How to make users for second maildomain
NethServer Version: 7.4
Module: mail
Hi there, I have a small question. I have my server up and running with a domain name aaaaaaaa.nl Now I added a second domain name to the server for website and mail. I don’t want those users be a part of my server on aaaaaaaa.nl but only mail users on bbbbbbbb.nl.
How to seperate those users? I only seem to be able to make users as koos@aaaaaaaa.nl
Thanks in advance, Pitmaster
AFAIK You can’t…
You can use alias to associate a mail with domain @bbbbbb.nl to a user/gorup with @aaaaaaa.nl domain
Email Adresses -> tab “Mail Aliases” -> click on “Create New”
But that means people have to log in with user@aaaaaaaa.nl to get mail for user@bbbbbbbb.nl?
Thats unusual.
Pit
Yes, but you can log in without @aaaaaaaaa.nl suffix.
@Pitmaster, what you want is a multi-tenant mail environment. Unfortunately NethServer does not provide that.
Webtop5 has the option to act as multi-tenant mail solution, but that feature is not implemented in NethServer.
@gabriele_bulfon has explained it in this post
For the rest I refer to what @saitobenkei said: you can create domain users with the domain you configured when you installed your Samba4 domain or LDAP domain.
You can add several other mail domains so your domain users can send and receive with alias email addresses. Those aliases can be either created from the initial domain or with another mail domain.
I made a installation like yours, where I need to have two or more separate domains for mail address.
I don’t need to join to SMB or LDAP domains or to use it as file server so I use a dirty hack:
Suppose that mail domains are @aaaaa.nl and @bbbbb.nl
I installed my machine with local LDAP provider. The Domain I’ve assigned is @local.lan (yes, @local.lan)
For every user I create a name.surname@local.lan profile/login
Example: I have:
Mario Rossi (his email is mrossi@aaaaa.nl)
Piero Bianchi (his email is pbianchi@aaaaa.nl)
Elisa Neri (her email is eneri@bbbbb.nl)
Franca Rossi (her email is frossi@bbbbb.nl)
I’ve created the following users:
mario.rossi@local.lan
piero.bianchi@local.lan
elisa.neri@local.lan
franca.rossi@local.lan
In “Email” -> “Domains” I’ve created domain emails
aaaaa.nl
bbbbb.nl
That point to “this server”
In “Email addresses” -> Tab “Mail Aliases” I’ve assigned the correct email address to every user
mrossi@aaaaa.nl -> mario.rossi@local.lan
pbianchi@aaaaa.nl -> piero.bianchi@local.lan
eneri@bbbbb.nl -> elisa.neri@local.lan
frossi@bbbbb.nl -> franca.rossi@local.lan
In this way you don’t risk that someone who writes at the eneri@aaaaa.nl (email that don’t have to exist), the mail is delivered.
You can login to POP3/IMAP/SMTP/Webtop/Roundcube either with name.surname or name.surname@local.lan (if you use activesync with webtop you must use name.surname@local.lan).
In this way you have user logins that aren’t bound directly to your email addresses.
Remember to put the host names of your domains in “DNS” -> “Server Alias”
If in your provider DNS you have registered mail.aaaaa.nl and mail.bbbbb.nl that points to pubic IP address of your server, you have to insert mail.aaaaa.nl and mail.bbbbb.nl in “DNS” -> “Server alias”.
Remember to create the correct entry of those hosts in your local DNS too.
Addendum:
If you want to use the webtop cloud to send/receive attachments, you should have a third “generic” domain/host (for example my.ddddd.nl) where download/upload links have to point.
Configure my.ddddd.nl in Nethserver as above for others domains, then digit the next commands in console:
config setprop webtop PublicUrl "http://my.ddddd.nl/webtop"
signal-event nethserver-webtop5-update
(http is correct, Nethserver will be redirect to https automatically)
I am testing a vm with ClearOS at the moment. See or this OS can do the job.
Pit
Maybe they have same situation as Nethserver:
https://www.clearos.com/clearfoundation/social/community/mailbox-with-multiple-domains
Hmmmm, it look like it is pretty much the same. Damn, maybe back to my old Ubuntu.
I think about a vm with Nethserver within the default server…
Pit
If you want to use Nextcloud in Webtop then I recommend to use https instead of http. The link you send for downloading will be in http and when a password is necessary to download the file it will be probably in plain text.
Webtop switches automatically from http to https when you click on the link.
Nethesis Technical Assistance has told me specifically:
in prop uses http and not https, then the system will perform the redirect appropriately.
(Occhio: nella prop usa http e non https, sarà poi il sistema ad effettuare opportunamente il redirect.)
Sorry, probably I have misunderstood.
The modify that I wrote it’s for use inside Webtop cloud
I never tried with link directly to another cloud system without going through Webtop cloud
I have tested it from within Nextcloud and there the link was sent in https:. When I integrated Nextcloud into Webtop (cloud) the link was sent in http. I had to change the Webtop ‘Public Url’ to get it right.
