Well, if there’s going to be a timeout at all (and I think there should be), there has to be some kind of setting, either baked into the code or user-controllable. Baked into the code is OK as far as I’m concerned so long as it’s a reasonable length of time–I’m not completely sure what that would be, but surely no more than 24 hours. But I suspect people’s opinions are going to vary widely about what is “a reasonable length of time,” so a user-adjustable setting might be the better way to go.
NExtcloud User Mapping
As seen in this image, we had a challenge between nextcloud users created on AD/Ldap into nextcloud having that weired ID defined.
the issue became even more compunded, when we added SAML(OIDC) using the LLLNG Module whereby, the system now had 2 set of users.
I am curious, is that mapping going to be fixed in NS8 or is it going to remain the same.
DOes NS7 to NS8 Migration also support Nextcloud Migration.
from this: NethServer 7 migration — NS8 documentation
Or would NExtcloud Migration have other requirements?
This “just works”!
So Both Nextcloud as well as the EMail would be migrated successfully to a new NS8 Server.
WOW, thats really going to be of huge help to me. been wanting to migrate a certain NExtcloud and MAil server running NS7 to another Node for 2 years…
What stopped you? IMAPsync has been available for a few years on NS7 now…
That would be mail,
Nextcloud is just DB & files…
Backup / Restore would also have worked!
Copy files and Export / Import DB would have been another way to move it over…
No reason for you putting it of for 2 years!
If it didn’t work before, there’s other issues, not mentionned here (yet)…
What won’t work is having Nextcloud data on source and target, and you wanting to merge both. A Migration will NOT do that, it’s not a migration. Migration is always to a new, clean box (In IT, at least. For Humans, migration entails “other” issues!)
these are 2 separate servers with separate public ip, but upon migration, they are supposed to retain the same domains. cloud.domain for nextcloud, and webmail.domain for email as well as the same variances for the hostname.
Now my understanding so far of Imapsync, is that it will migrate to 2 seprate mail nodes operational.
how would imapsync work in this case, with the mail server, considering one has to be offlined, (DNS limitations)
how should the mx records be implemented to have both mail servers function with the same domain at the same time to have imapsync work for both.
so for both servers, a username and active domain account needs to work
imapsync \
--host1 test1.lamiral.info --user1 test1 --password1 secret1 \
--host2 test2.lamiral.info --user2 test2 --password2 secret2
Thank goodness my AD server is running on a separate dedicated node, Not Even Sure if that would migrate to NS8 soon, i can always attempt, without the old one being offline
IMAPsync syncs to a “different” server.
It can be used as an “offsite” backup of mail.
It can also be used to migrate a mail server, after migration, names are changed, DNS adapted, etc.
As your AD is already separate and is reachable for both, this would be actually easier!
For details, see the manual, there are a lot of options!
so basically what youre saying is,
have a seprate domain MX records on the second server, then use imapsync to sync the data, then once the syn/migration has completed,
change the DNS records for the new server to the old domain, and remove the old domain components.
OK Noted, there cpuld still be uses for it elsewhere.
For this server, since 2024 is already around the conner, and NS8 is already reaching RC, hopefully a release will be ready before or by End Year, then On December,(where little traffic) i can work on the migration.
Who said it needs MX for migration?
Think small home server, having a full offline / offsite backup of your Gmail…
Why would any MX be needed for this scenario?
AFTER a successful sync, and you want to promote that server, you can (Then needs ports, MX, etc…)
You could also use IMAPsync as Bridgehead:
Use a IMAPsync wherever you need it to keep a copy of all accounts and maiil. This does not even need to use AD accounts (same named ones locally would do, IMAPsync does NOT transfer account information. When ready to move mail, just change the existing sync (source server) to new (target server).
This is VERY flexible, and simple to use!
Right, filed here NethServer 8 · GitHub
@davidep Is there something that can be done to this
When one clicks the Update Button, either the button becomes inactive, or to show something is already working,
Currently, we have a situation where one can click an item to be updated multiple times, while i have noticed there is not problem when this happenes, it is just a quality of life improvement.
Updated to NExtcloud 27.1.3 (Hub 6)
I am getting the following error, after updated to nX Hub 6 on the settings dashboard.
Right now it seems to be a cosmetic error, and i have noticed anything yet.
We’ll try to disable the module update from the NC admin page, as Marc pointed out here:
(Nextcloud)
the new TAbles APP in NExtcloud is an extremly powerful tool, interesting
My NethVoice Installation Freezes at 67%
After performing the relevant system up[dates,
I went to software center and first installed the NethVoice Proxy.
my assumption for doing this was that NethVoice might not work without Nethvoice Proxy.
