Try out Nethserver 7 beta1
We need your help to make NethServer 7 the best release yet, so please take some time to download and try out the Beta1 and make sure the things that are important to you are working.
  • You can install it on a virtual machine or on a bare-metal server using a DVD or USB stick
  • Upgrade from Alpha 3 is supported through the Software center
If you find a bug, please report it replying to this topic – every bug you uncover is a chance to improve the experience for thousands of NethServer users worldwide, also our amazing beta testers team will be called upon to give its support on that!
Together, we can make NethServer rock-solid. We have a culture of coordinating new features and pushing fixes upstream as much as possible, and your feedback will help improve not only NethServer but Linux and free software as a whole.
Since the ISO was built we released some bug fixes! Check them out from the Software Center!
Closed issues on v7:
http://mirror.nethserver.org/nethserver/7.2.1511/updates/x86_64/Packages/
We are investigating some problems with multiple DHCP (green) interfaces (/cc @giacomo)
I am using Nethserver 7 from alpha 2 in a test mode and install nethserver-dc and nethserver-directory. Now I’m on beta1 and yum update gives me an error : Error: nethserver-dc conflicts with nethserver-directory-3.0.0-1.ns7.noarch. Any suggestions?
I see the same error on a fresh beta1 installation.
In my system I had to remove nethserver-messaging, because nethserver-ejabberd requires nethserver-directory.
Hello,
today I’ve got an update. Web-server is back. But UI got an error too.
“Web proxy stats” meny item open a new instance of UI in the main frame. So I can do this:
screenshot
P.S. Sorry if I post it wrong place :wink:
Upd: ntopng also doesn’t start from the box with next messages in the log:
systemd: Started Start/stop ntopng program.
Jul 14 21:59:50 hostname systemd: ntopng.service holdoff time over, scheduling restart.
Jul 14 21:59:50 hostname systemd: Starting Start/stop ntopng program…
Jul 14 21:59:50 hostname logger: ntopng start
Jul 14 21:59:50 hostname ntopng: Starting ntopng: /usr/bin/ntopng: error while loading shared libraries: libzmq.so.4: cannot open shared object file: No such file or directory
Jul 14 21:59:55 hostname ntopng: Unable to start ntopng[FAILED]
Jul 14 21:59:55 hostname logger: ntopng stop
Upd2: Don’t know if someone reported it. ‘Graphs’ doesn’t work:
screenshot
web browser console output:
screenshot
Yes, This post should be on another topic
You need a library. you’ve updated NS from terminal? yum update or verifies that this package is installed
nethserver-ntopng.noarch : NethServer ntopng configuration
ntopng-data.noarch : GeoIP databases for ntopng
ntopng.x86_64 : Web-based network traffic monitoring
Regards
Sorry, I thought this topic about beta1 =(
No, I did all the things from the UI.
All the was packages installed.
I’ve tryed to reinstall it but with no result.
libzmq.so.4 actually doesn’t exists. Here’s the list:
ls /usr/lib64/libzmq.so
libzmq.so libzmq.so.3 libzmq.so.3.0.0 libzmq.so.5 libzmq.so.5.0.0
I’m not sure shoud I create a symlink with 4…
in fact, it is NS7 Beta 1, but you can open another topic asking or informing the ruling.
take it easy, dont worry be happy :smile: friend
in NS7 terminal run this:
yum search ntop
verifies that this installed
A couple of cosmetic issues.
text not aligned properly when lines from other elements are missing (eg. gateway not set, then dns not aligned):
RAM and swap usage information are too close:
I will try to reproduce.
It seems you are experiencing problems with name resolution.
Try to access the server with the FQDN.
Another reason to remove the gateway field :wink:
New install, using the beta3 CD. Once installed I try to install Sogo from the web interface.but it can not. Something that I need to clear cache first.
