SOGO (and AD LDAP clients) not working after upgrade
Can’t login to SOGO, it says invalid username or password.
When I go to users and groups on the webadmin there are no users listed and I get a red warning message on top : AccountProvider_Error_82
On the command when I try /usr/libexec/nethserver/list-users it says :
kinit: Cannot contact any KDC for realm ‘CHANGED-DOMAIN.COM’ while getting initial credentials
(82) GSSAPI Error (init): Unspecified GSS failure. Minor code may provide more information
Ticket expired
/var/log/messages keeps repeating this
May 14 06:47:01 ganesha [sssd[ldap_child[29987]]]: Failed to initialize credentials using keytab [MEMORY:/etc/krb5.keytab]: Cannot contact any KDC for realm 'CHANGED-DOMAIN.COM'. Unable to create GSSAPI-encrypted LDAP connection.
May 14 06:47:01 ganesha [sssd[ldap_child[29987]]]: Cannot contact any KDC for realm 'CHANGED-DOMAIN.COM'
May 14 06:47:11 ganesha [sssd[ldap_child[30040]]]: Failed to initialize credentials using keytab [MEMORY:/etc/krb5.keytab]: Cannot contact any KDC for realm 'CHANGED-DOMAIN.COM'. Unable to create GSSAPI-encrypted LDAP connection.
May 14 06:47:11 ganesha [sssd[ldap_child[30040]]]: Cannot contact any KDC for realm 'CHANGED-DOMAIN.COM'
May 14 06:47:11 ganesha [sssd[ldap_child[30043]]]: Failed to initialize credentials using keytab [MEMORY:/etc/krb5.keytab]: Cannot contact any KDC for realm 'CHANGED-DOMAIN.COM'. Unable to create GSSAPI-encrypted LDAP connection.
May 14 06:47:11 ganesha [sssd[ldap_child[30043]]]: Cannot contact any KDC for realm 'CHANGED-DOMAIN.COM'
May 14 06:47:16 ganesha dbus[1616]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service'
May 14 06:47:16 ganesha dbus-daemon: dbus[1616]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service'
May 14 06:47:16 ganesha systemd: Starting Time & Date Service...
May 14 06:47:16 ganesha dbus[1616]: [system] Successfully activated service 'org.freedesktop.timedate1'
May 14 06:47:16 ganesha dbus-daemon: dbus[1616]: [system] Successfully activated service 'org.freedesktop.timedate1'
May 14 06:47:16 ganesha systemd: Started Time & Date Service.
May 14 06:47:34 ganesha nfsidmap[30595]: nss_getpwnam: name 'admin@CHANGED-DOMAIN' does not map into domain 'noble-house.tk'
May 14 06:47:34 ganesha nfsidmap[30598]: nss_name_to_gid: name 'users@CHANGED-DOMAIN' does not map into domain 'noble-house.tk'
May 14 06:47:49 ganesha nmbd[2785]: [2018/05/14 06:47:49.738891,  0] ../source3/libsmb/nmblib.c:873(send_udp)
May 14 06:47:49 ganesha nmbd[2785]:  Packet send failed to 192.168.122.255(137) ERRNO=Operation not permitted
May 14 06:47:49 ganesha nmbd[2785]: [2018/05/14 06:47:49.739054,  0] ../source3/nmbd/nmbd_packets.c:179(send_netbios_packet)
May 14 06:47:49 ganesha nmbd[2785]:  send_netbios_packet: send_packet() to IP 192.168.122.255 port 137 failed
May 14 06:47:49 ganesha nmbd[2785]: [2018/05/14 06:47:49.739106,  0] ../source3/nmbd/nmbd_namequery.c:245(query_name)
May 14 06:47:49 ganesha nmbd[2785]:  query_name: Failed to send packet trying to query name NOBLE-HOUSE<1d>
May 14 06:48:01 ganesha systemd: Created slice User Slice of asterisk.
May 14 06:48:01 ganesha systemd: Starting User Slice of asterisk.
May 14 06:48:01 ganesha systemd: Started Session 50 of user asterisk.
May 14 06:48:01 ganesha systemd: Starting Session 50 of user asterisk.
May 14 06:48:01 ganesha systemd: Created slice User Slice of sogo.
May 14 06:48:01 ganesha systemd: Starting User Slice of sogo.
May 14 06:48:01 ganesha systemd: Started Session 51 of user sogo.
May 14 06:48:01 ganesha systemd: Starting Session 51 of user sogo.
May 14 06:48:01 ganesha systemd: Removed slice User Slice of asterisk.
May 14 06:48:01 ganesha systemd: Stopping User Slice of asterisk.
May 14 06:48:01 ganesha systemd: Removed slice User Slice of sogo.
May 14 06:48:01 ganesha systemd: Stopping User Slice of sogo.
