I think @stephdl Stephdl has a new repo, saw that when updating yesterday or day before…
I think on the NethServer Modules page the link is updated for @stephdl 's Repo…
if you have installed openldap or dc, use the password of users, else the login is admin/admin
go to https://domain/dolibarr
You did a great job
- I think its time to pay you a beer…
From me too.
Tried to restore the dolibarr mysqldb on another server and was not able to login. Seems that the login AD credentials are wrong now but I think you now that…
Maybe It could be possible to exclude the login-creds from the backup?
Could you explain line by line what you did, for the migration and what it failed. Indeed the ldap is build with a mysql importation, maybe after the migration you need to trigger the event nethserver-dolibarr-update to import the new login/password inside the database.
try to trigger the event nethserver-dolibarr-update, verify that the file /usr/share/dolibarr/htdocs/conf/conf.php gets the good settings, compare with account-provider-test dump
OK, but no time left. I will try it tomorrow…
Thank you for your Help!
Nicely done! Installation is working great.
A few notes:
Installation of external module is not possible from the web interface for the following reason: Failed to write in directory //usr/share/dolibarr/htdocs/custom
Fileset integrity checks are not working (upstream issue).
krbtgt (kerberos user), ldapservice and Guest listed as dolibarr users. Maybe not an issue.
Some modules URLs are referring to 127.0.0.1. Do not recall if this is by design (URL examples) or if in other versions URLs pointed to the server FQDN or IP:
URL to check and launch qualified cron jobs
A public interface requiring no identification is available at the following url : https://127.0.0.1/dolibarr/public/ticket/index.php
newly created AD users instantly available on dolibarr: OK
Thank, I think I have some stuff to fix, I will make a point
# Import Nethserver DolibarrDB (get the password from new installed dolibarr)
/usr/bin/mysql dolibarr -h localhost -P 3306 -u dolibarr -p<mypassword> < /root/mysqldump_dolibarr_11.0.3_202004181836.sql
signal-event nethserver-dolibarr-update
OK, migration went well…
I need to do some doc, I will ping you to make some comments on what you did
Yes, OK
relative to the migration of dolibarr, did you use the import/export functionnality of dolibarr, or you did a mysqldump in a terminal ?
Just the mysqldump via CLI.
thank @dnutan I saw now that there is a ticket software inside dolibarr, it is a nice feature
done
lets see later if we need to fix it
krbtgt (kerberos user), ldapservice and Guest listed as dolibarr users. Maybe not an issue.the issue here when you check the ldap with phpldapadmin, it is an user like ldap@service, guest.....not easy way to filter them. We could have another way, allow only members of a group to login, for example dolibarr and therefore maybe display only members of this group. However it is not so simple :)
done
done
done