Then I go to the command line. The GPG key for sope49-gdl1-mysql has changed and therefore it can’t be installed:
[root@hub ~]# yum install sope49-gdl1-mysql
nethforge | 3.6 kB 00:00:00
Dependencies Resolved
Package Arch Version Repository Size
Installing:
sope49-gdl1-mysql x86_64 4.9-20160305_1664.el7.1 nethforge 36 k
Transaction Summary
Install 1 Package
Total download size: 36 k
Installed size: 138 k
Is this ok [y/d/N]: y
Downloading packages:
warning: /var/cache/yum/x86_64/7/nethforge/packages/sope49-gdl1-mysql-4.9-20160305_1664.el7.1.x86_64.rpm: Header V4 RSA/SHA1 Signature, key ID 2bdaabff: NOKEY
Public key for sope49-gdl1-mysql-4.9-20160305_1664.el7.1.x86_64.rpm is not installed
sope49-gdl1-mysql-4.9-20160305_1664.el7.1.x86_64.rpm Try out Nethserver 7 beta1 | 36 kB 00:00:00
You can work around it if you disable GPG checking, but that is of course not the idea :slight_smile:
No matter how hard i try I just cant get the Nethserver 7 beta1 to connect to the internet… The tricks i use in 6.8 just don’t work
Call to Action for our Beta Testers group:
@dz00te @cronopio @tcpip @mabeleira @mikabeckerich @Marcin_Kozyra @servevirtland @jgjimenezs @fasttech @EddieA @syntaxerrormmm @Enzo @Artem Fedai @Luciano Vicentini @GG_jr @marceloeng @Mark @MartinsZB @Hunv @PaulM55 @Crazyusb @harrioh @MrE
At this moment I’m doing a clean install of Beta 1. I’ll verifying each fault reported
Regards
  • NethServer Installation 7 Beta 1 without problems
  • Update from the software center without problems
  • OpenLDAP installation without problems
  • Installation of SAMBA DC, conflict with OpenLDAP
  • OpenLDAP uninstall without problems
  • Installation of SAMBA DC without problems
  • Create a user from “Users and Groups” leaves create a user, and indicates that already exists without creating it
  • Create a group from “Users and Groups” Create a group, but to make the process an error occurs, no information from the software center
Both OpenLDAP and uninstalling SAMBA DC, this occurs
[["Tf0a2af2d",[{"a":{"message":"Operation completed successfully","description":"The current page must be reloaded to update the navigation menu","buttonLabel":"Reload page","action":"\/en-US\/PackageManager"},"t":"yumSuccess"}]],["T00774e10",[{"opackages_selected":[],"id":"nethserver-directory","name":"Account provider: OpenLDAP","description":"Configure users and groups on OpenLDAP","mpackages":["nethserver-directory"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-dc","name":"Account provider: Samba Active Directory","description":"Configure users and groups on Samba Active Directory","mpackages":["nethserver-dc"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-backup","name":"Backup","description":"Backup of configuration and data","mpackages":["nethserver-backup-data","nethserver-backup-config","nethserver-restore-data"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-bandwidth-monitor","name":"Bandwidth monitor","description":"Configure and manage Ntopng","mpackages":["nethserver-ntopng"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-firewall-base","name":"Basic firewall","description":"Configure network adapters and basic firewall","mpackages":["nethserver-firewall-base-ui"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-l10n-nl","name":"Dutch language","description":"Server Manager Dutch localization","mpackages":["nethserver-lang-nl"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-mail","name":"Email","description":"Email server and filter","mpackages":["nethserver-mail-server","nethserver-mail-filter"],"opackages_datasource":[["nethserver-roundcubemail","nethserver-roundcubemail"]]},{"opackages_selected":[],"id":"nethserver-fax-server","name":"Fax server","description":"Configure HylaFax+ and manage IAX modems","mpackages":["nethserver-iaxmodem","nethserver-hylafax"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-file-server","name":"File server","description":"Daemons and tools for network file sharing","mpackages":["nethserver-samba"],"opackages_datasource":[["nethserver-samba-audit","nethserver-samba-audit"]]},{"opackages_selected":[],"id":"nethserver-l10n-fr","name":"French