Openstack VM
1 Vcpu, 2 GB RAM 20 GB HDD
DNS
ns8.bybiz.link
min.ns8.bybiz.link
mina.ns8.bybiz.link
Alma Linux 9 standard installation ssh
curl https://raw.githubusercontent.com/NethServer/ns8-core/ns8-stable/core/install.sh | bash
Backup Encryption PW
done
Installation Minio
Setting Minio hostname with http:// or / after the fgdn causes these errors
Minio LE cert is not reflected immediately, is a reboot or login/logout required for main cluster admin for this to be visible?
Configuration
API server host name:
min.ns8.bybiz.link
Web interface host name:
min.ns8.bybiz.link
TEst
NO LE and LE,
LE takes long to reflect.
Api host server name, redirects to :9001
Create a new Bucket and upload files.,
Share link for file is in format of :
http://127.0.0.1:9000/minadmin/things%20to%20read%20and%20research.txt?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=8DVLUACFOQJWB8UVIKII%2F20230915%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20230915T133022Z&X-Amz-Expires=604800&X-Amz-Security-Token=eyJhbGciOiJIUzUxMiIsInR5cCI6IkpXVCJ9.eyJhY2Nlc3NLZXkiOiI4RFZMVUFDRk9RSldCOFVWSUtJSSIsImV4cCI6MTY5NDgyNjUwNCwicGFyZW50IjoibWluaW9hZG1pbiJ9.w_tgEfdlxXjMOADL1BPpizY9DfaKMO6RC-oAhf_VQvhGrRqPP7UBBct4rYFHsoHlALMIg9jejmp5K1gymUlBzA&X-Amz-SignedHeaders=host&versionId=null&X-Amz-Signature=40089df7df5eea37388649ac8165e491df07b17666afb5ac4547877460ee40a7
instead of the defined api hostname
the fact that you can define an external/attached storage is a welcome and nice to have feature.
Notification Panel:
i think it would be great if it was possible to clear individual completed cards on this panel.
Also Ability to clear all.
currently only mark as read is available
Samba AD Installed
Much easier to install and configure than on NS7
Adding a second Provider of Samba, on the same domain possible on the same host, but configuring gives config error.
Adding AD domain and OpenLdap Domain on the same domain is possible (),interesting ![]()
The Edit Domain user Interface is so Huge, i think it can be reduce, since there are not many parameters. ( )
