NS8B1 first test
Hello the team,
Thanks for your work!
Download image.vmdk
D:\ns8-rocky-linux-9-1.0.0.vmdk
cd “C:\Program Files\Oracle\VirtualBox”
VBoxManage clonehd --format VDI “D:\ns8-rocky-linux-9-1.0.0.vmdk” “D:\ns8-rocky-linux-9-1.0.0.vdi”
→ D:\ns8-rocky-linux-9-1.0.0.vdi
VBoxManage.exe internalcommands sethduuid "D:\ns8-rocky-linux-9-1.0.0.vdi
VBoxManage clonevdi “D:\ns8-rocky-linux-9-1.0.0.vdi” “D:\ns8-rocky-linux-9-1.0.0-test1.vdi”
Other for example
VBoxManage clonevdi “D:\ns8-rocky-linux-9-1.0.0.vdi” “D:\ns8-rocky-linux-9-1.0.0-test2.vdi”
In VirtualBox :
Push New button
Enter a name
Select Machine Folder
Select “Linux”
Select "Red Hat (64-bit)
Push Next button
Select “RAM memory”
Push Next button
Select “Use an existing virtual hard disk file”
→ Choose a virtual hard disk file
Push Create button
Push Setting button
Select Network → Adapter 1 → Bridged Adapter
Select Network → Adapter 2 → Nat Network
Push OK and Start the VM
The VM has been started and there is an answer to ping
https://XXX.XXX.XXX.XXX/cluster-admin/
→ ERR_CONNECTION_REFUSED
Thanks for testing and your feedback. You could try these vmdks, they worked in VMware:
You could try to setup the vbox vm with just one bridged virtual network device in promiscuous mode.
EDIT2:
Maybe the conversion to vdi works better from qcow image?
Next step that I have done, connect in Console with root, change password and if I do: “systemctl enable --now cockpit/socket”, Cockpit works but always no https://xxx.xxx.xxx.xxx/cluster-admin/
In another test, I do not know when exactly, I had the https://xxx.xxx.xxx.xxx/cluster-admin/ but impossible to connect with admin account.
There were similar issues with the Debian image in VMWare, please try a vmdk from here.
I tested converting the qcow image to vdi and it worked. I used a bridged virtual network adapter and could reach the cluster-admin page. If needed you can download the working vdi.
