Problems with the cloud function of Webtop 5
NethServer Version: 7.4 1708 (Final
Module: WebTop 5
Hello friends,
I (normal user) can not connect to the cloud function of Webtop 5.
I click the cloud icon. And then this error message appears.
Error_Webtop 5_Cloud
The same error message I get when I connect via Webtop 5 with my Nextclud account.
I have followed these instructions.
https://wiki.nethserver.org/doku.php?id=userguide:webtop5_nextcloud_itegration
Thanks for your help.
Uwe
Hi, can you access the webtop log under /var/log/webtop/webtop.log ?
That may tell what’s wrong.
Hi @transocean,
excuse the question, perhaps trivial, have you checked out that the Nextcloud module is installed?
Check what is reported to you on the /var/log/webtop/webtop.log when the interface error occurs.
here are the Logs:
2018-03-20 21:45:10 [ERROR] com.sonicle.webtop.vfs.Service - Upload failure
org.apache.commons.vfs2.FileSystemException: Unknown message with code “Root not exist”.
at com.sonicle.webtop.vfs.sfs.StoreFileSystem.resolveRoot(StoreFileSystem.java:102)
at com.sonicle.webtop.vfs.sfs.StoreFileSystem.getRootFileObject(StoreFileSystem.java:82)
at com.sonicle.webtop.vfs.VfsManager.getTargetFileObject(VfsManager.java:1283)
at com.sonicle.webtop.vfs.VfsManager.addStoreFileFromStream(VfsManager.java:669)
at com.sonicle.webtop.vfs.VfsManager.addStoreFileFromStream(VfsManager.java:657)
at com.sonicle.webtop.vfs.Service$OnUploadStoreFile.onUpload(Service.java:160)
at com.sonicle.webtop.core.app.AbstractEnvironmentService.processUpload(AbstractEnvironmentService.java:170)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.sonicle.webtop.core.servlet.BaseRequest.invokeMethod(BaseRequest.java:109)
at com.sonicle.webtop.core.servlet.PrivateRequest.processRequest(PrivateRequest.java:83)
at com.sonicle.webtop.core.servlet.PrivateRequest.doPost(PrivateRequest.java:114)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:650)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:61)
at org.apache.shiro.web.servlet.AdviceFilter.executeChain(AdviceFilter.java:108)
at org.apache.shiro.web.servlet.AdviceFilter.doFilterInternal(AdviceFilter.java:137)
at org.apache.shiro.web.servlet.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:125)
at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:66)
at com.sonicle.webtop.core.shiro.filter.GZip.doFilterInternal(GZip.java:60)
at org.apache.shiro.web.servlet.AbstractShiroFilter.executeChain(AbstractShiroFilter.java:449)
at org.apache.shiro.web.servlet.AbstractShiroFilter$1.call(AbstractShiroFilter.java:365)
at org.apache.shiro.subject.support.SubjectCallable.doCall(SubjectCallable.java:90)
at org.apache.shiro.subject.support.SubjectCallable.call(SubjectCallable.java:83)
at org.apache.shiro.subject.support.DelegatingSubject.execute(DelegatingSubject.java:383)
at org.apache.shiro.web.servlet.AbstractShiroFilter.doFilterInternal(AbstractShiroFilter.java:362)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:218)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:110)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:506)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:962)
at org.apache.catalina.valves.RemoteIpValve.invoke(RemoteIpValve.java:683)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:445)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1087)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:637)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1152)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:622)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
2018-03-20 21:53:12 [WARN ] com.sonicle.webtop.vfs.VfsManager - Error creating store file from stream
2018-03-20 21:53:12 [ERROR] com.sonicle.webtop.vfs.Service - Upload failure
Cloudfunction in WebTop5 is ok now. But connecting to my Nextcloud via WebTop5 is impossible like before.
Regards
Uwe