After installing Nethvoice Proxy, i proceeded with installing NEthVoice CTI.
unfortunately its been more than one hour, and it has stuck at 67 percent.
I am not sure what might be the issue.
this is still my repos settings:
finally it has failed the installation with the following trace:
{"context":{"action":"add-module","data":{"image":"ghcr.io/nethesis/nethvoice:0.0.1","node":1},"extra":{"completion":{"extraTextParams":["node"],"i18nString":"software_center.instance_installed_on_node","outputTextParams":["module_id"]},"description":"Installing on Node 1","eventId":"68d57823-7561-4d13-bfb8-1b8d8a8075d3","node":"Node 1","title":"Install NethVoice"},"id":"01ebf395-d859-432a-9749-fec142206209","parent":"","queue":"cluster/tasks","timestamp":"2023-11-23T08:57:40.525699463Z","user":"admin"},"status":"aborted","progress":67,"subTasks":[{"context":{"action":"add-module","data":{"environment":{"IMAGE_DIGEST":"sha256:5ffffacfb28e2f61669d4a7c7d9afa331748422d10900881839923b4df524a37","IMAGE_ID":"bdc95fb292f0dd00529a13a2962fbb9ed0abae1aa12e7c593f9cc576f5fb66e1","IMAGE_REOPODIGEST":"ghcr.io/nethesis/nethvoice@sha256:5ffffacfb28e2f61669d4a7c7d9afa331748422d10900881839923b4df524a37","IMAGE_URL":"ghcr.io/nethesis/nethvoice:0.0.1","MODULE_ID":"nethvoice2","MODULE_UUID":"d44c315e-9b13-4526-ac2d-b33f6c44aa7f","NODE_ID":"1","TCP_PORT":"20055","TCP_PORTS_RANGE":"20055-20087"},"is_rootfull":false,"module_id":"nethvoice2"},"extra":{},"id":"170af123-a653-40db-b6c4-6fda8ce944b3","parent":"01ebf395-d859-432a-9749-fec142206209"},"status":"completed","progress":100,"subTasks":[],"result":{"error":"<7>useradd -m -k /etc/nethserver/skel -s /bin/bash nethvoice2\n<7>extract-image ghcr.io/nethesis/nethvoice:0.0.1\nExtracting container filesystem imageroot to /home/nethvoice2/.config\nTotal bytes read: 8519680 (8.2MiB, 99MiB/s)\nimageroot/actions/\nimageroot/actions/configure-module/\nimageroot/actions/configure-module/20setenvs\nimageroot/actions/configure-module/30traefik\nimageroot/actions/configure-module/50users\nimageroot/actions/configure-module/60sip_proxy\nimageroot/actions/configure-module/71reports_api\nimageroot/actions/configure-module/72reports_ui\nimageroot/actions/configure-module/80start_services\nimageroot/actions/configure-module/validate-input.json\nimageroot/actions/create-module/\nimageroot/actions/create-module/05setenvs\nimageroot/actions/create-module/80process_notifier\nimageroot/actions/create-module/90firewall\nimageroot/actions/destroy-module/\nimageroot/actions/destroy-module/20destroy\nimageroot/actions/destroy-module/60sip_proxy\nimageroot/actions/destroy-module/90firewall\nimageroot/actions/get-configuration/\nimageroot/actions/get-configuration/20read\nimageroot/actions/get-configuration/validate-output.json\nimageroot/actions/restore-module/\nimageroot/actions/restore-module/20copyenv\nimageroot/actions/restore-module/21database\nimageroot/actions/restore-module/22asterisk\nimageroot/actions/restore-module/70configure_module\nimageroot/actions/restore-module/71reload_services\nimageroot/bin/\nimageroot/bin/adjust-services\nimageroot/bin/install-certificate\nimageroot/bin/module-cleanup-state\nimageroot/bin/module-dump-state\nimageroot/etc/\nimageroot/etc/state-include.conf\nimageroot/events/\nimageroot/events/certificate-updated/\nimageroot/events/certificate-updated/00validate_event\nimageroot/events/certificate-updated/20install_certificate\nimageroot/events/user-domain-changed/\nimageroot/events/user-domain-changed/20configure_ldap\nimageroot/systemd/\nimageroot/systemd/user/\nimageroot/systemd/user/asterisk.service\nimageroot/systemd/user/flexisip.service\nimageroot/systemd/user/freepbx.service\nimageroot/systemd/user/janus.service\nimageroot/systemd/user/mariadb.service\nimageroot/systemd/user/nethcti-server.service\nimageroot/systemd/user/nethcti-ui.service\nimageroot/systemd/user/phonebook-update.service\nimageroot/systemd/user/phonebook-update.timer\nimageroot/systemd/user/phonebook.service\nimageroot/systemd/user/redis-flexisip.service\nimageroot/systemd/user/reports-api.service\nimageroot/systemd/user/reports-redis.service\nimageroot/systemd/user/reports-scheduler.service\nimageroot/systemd/user/reports-scheduler.timer\nimageroot/systemd/user/reports-ui.service\nimageroot/systemd/user/tancredi.service\nimageroot/systemd/user/watcher.path\nimageroot/systemd/user/watcher.service\nchanged ownership of './events/certificate-updated/20install_certificate' from root:root to nethvoice2:nethvoice2\nchanged ownership of './events/certificate-updated/00validate_event' from root:root to nethvoice2:nethvoice2\nchanged ownership of './events/certificate-updated' from root:root to nethvoice2:nethvoice2\nchanged ownership of './events/user-domain-changed/20configure_ldap' from root:root to nethvoice2:nethvoice2\nchanged ownership of './events/user-domain-changed' from root:root to nethvoice2:nethvoice2\nchanged ownership of './events' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/watcher.path' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/nethcti-ui.