the current RC for NS8 does not have a CLI interface to SSH into the server, simila rto what we had in NS7,
Would this be a feature that would be added or considered to be added later to the NS8?
it ussually came in handy, and considering that NS8 now does have its own built in seprate cluster admin users, it would be really great to have such a feature.
I’ve never seen a significant benefit to such a feature. TrueNAS has it, and I never use it. Proxmox has it, and I never use it there either (for the host itself; I use the virtual console for the VMs all the time). What’s the benefit compared to just ssh user@host? Every halfway modern operating system (yes, including Windows since Windows 10) has an ssh client–opening a terminal window and running it has to be faster than opening a browser, browsing to the NS8/Cockpit/whatever web UI, logging in there, and then browsing to the web shell.
say, i tell you, DanB kindly login to my server and install the module X, that was developed by user B
With the interface, i only need to go to NS8 admin interface, add a cluster admin user,
and then you go to browser, login to the server, open terminal window, and do your thing.
Without it, this is what would happen.
Assuming root login is disabled,
assuming pwd login is disabled.
Ill have to share my ssh key with you,
or
add a new user on ssh, upload and assign ssh key for you, most of which are abit cumbersome.
then share my root password, because you need to be rrot to install apps.
isnt it all cumbersome…
Meshcentral used to get it done so well.
I just share a server, and setup security, and anyone can have some access
Heavens no; it would be silly to do either of these. I would give you a SSH public key, keeping the private key, well, private. You’d either temporarily add that to the root user (echo $key >> /root/.ssh/authorized_keys), or (better, but a little more work) to a different user with sudo access. It’s a different process than doing it through the GUI to be sure, but I don’t see that it’s any more cumbersone.
FYI, every linux/bsd out there has SSH built in, right… and what’s nice now is so does Windows 11. Might even be in 10, but I don’t have one handy to test.
But that seems kind of a convoluted way to copy over a public key. If your client is anything but Windows, the simplest way to do it is with ssh-copy-id user@host. If your client machine is running Windows, it doesn’t look like that command is available for some reason, but in that case, ssh to the host, nano .ssh/authorized_keys, and then paste in the public key. The scp seems like an unnecessary step in any case.
Since NS8 doesn’t deal with system-level users at all, I’d say probably not. But it looks like this can be done through Cockpit as well.
As has been discussed several times, NS8 doesn’t include any tools to manage the server itself. Installing updates? Not there. Configuring the network? Not there. System-level user management? Not there either. Heck, even shutting down the system isn’t there. And while I don’t love that fact, and I’m not sure (easy for me to say) it would be a huge amount of development work to figure out which of the two supported distros (because there really only are two: Debian and EL) is being used, and adapt accordingly, that’s the way it’s designed.
So, come up with other ways of managing the system. Use the CLI–it isn’t too hard for the basic tasks that are likely to be necessary. Or install some other tool, like Cockpit or Webmin.
In short @dan a significant amount of hand holding from the developers is required to get some non conventional apps to actually owkr on Ns.
the normal CRUD apps, those would be ok, and the Ninjas in this community given enough time would figure it out.
for complex apps like an SSH terminal to work, or VPN, or server automation scripts… unless we get some samples built by the dev team, i dont see how we could manage
…but Stephane has suggested–in this very thread, no less–installing Cockpit with NS8. That’s additional software that isn’t part of the base distro, nor is it part of NS8. And it’s never been the case with NS7 that you can’t install any software other than NS modules–though in both cases, you’re on your own to ensure they don’t interfere with the rest of what the system’s doing.
But with respect to SSH specifically, this whole thread strikes me as odd. SSH is fundamentally a command-line tool. There are mature tools for configuring and managing it at the command line. I don’t understand the desire for a GUI way to configure/use a command-line tool. Not that it’s bad as such, but I just don’t see why it’s particularly desirable.
I don’t use Windows save as a case to provide some application for a user, or to give them a Windows environment on the other side of Guacamole.
Cool that you have a your own way to solve this, good thing There Is More Than One Way To Do It (TIMTOWDI). I’m a Perl coder by nature, and TIMTOWDI is a normal thing.
I’ll continue doing it the way I do because I spend some 50% of my time in the commandline rather than the GUI as it’s much better more predictable!
