Hi everyone.
Does anyone who uses Openfire know how I can set up to bring the real name instead of username?
Openfire is bringing my username and not my name, as you can see in print01 and print02.
In Zentyal Server with Openfire comes with real name.
I have compared the settings of both servers and they are the same.
mrmarkuz
(Markus Neuberger)
January 27, 2018, 12:10pm
2
At installation you are able to map the fields:
You may also edit the AD settings via admin web UI:
To have the full name use displayname instead of cn
You may use phpldapadmin to find out the fields to map.
It would be very nice if you could post the settings working with NethServer afterwards.
Like I see on screenshots, same problem that there are currently about users.
How to hide from list?
admin
Administrator
Guest
krbtgt
ldapservice
NSDC-PDC
PDC
It is linked to:
Neustradamus:
Well, I created a group called “openfire” on NethServer
And on the Openfire server, I activated shared contacts using Domain users
(Sorry, my Openfire is lang portuguese)
In “Domain Users”, admin is not part of the group
In Zentyal, you have not created a new group?
Because I search a solution for all softwares in NethServer (Roundcube, ejabberd, etc.).
In Zentyal was the same, I had to create a group
