After TEsting NS8 here: NS8beta2 | MArtin: my experiences and suggestions for imporvements - Feature - NethServer Community
Upgrading to the laest Release candidate and reporting my findings, i Have decided to take yet another Jab at testing, this time around begining with a new instance that is Release candidate 1.
My intentions are to test the server in different cloud enviornment, and report my findings, as well as do things in an unconventionl manner to see if something breaks, and report so that developers can resolve the issues arising before the Final Release VErsion.
Cloud Environment1: ARUBA CLOUD:
Openstack VM
2 Vcpu, 4 GB RAM 80 GB HDD
DNS
ns8.bybiz.link
min.ns8.bybiz.link
mina.ns8.bybiz.link
Alma Linux 9 standard installation ssh
Installation — NS8 documentation (nethserver.org)
INStallation went on sucessfully,
I had not pointed the domain to the new IP address so ssl cert failed during initial install.
I fumbled to figure out how to set ssl for the hostname, and finally found it in settings> TLS certs Request SSL.
(I think the devs would have implemented a component to check if hostname has ssl, and implement a function to request that easily from the main dashboard.)
Enabled TEsting in settings, and installed nethvoice proxy.
proceeded to install NEthvoice, Took way too long at 67% but finally completed the installation.
On
NEthVOICE:
there are 2 hostnames to be configured:
accessing nethcti, i am unable to login with any credentials, i am not sure if its by design, there is something not configured or something else.
Accessing NEthvoice based host, adding /freepbx
I am presented with login interface, which i can login with admin and pwd NEthesis, 1234
user control page, has nothing, and i assume its whats supposed to bring /nethvoice
there i am presented also with NEthvoice link, which is visible under /nethvoice.
tbh, i have no idea what each of the seprate links does, i will jus tkeep on exploring.
under sip providers,
i dont see a means to add a custom provider, not really sure how all these work as well, i am just exploring.
Default settings,
Only these tone zones listed
