you have a bundle of some dyndns providers, some are free, other are non free. If you think that more providers could be added, please provide the dydns configuration (GG is your friend)
This is a good implementation of the ddclient service, but I am using Freedns (http://freedns.afraid.org) as a provider.
Could this provider be added to the module?
Sample #1
daemon=5m
timeout=10
syslog=no # log update msgs to syslog
mail=root # mail all msgs to root
mail-failure=root # mail failed update msgs to root
pid=/var/run/ddclient.pid # record PID in file.
ssl=yes # use ssl-support. Works with ssl-library
use=if, if=eth0 server=freedns.afraid.org
protocol=freedns
login=login_name
password=the_password somedomain.mooo.com
Sample #2
use=your_router #If supported, can be listed with ddclient --help server=freedns.afraid.org
protocol=dyndns1
login=login_name
above the ethernet NIC eth0 is used to retrieve the external IP
above the router is used to retrieve the external IP
I can be wrong but the service needs a reference to find the external IP, for commodity I use an external website, but you can choose between several others
Question, it is possible with the DDNS module set up a plain-provider in which you can enter the server and returns the string with placeholders itself.
Well my idea is that for vendors that are not listed a kind of free-text input power, so the server indicates manuel and the module enters ddclient.conf this accordingly in the.
User name and password and the domain you wear so well accordingly, still missing the protocol and the server where you registered with.
Here the pattern contents of a ddclient.conf would be with the data of freedyndns.de
(/etc/ddclient.conf)
Your provider dyndnsfree is now available, with free custom field if your want another provider.
It is not a satisfy solution to provide custom fields since some providers are different and use not standard settings, but that can help.
I wonder if someone needs wildcard settings with their providers ? Personally I use dyndns and I have it enabled for my personal use, but if you need it we can imagine a setting with a checkbox.
The coding weekend is over, I worked yesterday, and I go now to see another customerâŠpfffttt
