The virtual host for Activsync is not configured, and to be quite frank i’m still figuring out how it al works in the new virtual-host setup an V7-beta2.
I got it running, but it is better if someone else checks this solution.
If it’s good we make it permanent, always remember nethsever most of the configuration file are overwritten at certain events. So you should never manually change them, and that’s exactly what i did.
edit /etc/httpd/conf.d/SOGo.conf
un-mark Microsoft ActiveSync support
# Enable to use Microsoft ActiveSync support
# Note that you MUST have many sogod workers to use ActiveSync.
# See the SOGo Installation and Configuration guide for more details.
ProxyPass /Microsoft-Server-ActiveSync \
http://127.0.0.1:20000/SOGo/Microsoft-Server-ActiveSync \
retry=60 connectiontimeout=5 timeout=360
edit /etc/httpd/conf.d/default-virtualhost.inc
add a redirect, last line (BTW sooner or later this will be overwritten)
For the time being it is fine even if I have to manually make changes every now and then. I just want to test the new Nethserver 7, it is not production.
have a look in:
> ls -l /etc/e-smith/templates/etc/httpd/conf.d/default-virtualhost.inc
> cat /etc/e-smith/templates/etc/httpd/conf.d/default-virtualhost.inc/30SOGo
this are default templates witch construct the configuration files,
you should not touch them! make a custom template instead:
make a directory for it mkdir -p /etc/e-smith/templates-custom/etc/httpd/conf.d/default-virtualhost.inc
Hi all, I’m sorry to have not been able to respond for a long time. As I said I’m only testing Nethserver to check if I can replace the current mail server with an OS solution, but I still have to manage the current one
Yes, activesync worked perfectly, I have been able to configure it on two different mobile phones without any issue, but I still had not time to check the suggestion of mark to make the change permanent. I hope to have more time to test it soon.