May 14 06:48:01 ganesha [sssd[ldap_child[31200]]]: Failed to initialize credentials using keytab [MEMORY:/etc/krb5.keytab]: Cannot contact any KDC for realm 'CHANGED-DOMAIN.COM'. Unable to create GSSAPI-encrypted LDAP connection.
May 14 06:48:01 ganesha [sssd[ldap_child[31200]]]: Cannot contact any KDC for realm 'CHANGED-DOMAIN.COM'
May 14 06:48:38 ganesha [sssd[ldap_child[31815]]]: Failed to initialize credentials using keytab [MEMORY:/etc/krb5.keytab]: Cannot contact any KDC for realm 'CHANGED-DOMAIN.COM'. Unable to create GSSAPI-encrypted LDAP connection.
May 14 06:48:38 ganesha [sssd[ldap_child[31815]]]: Cannot contact any KDC for realm 'CHANGED-DOMAIN.COM'
May 14 06:48:38 ganesha [sssd[ldap_child[31818]]]: Failed to initialize credentials using keytab [MEMORY:/etc/krb5.keytab]: Cannot contact any KDC for realm 'CHANGED-DOMAIN.COM'. Unable to create GSSAPI-encrypted LDAP connection.
May 14 06:48:38 ganesha [sssd[ldap_child[31818]]]: Cannot contact any KDC for realm 'CHANGED-DOMAIN.COM'
Did you upgrade to centos7.5 ?
No just the regular update from the software center on the webadmin.
I have a Crostino subscription so I thought it was safe, usually I take a snapshot before but this time, of course, I did not :disappointed_relieved:
I pasted the message log from the upgrade here : https://paste.ee/p/0viWB
Also nextcloud and xmpp are not available, please help :worried:
Yes not relative to sogo, you cannot authenticate any ldap client
Yes, so it seems. How should I best proceed to get it fixed ? :grimacing:
Any logs I should look into or commands I could try to pinpoint the problem, and more importantly find a solution.
When you look to the line 400 of your pastebin, you can see that the event nethserver-dc-update upgraded the sambaAD VM to centos7.5.
If I understand correctly this could be the key of the problem
@davidep do i’m wrong ?
What did it do that for :cold_sweat: , can and should I revert that upgrade?
Keep calm, how many users have you on your system ?
About 40 to 50 accounts of which like some 20 active users.
Downgrade seems to be an option, but waiting on your reply :innocent:
]# yum downgrade nethserver-dc.x86_64
sb-base        | 3.6 kB  00:00:00
sb-centos-sclo-rh        | 3.0 kB  00:00:00
sb-centos-sclo-sclo        | 2.9 kB  00:00:00
sb-epel        | 4.7 kB  00:00:00
sb-extras        | 3.4 kB  00:00:00
sb-nethserver-base        | 2.9 kB  00:00:00
sb-nethserver-updates        | 4.1 kB  00:00:00
sb-updates        | 3.4 kB  00:00:00
Resolving Dependencies
--> Running transaction check
---> Package nethserver-dc.x86_64 0:1.4.5-1.ns7 will be a downgrade
---> Package nethserver-dc.x86_64 0:1.5.0-1.ns7 will be erased
Dependencies Resolved
 Package                           Arch                       Version                           Repository                                 Size
Downgrading:
 nethserver-dc                     x86_64                     1.4.5-1.ns7                       sb-nethserver-updates                      13 M
Transaction Summary
Downgrade  1 Package
Total download size: 13 M
Is this ok [y/d/N]: n
Exiting on user command
I’m looking at the attached log…
Thank you, we really need the SOGo calendar functionality.
So, all LDAP clients fail to connect with AD LDAP service: is it running? Any error in journal?
account-provider-test dump
ping $(config getprop nsdc IpAddress)
systemctl status nsdc
journalctl nsdc
journalctl -M nsdc
If the nsdc service is stopped try with:
systemctl start nsdc
…and see if any error occurs in journals
https://paste.ee/p/0viWB#s=0&l=439
It seems your system was updated from sb-* repositories as expected. However for a reason that needs to be dug more deeply the NSDC chroot was updated against 7.5 repositories.
So your NethServer is still at 7.4. Only nsdc chroot is rebased on 7.5.
Everything seems to function, only journalctl nsdc returns :
Failed to add match 'nsdc': Invalid argument
Failed to add filters: Invalid argument
First three commands seems to return valid responses and last one shows many many pages of logs.
I’ll try to anonymize some and post them for you.
~]# systemctl status nsdc
● nsdc.service - NethServer Domain Controller container
Loaded: loaded (/usr/lib/systemd/system/nsdc.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2018-05-14 05:27:08 CEST; 9h ago
Docs: man:systemd-nspawn(1)
Main PID: 2825 (systemd-nspawn)
Status: “Container running.”