language","description":"Server Manager French localization","mpackages":["nethserver-lang-fr"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-ftp","name":"FTP server","description":"Configure the FTP server (vsftpd)","mpackages":["nethserver-vsftpd"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-l10n-de","name":"German language","description":"Server Manager German localization","mpackages":["nethserver-lang-de"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-l10n-el","name":"Greek language","description":"Server Manager Greek localization","mpackages":["nethserver-lang-el"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-l10n-hu","name":"Hungarian language","description":"Server Manager Hungarian localization","mpackages":["nethserver-lang-hu"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-messaging","name":"Instant messaging","description":"XMPP\/Jabber chat server","mpackages":["nethserver-ejabberd"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-ips","name":"Intrusion Prevention System","description":"Monitor and block network traffic for malicious activity","mpackages":["nethserver-snort"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-ipsec-tunnels","name":"IPsec tunnels","description":"Site-to-site Virtual Private Networks (VPN) using IPsec","mpackages":["nethserver-ipsec-tunnels"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-l10n-it","name":"Italian language","description":"Server Manager Italian localization","mpackages":["nethserver-lang-it"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-mysql","name":"MariaDB (MySQL) server","description":"Configuration tools for MariaDB (MySQL)","mpackages":["nethserver-mysql"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-openvpn","name":"OpenVPN","description":"Configure remote-access and site-to-site Virtual Private Networks (VPN) using OpenVPN","mpackages":["nethserver-openvpn"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-p3scan","name":"POP3 proxy","description":"Intercept POP3 connections and scan messages for virtus and spam","mpackages":["nethserver-p3scan","nethserver-mail-filter"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-l10n-pt","name":"Portuguese language","description":"Server Manager Portuguese localization","mpackages":["nethserver-lang-pt"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-printers","name":"Print server","description":"Print management server (CUPS)","mpackages":["nethserver-avahi","nethserver-cups"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-roundcubemail","name":"Roundcube web mail","description":"Roundcube web mail","mpackages":["nethserver-roundcubemail"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-l10n-ru","name":"Russian language","description":"Server Manager Russian localization","mpackages":["nethserver-lang-ru"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-l10n-sr","name":"Serbian language","description":"Server Manager Serbian localization","mpackages":["nethserver-lang-sr"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-smtp-proxy","name":"SMTP proxy","description":"SMTP proxy","mpackages":["nethserver-mail-filter","nethserver-firewall-base-ui"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-net-snmp","name":"SNMP server","description":"Configure the SNMP server","mpackages":["nethserver-net-snmp"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-sogo","name":"SOGo groupware","description":"SOGo server and Thundebird extensions","mpackages":["nethserver-sogo"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-l10n-es","name":"Spanish language","description":"Server Manager Spanish localization","mpackages":["nethserver-lang-es"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-statistics","name":"Statistics","description":"Collect and analyse system statistics","mpackages":["nethserver-collectd","nethserver-cgp"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-l10n-tr","name":"Turkish language","description":"Server Manager Turkish