We are working very proudly to have Asterisk 13 and FreePBX 14 on NethServer 7!
They are useful to turn your NethServer 7 into a phone switchboard!
What is Asterisk?
Asterisk is a free and open source framework for building communications applications and is sponsored by Digium ( http://www.asterisk.org/ ).
What is FreePBX?
FreePBX is a web-based open source GUI (graphical user interface) that controls and manages Asterisk (PBX), an open source communication server ( https://www.freepbx.org/ ).
What are we doing?
We have started from Sangoma’s packages built for the FreePBX distro ( https://www.freepbx.org/downloads/freepbx-distro/ ) to avoid unnecessary work and to get upstream.
The Asterisk related packages are fully usable as they come from the distro, but the FreePBX package needs some improvements to fix the installation process as it actually uses a php installer that is not very “smart” (the rpm does not keep track of its own files!).
As you can see from the following url, we have suggested to Sangoma to change their approach in making their rpms packages for FreePBX, but they persist in thinking that it is good due to their upgrades and modules architecture.
So, our approach will be to avoid big changes to their FreePBX rpm as much as possible in order to keep the same direction and reduce the work, just little fixes.
Im sorry i havent been very active on the chats and other activites.
Please let me know if there is any assistance I can assist or help with.
I havent really played played with freepbx 14 yet, I have almost 56 deployments out in the field still on Freepbx 13. But @Nas you very correct. Asterisk and FreePBX do have numerous security breaches, and loops.
It seems like your local service providers cache has not synced yet. I had the same issue with mine. Our local cache is maintained by tenet in South africa. But i got them to do a forced update, It seems that none of your local caches have updated yet.
Give it about 24 to 48 hours to update.
Idont want to brag or anything. Sorry, but except for the freepbx still in beta and alot of the features of the usual freepbx are still missing. Not Nethservers fault. Its looking good.
Only one thing @jobezic that I have found.
amportal when i run comands periodically brings bring up an error of using php 5.4.1. And it requires a minimum of 5.6. Im just trying to replicate and get a screen shot. I will send it through later
So far 20 extensions 1 sip trunk 1 iax interbranch link to an exsisting box and a fax link to my offices hylafaxsystem proudly running on Nethserver. And only one problem… It still wont make my cup of coffee… otherwise its looking really good
Thanks @Stll0 Im feeling a bit dumb right now. It seems thevsouth african cache had not pulled everything. Or maybe its just me. Im not seeing the usual, ivrs or conference rooms, im still in freepbx 12.
Regarding the error, I will send a screen shot and the full commands sent.
