Nethserver 8 extend drive
Hi All
I have NethServer 8 installed on Proxmox 8. How do I extend my samba drive from 40GB to 200gb? I have already added the extra space in Proxmox.
I just downloaded a GParted ISO file, loaded it into Proxmox, and tried it, seemd to work but at the end it would not apply.
I followed this post (Andy) ended up with GParted error
Am guessing that is because it is Rocky 9 and not Debian.
Hi @HZK
This system has 5 partitions, 4 primary and one one of those 4 is an “extended” partition.
Here is where the partition 5 is…
First the enclosing box needs to be enlarged, then the actual swap partition on partition5.
You should be able to see which partition is used for the extended partition5…
Hi Andy
So to stop it crashing if you drag it along then hit the + it increments the move to the correct 1024k block.
That looks “sernsible”.
The partitioning on that Rocky looks “highly experimental” and not really suitable to a productive system.
For example, what is /dev/sda3? (Prep ?).
/dev/sda4 doesn’t really look correct, as the boot partition is already on /dev/sda2…
When using BIOS Boot, 3 Partitions are normal. When using EFI, then 4 Partitions.
(Valid for a single disk system / mirrored).
I would NOT use such a unlogical and crappy set up system as a base for a productive server.
My 2 cent
Hi Andy
Pherhaps that is just the way GParted is represinting the disk/partitions. This is a qcow2 image from the NethServer site (ns8-rocky-linux-9-ns8-stable.qcow2). Is there a Debian install then install NS8?
Yes, that’s what I did in my HowTo, which I sent you in an earlier message…
I did state I’ld install the base OS myself. :slight_smile:
The pre-built VMs did have issues in the past.
Add to that the fact that I do know Debian and been using it for more than 30 years AND being using VMWare as Hypervisor since before 2000 - so I probably know Debian and Virtualization better than all our Devs here! I switched to Proxmox around 2014/2015 - and moved all my clients over quickly!
I like & prefer Debian and have been using Debian since before RHEL even started…
All my ca 10 NS8 Clients run like this, albeit most using a much more powerful Proxmox Hypervisor.
A lot are using HP Proliant ML series (Or DL for those using 19" Racks), usually Silver or Gold,
or an equivalent Dell / Supermicro box.
(The HowTo was intended to show it’s possible for NS8 install on a low powered Hypervisor…)
Note:
If any of my clients would like to pay for support, I can at any time spin up a similiar Rocky VM, make it into a member node, then move all Apps and AD/Fileserver via Backup/Restore or Migration to the new node.
At least here, we do have freedom of choice, and a not to hard migration path… :slight_smile:
You could use growpart to extend:
Hi Andy, you spoke to soon. Manage to expand the disk from 40GB to 190GB. but now I see the users (2) corrupt and the group (1) also corrupt. Only other thing I did was change the IP address.
You may need to set the new ip in samba too, see also NethServer 7 migration — NS8 documentation
api-cli run module/samba1/set-ipaddress --data '{"ipaddress":"192.168.1.123"}'
And soon as I put IP back to what it was NS8 nmtui (DHCP Automatic) my Users and groups are back. Is there a concole or terminal session in the NS8 gui? (Like NS7 had).
There’s no web terminal in the NS8 cluster-admin.
You could install cockpit, see also NS8 terminal for cluster admin - #8 by stephdl
As you run on proxmox you can just use the console of the VM?
For changing the partition size of the prebuilt qcow image I did the following:
Increase the size of the disk image in proxmox.
Then from the console of the vm:
growpart /dev/sda 5
xfs_growfs /
Please note that there is a space between “sda” and “5”
EDIT: Sorry, now see that this was already suggested by mrmarkuz.
Hi All
Debian12 NS8
After changing the IP I managed to link the domain back to the domain IP with changing the Provider api-cli run module/samba1/set-ipaddress --data ‘{“ipaddress”:“192.168.16.10”}’ all users and groups and share working.
But now the mail server cannot find the domain.
Should I just remove the domain and start again?
Many Thanks as always for any help
PS
I have uninstalled and reinstalled the mail, made no difference.
I am setting up this system at my place (192.168.25.0/24) but the place it is going to is (192.168.16.0/24). Before moving it I wanted to switch over the IP addressing.
Hi @HZK
This is NOT the way to set up a good server.
Better would be:
  • Create a separate subnet on your router simulating your Target Network (192.168.16.0/24) or a second router creating a separate subnet.
  • Set up the server there - so it will not need an IP change.
What’s your servers hostname and domain?
hostname -f
The mail domain default is set to the domain of the host and it seems there’s no dot in the domain name, see also ns8-mail/imageroot/actions/get-defaults/10get_defaults at main · NethServer/ns8-mail · GitHub
Many thanks Andy, I figured that NS8 is quite sensitave to IP change. I can set that other IP range up.
Hi mrmarkuz
Here is the host name.
root@debian:~# hostname -f
debian.gkas
Is that a link to a script to run?