localization","mpackages":["nethserver-lang-tr"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-nut","name":"UPS support","description":"UPS management and monitoring configuration","mpackages":["nethserver-nut"],"opackages_datasource":[["nethserver-collectd","nethserver-collectd"],["collectd-nut","collectd-nut"]]},{"opackages_selected":[],"id":"nethserver-webvirtmgr","name":"Virtual machines manager","description":"Web interface for KVM virtual machines","mpackages":["nethserver-webvirtmgr"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-web-filter","name":"Web filter","description":"Squid web content and virus filter","mpackages":["nethserver-lightsquid","nethserver-squid","nethserver-squidclamav","nethserver-squidguard"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-web-proxy","name":"Web proxy","description":"Squid web caching proxy configuration","mpackages":["nethserver-lightsquid","nethserver-httpd","nethserver-squid"],"opackages_datasource":[]},{"opackages_selected":[],"id":"nethserver-web","name":"Web server","description":"Configuration tools for Apache web server","mpackages":["nethserver-httpd","nethserver-virtualhosts"],"opackages_datasource":[["php-mbstring","php-mbstring"],["php-pecl-memcached","php-pecl-memcached"],["php-ldap","php-ldap"],["php-imap","php-imap"],["php-mcrypt","php-mcrypt"],["php-mysql","php-mysql"],["php-pecl-redis","php-pecl-redis"],["php-pecl-apcu","php-pecl-apcu"],["php-gd","php-gd"],["php-smbclient","php-smbclient"]]},{"opackages_selected":[],"id":"nethserver-webtop-groupware","name":"WebTop groupware","description":"WebTop groupware","mpackages":["nethserver-webtop4"],"opackages_datasource":[]}]],["Tbe75182f",[{"id":"everything","name":"Everything","description":"Show groups from any category","display_order":0,"groups":["nethserver-directory","nethserver-dc","nethserver-backup","nethserver-bandwidth-monitor","nethserver-firewall-base","nethserver-l10n-nl","nethserver-mail","nethserver-ftp","nethserver-fax-server","nethserver-file-server","nethserver-l10n-fr","nethserver-l10n-de","nethserver-l10n-el","nethserver-l10n-hu","nethserver-ipsec-tunnels","nethserver-messaging","nethserver-ips","nethserver-l10n-it","nethserver-mysql","nethserver-openvpn","nethserver-p3scan","nethserver-l10n-pt","nethserver-printers","nethserver-roundcubemail","nethserver-l10n-ru","nethserver-smtp-proxy","nethserver-net-snmp","nethserver-sogo","nethserver-l10n-sr","nethserver-l10n-es","nethserver-statistics","nethserver-l10n-tr","nethserver-nut","nethserver-webvirtmgr","nethserver-web-filter","nethserver-web-proxy","nethserver-web","nethserver-webtop-groupware"],"selected":true},{"description":"Infrastructure and groupware services","display_order":1,"id":"base","groups":["nethserver-web","nethserver-messaging","nethserver-monitoring","nethserver-webtop-groupware","nethserver-mail","nethserver-printers","nethserver-iso","nethserver-roundcubemail","nethserver-ntp","nethserver-wireless-tools","nethserver-dc","buildsys-build","nethserver-file-server","nethserver-backup","nethserver-dns-dhcp","nethserver-net-snmp","nethserver-statistics","nethserver-directory","nethserver-nut","nethserver-fax-server","nethserver-mysql","centos-minimal"],"name":"Base system"},{"description":"NethForge modules from Community","display_order":1,"id":"nethforge","groups":["nethserver-sogo","nethserver-webvirtmgr"],"name":"NethForge"},{"description":"UTM Firewall","display_order":3,"id":"firewall","groups":["nethserver-web-filter","nethserver-web-proxy","nethserver-openvpn","nethserver-p3scan","nethserver-bandwidth-monitor","nethserver-smtp-proxy","nethserver-firewall-base","nethserver-ipsec-tunnels","nethserver-ips"],"name":"Firewall"},{"description":"Localization of the Server Manager web interface","display_order":4,"id":"server-manager-languages","groups":["nethserver-l10n-fr","nethserver-l10n-nl","nethserver-l10n-es","nethserver-l10n-hu","nethserver-l10n-it","nethserver-l10n-ru","nethserver-l10n-pt","nethserver-l10n-el","nethserver-l10n-tr","nethserver-l10n-sr","nethserver-l10n-de"],"name":"Languages"}]],["Tca17f75a",[]],["T1b660d6d",[{"description":"Infrastructure