I can confirm that with noip.com works perfectly. Thank you!
I want ddclient for a new NethServer, but I can’t install because the repository is down.
Can anyone help me?
Thanks,
Marcelo Costa
If the nethserver-ddclient RPM comes from a third-party repository only the repository owner (@stephdl?) can help you!
On the other hand, we can build the RPM from source code and upload to nethforge-testing. Despite what this old issue says, I’ve not found the RPM in nethforge/nethforge-testing
could you try… see the repository part
I following this post Help in testing mirror/repo and works with dz00te repo.
Thanks,
Marcelo Costa
@stephdl - once more thanks for great job!
Just to make the provider list longer (and make me happy). Is it possible to add DNSexit?
https://www.dnsexit.com/Direct.sv?cmd=ipClients
Thanks again!
can you provide us the configuration you used please ?
EDIT : it seems that your dynamic provider cannot be used easily with ddclient, see https://sourceforge.net/p/ddclient/discussion/399428/thread/04e23ee6/
Is ovh supported?
if you spoke about dynhost (ovh.com) I think so
I try to use ddclient with cloudflare but i got this error
FATAL: Error loading the Perl module JSON::Any needed for cloudflare update.
How i can install perl-json module??
Thk in advance
Regards
Try this:
protocol=cloudflare
server=www.cloudflare.com
Firts, i don’t have your screen for the configuration.
Secound, the problema is when start the services
ddclient -daemon=0 -debug -verbose -noquiet
Sorry, I thought you had already installed following this topic:
from the terminal:
cat << ‘EOF’ > /etc/yum.repos.d/dz00te.repo
[dz00te]
name=dz00te repository for nethserver $releasever - $basearch
baseurl=http://mirror.framassa.org/NethServer/$releasever
enabled=0
gpgcheck=1
gpgkey=http://mirror.framassa.org/NethServer/RPM-GPG-KEY-dz00te
EOF
Then:
yum --enablerepo=dz00te install nethserver-ddclient
try what I said and let us know
Regards
Hi @dz00te and @stephdl need your opinions with this configuration:
Cloudflare not on the list ddclient and requires special configuration.
Add in GitHub: (/root/usr/share/nethesis/NethServer/Template/DdClient/DdClient.php
->insert($view->radioButton(‘DynDns’, ‘CLOUDFLARE’))
Add in GitHub: (/root/etc/e-smith/templates/etc/ddclient/ddclient.conf/20Declaration
elsif( $dns eq ‘CLOUDFLARE’)
$explain=‘## cloudflare dns static’;
$protocol=‘cloudflare’;
$server = ‘www.cloudflare.com’
Dynamic DNS hostname =
registered domain cloudflare
Login = registered mail cloudflare
Password = api key registered user
the configuration is appropriate?
You can keep updated ddclient, we are currently using version 3.8.1 and 3.8.3 is the last
@Alejandro_Guerra you can use ddclient from console cloudflare following specifications and using the version 3.8.3 of ddclient
after installing 3.8.3 ddclient verifies the following:
This we can find in the file: ddclient (perl)
require 5.004;
use strict;
use Getopt::Long;
use Sys::Hostname;
use IO::Socket;
Change:
require 5.004 for require 5.014;
and add this:
use JSON::Any;
although requested to install these packages, it is not: (libjson-any-perl & libio-socket-ssl-perl)
yum install curl sendmail libjson-any-perl libio-socket-ssl-perl
Loaded plugins: changelog, fastestmirror, nethserver_events, presto
Setting up Install Process
- centos-base: mirrors.coreix.net
- centos-updates: mirrors.coreix.net
- nethforge: mirror.nethserver.org
- nethserver-base: mirror.nethserver.org
- nethserver-updates: mirror.nethserver.org
Package curl-7.19.7-52.el6.x86_64 already installed and latest version
although requested to install these packages, it is not.
Resolving Dependencies
→ Running transaction check
—> Package sendmail.x86_64 0:8.14.4-9.el6 will be installed
→ Processing Dependency: procmail for package: sendmail-8.14.4-9.el6.x86_64
→ Processing Dependency: libhesiod.so.0()(64bit) for package: sendmail-8.14.4-9.el6.x86_64
—> Package hesiod.x86_64 0:3.1.0-19.el6 will be installed
—> Package procmail.x86_64 0:3.22-25.1.el6_5.1 will be installed
→ Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository SizeInstalling:
sendmail x86_64 8.14.4-9.el6 centos-base 716 k
Installing for dependencies:
hesiod x86_64 3.1.0-19.el6 centos-base 20 k
procmail x86_64 3.22-25.1.el6_5.1 centos-base 162 k
Transaction Summary
Install 3 Package(s)
Total download size: 899 k
Installed size: 1.9 M
but: Package perl-JSON-2.15-5.el6.noarch already installed and latest version
try this and you let us know how it goes
Regards
i did everything you wrote, but i got this error
Can’t locate JSON/Any.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at /usr/sbin/ddclient line 28.
BEGIN failed–compilation aborted at /usr/sbin/ddclient line 28.
and i try this
[root@nethserver /]# yum install perl-JSON-Any
- centos-base: centos.mirror.iweb.ca
- centos-updates: centos.mirror.iweb.ca
No package perl-JSON-Any available.
Error: Nothing to do
Install perfect !!!
Now i need to making the change for configuration for cloudflare
indeed! brother, there are problems with perl packages.
in NS6.8 not found and tests I made requested me, several dependencies.
@Alejandro_Guerra But i found this repo epel 6.8:
> yum install http://dl.fedoraproject.org/pub/epel/6/x86_64/epel-release-6-8.noarch.rpm
test and comment us how it went
in NS7, yes is located perl-JSON-Any
I’m looking francis cabrel at ‘pause guitare’…a festival of music at albi.
I’m far from computer…the real life is good also
I REALLY don´t know if the software i downloaded are the same, but i just did install a DDCLIENT and it worked really well with DynU, they even post a typical configuration file:
https://www.dynu.com/en-US/Support/Download
Good stuff!
