your browser.
Previous Replies
alefattorini
Alessio Fattorini
Community Manager
    June 17
dz00te
Testing Team Member
    June 17
if others testing team members are interested, i’m using this template for the verification process in redmine, i think it’s self-explanatory:
> +System and Package Version installed+ ... Package Installed: xxxx Other Package installed: xxxx +Test Original Problem+ ... +Install Updated Package+ <pre> yum --enablerepo=nethserver-testing update ... </pre> +Test Results after update+ ... +Note+ ...
