Who want to break his server, mine is already upgraded, nothing to say much
list of new features https://github.com/vstakhov/rspamd/releases/tag/1.7.9
Thank you in advance
Updated and it works fine.
Regards
Uwe
Update went fine. Reseting history now works!
clicking on configuration pops up a message “local > Request failed: Language not found” Not sure what that’s about.
thank for reporting, introduced by 1.7.9, we hide all score settings in rspamd and it seems problematic
@happnatious1 @transocean you felt very brave!
The world belongs to the brave.
ok got a fix
yum install http://packages.nethserver.org/nethserver/7.5.1804/autobuild/x86_64/Packages/nethserver-mail2-filter-2.2.7-1.3.pr71.g1e7a4c8.ns7.noarch.rpm
the UI expect a 200 return, and we block all actions URL by the reverse proxy, hence apache answers a 404. This is the error we can see.
In short to test rspamd-1.7.9
yum update rspamd --enablerepo=nethserver-testing
please test and report
Everything looks good.
Thanks stephdl
After installing the latest release from the software center it looks like the problem is back.
What issue ?
Check the nethserver-mail2-filter IS still the right version
clicking on configuration in the rspamd page pops up a message “local > Request failed: Language not found”
rspamd version 1.7.9
rpm -qa | grep nethserver-mail2
well found, You got an update which has overwritten my fix, check the rpm is now nethserver-mail2-filter noarch 2.2.8-1.ns7 nethserver-updates 67 k
the output of the command rpm -q nethserver-mail2-filter is:
nethserver-mail2-filter-2.2.8-1.ns7.noarch
good my fix is gone
I hate it when I fix stuff too.
Be patient, in few days we will release my fix and rspamd 1.7.9.
I understand, thank you for all your hard work.
Ola
Someone to test and report the upgrade to rspamd-1.7.9, please check https://github.com/NethServer/dev/issues/5561#issuecomment-418278813
