there is no official EPEL repository for armfhp. But because lot of users were asking for this, we decided to use the centos armhfp builders to (re)build Source packages from EPEL 7 (and try to track those automatically) when they’re idle. Please note that it’s just an automatic rebuild without any QA/test, and also resulting pkgs aren’t signed either.
at the moment only the epel packages we need are in our ns7arm repo, instead of using directly the repo. This is how @mark_nl setup the repo and i have maintained this config. This give us a better control of what we have in repo (and for me to better understand what we really use/need). If you find some useful package let me know and i will add to the ns7arm repo
same tructure also for ns7arm on aarch64, please remember that while i’ve left in the repo the aarch64 files, probably thy aren’t updated as for armhfp.
sorry, i didn’t have hardware to test aarch64, i will order something compatible this week so i can test it
I think the webfilter is responsible for that behavior .
But the pi is running now. During the meantime there is a new release of ufdbguard available. It is working well on my pi. Maybe I can tune the webfilter config a little bit I’ll try it in the next days
I was just browsing the Armbian web site ( www.armbian.com ) and stumbled upon ClearFog Pro SoC board and thought that this would make an interesting development board to use Nethserver with.
today I installed fail2ban to my kidsrouter.
It was necessary because I had 2 much brute force attacks in the logs…
I took the src rpm from Stephane de Labrusse’s repo and the src rpms of fail2ban from epel. I recompiled them and it’s working like a charm.
Many thanks to Stefano for the excellent plugin!!!
great! but I have to apologize. I had already ported but I forgot to write it down
I also tested locally nethserver-dokuwiki and nethserver-ddclient but I didn’t copy them in nethserver-testing on repo.
As soon as i can i’ll do it and write it here and on the wiki.
if i remember well i had some major problem with nethserver-transmission but i do not remember why …
ah, and i had added nethserver-diagtools in updates
but i still need to rebuild latest version of ufdbguard…
if/when you build new packages let me know so i can add them to repo…
tnx!
[CODE]
Transaction check error:
file /etc/e-smith/db/configuration/defaults/postfix/access conflicts between attempted installs of nethserver-mail-server-1.10.9-1.ns7.noarch and nethserver-mail-common-1.6.3-1.ns7.noarch
Error Summary
[/CODE]
what is going wrong with the dependencies? My goal is to run Nextcloud with mail server on the raspi…
sorry, i miss to sync the latest nethserver-mail-server package (1.10.11-1.ns7)
can you retry with
yum install @nethserver-mail
or from software center?
tnx
I tried it yesterday from software-center and from console login with the same error.
Today all installed fine from software center. I cleaned the yum cache manually before.
Now I’m not able to login to nextcloud but I’m not able to figure out why. The logfile from httpd says nothing. I’m on the same point as 2 month ago.
Is there somebody who is running nextcloud on the raspi?
netherserver-colelctd is not creating a rrd folder in /var/lib/collectd/. This is what im having: Error: No Collectd hosts found in /var/lib/collectd/rrd. Besides, it’s a piece of work to install the Statistics plugin, lots of unmet dependencies (libpango libcairo and so on). Got it to install though, any idea why i’m not getting the graphics?