CGroup: /machine.slice/nsdc.service
├─2825 /usr/bin/systemd-nspawn --quiet --keep-unit --boot --network-bridge=br0 --machine=nsdc --capability=CAP_SYS_TIME
├─2829 /usr/lib/systemd/systemd
└─system.slice
├─samba.service
│ ├─5896 /usr/sbin/samba -i --debug-stderr
│ ├─6141 /usr/sbin/samba -i --debug-stderr
│ ├─6142 /usr/sbin/samba -i --debug-stderr
│ ├─6143 /usr/sbin/samba -i --debug-stderr
│ ├─6144 /usr/sbin/samba -i --debug-stderr
│ ├─6145 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
│ ├─6146 /usr/sbin/samba -i --debug-stderr
│ ├─6147 /usr/sbin/samba -i --debug-stderr
│ ├─6148 /usr/sbin/samba -i --debug-stderr
│ ├─6150 /usr/sbin/samba -i --debug-stderr
│ ├─6151 /usr/sbin/samba -i --debug-stderr
│ ├─6152 /usr/sbin/samba -i --debug-stderr
│ ├─6153 /usr/sbin/samba -i --debug-stderr
│ ├─6154 /usr/sbin/samba -i --debug-stderr
│ ├─6155 /usr/sbin/samba -i --debug-stderr
│ ├─6158 /usr/sbin/samba -i --debug-stderr
│ ├─6159 /usr/sbin/winbindd -D --option=server role check:inhibit=yes --foreground
│ ├─6166 /usr/sbin/winbindd -D --option=server role check:inhibit=yes --foreground
│ ├─6168 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
│ ├─6169 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
│ └─6175 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
├─console-getty.service
│ └─5854 /sbin/agetty --noclear --keep-baud console 115200 38400 9600 vt220
├─systemd-logind.service
│ └─5818 /usr/lib/systemd/systemd-logind
├─dbus.service
│ └─5623 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
├─ntpd.service
│ └─5731 /usr/sbin/ntpd -u ntp:ntp -g
└─systemd-journald.service
└─5515 /usr/lib/systemd/systemd-journald
May 14 05:27:14 nethserver.ourdomain.com systemd-nspawn[2825]: [  OK  ] Started Network Service.
May 14 05:27:14 nethserver.ourdomain.com systemd-nspawn[2825]: [  OK  ] Reached target Network.
May 14 05:27:15 nethserver.ourdomain.com systemd-nspawn[2825]: [  OK  ] Started Samba domain controller daemon.
May 14 05:27:15 nethserver.ourdomain.com systemd-nspawn[2825]: Starting Samba domain controller daemon...
May 14 05:27:15 nethserver.ourdomain.com systemd-nspawn[2825]: [  OK  ] Reached target Multi-User System.
May 14 05:27:15 nethserver.ourdomain.com systemd-nspawn[2825]: [  OK  ] Reached target Graphical Interface.
May 14 05:27:15 nethserver.ourdomain.com systemd-nspawn[2825]: Starting Update UTMP about System Runlevel Changes...
May 14 05:27:15 nethserver.ourdomain.com systemd-nspawn[2825]: [  OK  ] Started Update UTMP about System Runlevel Changes.
May 14 05:27:16 nethserver.ourdomain.com systemd-nspawn[2825]: CentOS Linux 7 (Core)
May 14 05:27:16 nethserver.ourdomain.com systemd-nspawn[2825]: Kernel 3.10.0-693.21.1.el7.x86_64 on an x86_64
and an excerpt from the journalctl -M nsdc
https://paste.ee/p/q7swx
Sorry it was:
journalctl -u nsdc
I’ve tried to reproduce the unexpected RPM installation from 7.5 repositories:
  • On installation, NSDC packages were downloaded from 7.4 as expected.
  • However if I run the nsdc update procedure upstream repositories (7.5) are used.
It does not seem a problem, as the nsdc process is running. However I found an issue with the KDC process of Samba DC:
journalctl -M nsdc -u samba
One of the lines:
May 14 14:59:38 nsdc-vm7.ad.dpnet.nethesis.it samba[158]: task_server_terminate: [kdc: krb5_init_context failed]
Do you have the same?
Yes!
https://paste.ee/p/q7swx#s=0&l=411
The workaround to the bad Samba DC startup, is edit/fixing krb5.conf under the nsdc chroot. Just run this command:
cp -vfp /var/lib/machines/nsdc/var/lib/samba/private/krb5.conf /var/lib/machines/nsdc/etc/krb5.conf
Then stop and start the samba DC process
systemctl -M nsdc stop samba
systemctl -M nsdc start samba
Now I must investigate why the nsdc container wants to download from 7.5 repositories :thinking:
Yes that solved it, thank you very much!
Filed an issue, the fix is available from nethserver-testing repo, but requires the following command to be applied:
 signal-event nethserver-dc-upgrade