and groupware services","display_order":1,"id":"base","groups":["nethserver-web","nethserver-messaging","nethserver-monitoring","nethserver-webtop-groupware","nethserver-mail","nethserver-printers","nethserver-iso","nethserver-roundcubemail","nethserver-ntp","nethserver-wireless-tools","nethserver-dc","buildsys-build","nethserver-file-server","nethserver-backup","nethserver-dns-dhcp","nethserver-net-snmp","nethserver-statistics","nethserver-directory","nethserver-nut","nethserver-fax-server","nethserver-mysql","centos-minimal"],"name":"Base system"},{"description":"NethForge modules from Community","display_order":1,"id":"nethforge","groups":["nethserver-sogo","nethserver-webvirtmgr"],"name":"NethForge"},{"description":"UTM Firewall","display_order":3,"id":"firewall","groups":["nethserver-web-filter","nethserver-web-proxy","nethserver-openvpn","nethserver-p3scan","nethserver-bandwidth-monitor","nethserver-smtp-proxy","nethserver-firewall-base","nethserver-ipsec-tunnels","nethserver-ips"],"name":"Firewall"},{"description":"Localization of the Server Manager web interface","display_order":4,"id":"server-manager-languages","groups":["nethserver-l10n-fr","nethserver-l10n-nl","nethserver-l10n-es","nethserver-l10n-hu","nethserver-l10n-it","nethserver-l10n-ru","nethserver-l10n-pt","nethserver-l10n-el","nethserver-l10n-tr","nethserver-l10n-sr","nethserver-l10n-de"],"name":"Languages"}]],["T2aca61a4",[]],["T9d21b08e",0],["Tb60bee30","Loaded plugins: changelog, fastestmirror, nethserver_events\nLoading mirror speeds from cached hostfile\n * base: mirror.us.leaseweb.net\n * epel: epel.gtdinternet.com\n * extras: mirror.us.leaseweb.net\n * nethforge: mirror.nethserver.org\n * nethserver-base: mirror.nethserver.org\n * nethserver-updates: mirror.nethserver.org\n * updates: mirror.us.leaseweb.net\nchangelog stats. 0 pkgs, 0 source pkgs, 0 changelogs\n"],["T17bcdcb4",[]],["__COMMANDS__",{"0":{"R":"PackageManager_Modules","M":"show","A":[]},"1":{"R":"PackageManager_Modules_Available","M":"setMandatoryFields","A":[{"PackageManager_Modules_Available_groups":false}]},"2":{"R":"PackageManager_Modules_Installed","M":"setMandatoryFields","A":[{"PackageManager_Modules_Installed_groups":false}]}}],["__STATE__","6a11cec91edd10a0ce180e8af4618143"]]
[2] stream_select(): unable to select [4]: Interrupted system call (max_fd=17)
See the system log for details.
  • SAMBA DC uninstalling and then installing OpenLDAP, I can create a user with an error no information and I can create a group and assign the user created
Update from alpha 3 to beta 1 with softwarecenter without problems.
Can’t create a user. Same issue as @jgjimenezs when create a user without password.
Create a user with password lead to failure:
create group leads to the same failure as above.
I guess the uninstall cannot work with nethserver-dc and nethserver-directory. The two packages are mutually exclusive, and the nethserver-sssd is designed to allow a one-way installation of one of the two only, without way back.
@giacomo, @Stll0 do you think we can write an action for nethserver-sssd-update event that performs a reset of the sssd record in Configuration DB if neither nethserver-dc, nor nethserver-directory are installed?
This is an old friend of mine :blush: I’m seeking the origin of it, but it’s very hard… The good news are it is harmless, as it comes out during the background task tracking.
Reload the page and you can go.
This is not supported, but in the past I documented this procedure for the command-line
FQDN didn’t help.
IE screenshot
localhost doesn’t work too
screenshot
Hi Hi
tried again, Started from scratch reinstalled beta 1. First installed the OpenLDAP provider, created a user en then install SoGo:
If i change the /etc/yum.repos.d/NethForge.repo and add gpgcheck=0 it installs. however if i login with the user I can not press the send button nor the save button.
Little other thing although the server has a name the tab in the browser is called: Example Org
Lets see what else I can find :grinning:
