Subnet refused by GUI
NethServer Version: 7.6.1810
I’m trying to setup my OpenVPN with subnet 172.31.4.240 mask 255.255.255.240 and GUI answers
Network
regular expression /^(([0-9]|[1-9][0-9]|1[0-9]{2}|2[0-4][0-9]|25[0-5])\.){3}(0)$/
If i use 172.31.4.0 with same mask completes without errors.
Confirmed. The ip validation doesn’t like 172.31.4.240.
Would you like to open an issue on github?
I don’t have any account on github, sorry.
I tried also with different numbers on the third octet, maybe is only a matter of the fourth octet for being validated.
Workaround:
config setprop openvpn@host-to-net Network 172.31.4.240
signal-event nethserver-openvpn-save
Thanks @filippo_carletti.
GH issue:
The package is ready for testing.
Would you like to give it a try @pike?
Please, post how may I try :wink:
This is the command to install the new RPM:
yum --enablerepo=nethserver-testing update nethserver-openvpn
Then try to modify the configuration from the UI using another netmask and save. Finally go back to your netmask and verify that the UI accepts it.
All /28 subnets seems ok. Anyone can try the /29, /30 and also /31 missing subnets :wink:
I also tried to feed a wrong subnet id, and it was detected.
I don’t know if it’s a bug, but if i change settings, disable the server, and i click on save, the subnet id and mask can still be edited and saved while clicking on save.
Only if i reload the page edit is disabled.
Thank you for testing.
Yes, it’s a little bug in UI framework, we have it since ages :smiley:
IMHO it doesn’t worth fixing it now.
seem never worth fixin…
