Problem to get access to Webtop Cloud
Hi Friends,
after a brandnew Installation of the latest version of Nethserver with all updates i have the same problem lik one year before.
The WebTop admin has access to the Cloud of WebTop, but when i test it with a normal user access is not possible and runs in a error.
What can be the reason for this?
Regards…
Uwe
Solved by Federico Ballarini. Thank you!
Hi. I’m not getting this error in no one of my installations.
Could you check log into /var/log/webtop/webtop.log ?
Could you also post error in browser console?
Are you using some particular configuration like reverse proxy or similar?
Thank you.
Hi Federico,
here is the output of the log. I use no proxy.
2019-02-15 21:26:50 [ERROR] com.sonicle.webtop.vfs.Service - Error in ManageStoresTree
org.apache.commons.vfs2.FileSystemException: Could not find files in “file:///var/lib/nethserver/webtop/domains/NethServer/com.sonicle.webtop.vfs/mydocuments/myuser”.
at org.apache.commons.vfs2.provider.AbstractFileObject.findFiles(AbstractFileObject.java:946)
at org.apache.commons.vfs2.provider.AbstractFileObject.listFiles(AbstractFileObject.java:1560)
at org.apache.commons.vfs2.provider.AbstractFileObject.findFiles(AbstractFileObject.java:921)
at com.sonicle.webtop.vfs.VfsManager.listStoreFiles(VfsManager.java:618)
at com.sonicle.webtop.vfs.Service.processManageStoresTree(Service.java:423)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.sonicle.webtop.core.app.servlet.BaseRequest.invokeMethod(BaseRequest.java:109)
at com.sonicle.webtop.core.app.servlet.PrivateRequest.processRequest(PrivateRequest.java:85)
at com.sonicle.webtop.core.app.servlet.PrivateRequest.doGet(PrivateRequest.java:121)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:635)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:61)
at org.apache.shiro.web.servlet.AdviceFilter.executeChain(AdviceFilter.java:108)
at org.apache.shiro.web.servlet.AdviceFilter.doFilterInternal(AdviceFilter.java:137)
at org.apache.shiro.web.servlet.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:125)
at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:66)
at com.sonicle.webtop.core.app.shiro.filter.GZip.doFilterInternal(GZip.java:60)
at org.apache.shiro.web.servlet.AbstractShiroFilter.executeChain(AbstractShiroFilter.java:449)
at org.apache.shiro.web.servlet.AbstractShiroFilter$1.call(AbstractShiroFilter.java:365)
at org.apache.shiro.subject.support.SubjectCallable.doCall(SubjectCallable.java:90)
at org.apache.shiro.subject.support.SubjectCallable.call(SubjectCallable.java:83)
at org.apache.shiro.subject.support.DelegatingSubject.execute(DelegatingSubject.java:383)
at org.apache.shiro.web.servlet.AbstractShiroFilter.doFilterInternal(AbstractShiroFilter.java:362)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:493)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.valves.RemoteIpValve.invoke(RemoteIpValve.java:685)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:800)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:806)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1498)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.apache.commons.vfs2.FileSystemException: Invalid descendent file name “Y:”.
at org.apache.commons.vfs2.impl.DefaultFileSystemManager.resolveName(DefaultFileSystemManager.java:796)
at org.apache.commons.vfs2.provider.AbstractFileObject.getChildren(AbstractFileObject.java:1045)
at org.apache.commons.vfs2.provider.AbstractFileObject.traverse(AbstractFileObject.java:121)
at org.apache.commons.vfs2.provider.AbstractFileObject.findFiles(AbstractFileObject.java:943)
… 62 common frames omitted
2019-02-15 21:26:50 [ERROR] com.sonicle.webtop.vfs.Service - Error in ManageGridFiles
at com.sonicle.webtop.vfs.Service.processManageGridFiles(Service.java:852)
2019-02-15 21:27:31 [ERROR] com.sonicle.webtop.vfs.Service - Error in ManageGridFiles
2019-02-15 21:28:45 [ERROR] com.sonicle.webtop.vfs.Service - Error in ManageStoresTree
2019-02-15 21:28:46 [ERROR] com.sonicle.webtop.vfs.Service - Error in ManageGridFiles
I think the problem is this. Could you check that folder exists and permission are set to tomcat:tomcat (770) ?
i think the permissions ar ok.Anmerkung%202019-02-15%20220023
The same permissions are applied also to the files?
Yes. There are the same permissions.
It’s a strange problem.
  • Can you try login with a user without files and see if get the same error?
  • Can you check these properties in Webtop admin properties?
    – com.sonicle.webtop.core - home.path
    – com.sonicle.webtop.vfs - check if there is some properties
Webtop is up to date?
Yes, WebTop is up to date. Tomorrow i will check it with a new user.
Have a nice evening…
Hi @transocean,
probably I’ve found the error: if you have a file with character like “:” Webtop goes in error. I suggest you to rename this file and all should be works properly.
In fact:
Probably you have uploaded a file with “:” from SFTP and not from Webtop interface that block the upload. To find files that contains “:” you can use these commands:
find /var/lib/nethserver/webtop/domains/NethServer/com.sonicle.webtop.vfs/mydocuments/*/ -name '*:*'
and
find /var/lib/nethserver/webtop/domains/NethServer/images/ -name '*:*'
Then you can rename found files with mv command.
If are not “:” you have to search some others special characters.
@lucag @webtop_team Maybe we can add an error description when log contains
[ERROR] com.sonicle.webtop.vfs.Service - Error in ManageStoresTree org.apache.commons.vfs2.FileSystemException: Could not find files in “file:///var/lib/nethserver/webtop/domains/NethServer/com.sonicle.webtop.vfs/mydocuments/myuser”.
and
that suggest to user to contact SysAdmin because there is an error with file names and he have to check it.
Wait for feedback.
Regards.
Yes, this is a known bug on the Apache Java VFS libraries.
We have solved it in the interface by sanitizing the names when possible, but this is not always under control.
Here was the issue:
https://issues.sonicle.com/projects/WTCLOUD/issues/WTCLOUD-14
Gabriele
Good morning Federico,
there is no file named C:log.text.
Anmerkung%202019-02-16%20093711
The upload goes not via SFTP. I use only WebTop for Upload.
I have created a new user for testing the upload. Upload is also not possible.
Regards
Uwe
I confirm that the problem has been solved and the fix is included in the 5.5.2 release released a few days ago:
I recommend updating and try again :wink:
I have NS new installed from the latest image.
In the previous version 7.5 1804 I did not have the problem.
Good morning lucag,
the latest version of WebTop 5 is already on the server.
Regards
Uwe
@transocean you are checking in the wrong folder.
Use this command and substitute user with your username
find /var/lib/nethserver/webtop/domains/NethServer/com.sonicle.webtop.vfs/mydocuments/user/ -name '*:*'
Obviusly it will not appear a file named C:log.txt… I created this file manually to have some test.
But you receive the error when try uploading or when you try open webtop cloud?
In your case there is a file named “Y:”, in fact in log you can see
Give me feedback. Thank you.
Sorry for the late answer. Server has crashed. New Installation is running.
Yes, there was a file named “Y:”
Ok, if I solve your problem mark this answer as solution that can be helpful for other users.
Thank you.