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/flexisip.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/redis-flexisip.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/phonebook-update.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/watcher.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/reports-api.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/nethcti-server.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/asterisk.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/tancredi.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/janus.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/reports-scheduler.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/reports-ui.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/mariadb.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/freepbx.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/reports-scheduler.timer' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/phonebook-update.timer' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/reports-redis.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './systemd/user/phonebook.service' from root:root to nethvoice2:nethvoice2\nchanged ownership of './.imageroot.lst' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/destroy-module/20destroy' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/destroy-module/90firewall' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/destroy-module/60sip_proxy' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/destroy-module' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/configure-module/72reports_ui' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/configure-module/30traefik' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/configure-module/20setenvs' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/configure-module/50users' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/configure-module/80start_services' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/configure-module/60sip_proxy' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/configure-module/71reports_api' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/configure-module/validate-input.json' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/configure-module' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/get-configuration/20read' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/get-configuration/validate-output.json' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/get-configuration' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/create-module/80process_notifier' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/create-module/05setenvs' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/create-module/90firewall' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/create-module' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/restore-module/20copyenv' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/restore-module/21database' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/restore-module/22asterisk' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/restore-module/71reload_services' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/restore-module/70configure_module' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions/restore-module' from root:root to nethvoice2:nethvoice2\nchanged ownership of './actions' from root:root to nethvoice2:nethvoice2\nchanged ownership of './etc/state-include.conf' from root:root to nethvoice2:nethvoice2\nchanged ownership of './etc' from root:root to nethvoice2:nethvoice2\nchanged ownership of './state/environment' from root:root to nethvoice2:nethvoice2\nchanged ownership of './state/agent.env' from root:root to nethvoice2:nethvoice2\nchanged ownership of './bin/install-certificate' from root:root to nethvoice2:nethvoice2\nchanged ownership of './bin/module-cleanup-state' from root:root to nethvoice2:nethvoice2\nchanged ownership of './bin/module-dump-state' from root:root to nethvoice2:nethvoice2\nchanged ownership of './bin/adjust-services' from root:root to nethvoice2:nethvoice2\nchanged ownership of './bin' from root:root to nethvoice2:nethvoice2\ne4966c33e39a12e16860b9e5b6f2b975c4489d65e25451ced93a7093c069bdc6\n<7>systemctl try-restart promtail.service\n<7>loginctl enable-linger nethvoice2\n","exit_code":0,"file":"task/node/1/170af123-a653-40db-b6c4-6fda8ce944b3","output":{"redis_sha256":"9028c5c17fb84123084d0dbd969b84bf7b117d9f6086c687acd0447741b2001e"}}},{"context":{"action":"create-module","data":{"images":["ghcr.io/nethesis/nethvoice-mariadb:0.0.1","ghcr.io/nethesis/nethvoice-freepbx:0.0.1","ghcr.io/nethesis/nethvoice-asterisk:0.0.1","ghcr.io/nethesis/nethvoice-cti-server:0.0.1","ghcr.io/nethesis/nethvoice-cti-ui:0.0.1","ghcr.io/nethesis/nethvoice-tancredi:0.0.1","ghcr.io/nethesis/nethvoice-janus:0.0.1","ghcr.io/nethesis/nethvoice-phonebook:0.0.1","ghcr.io/nethesis/nethvoice-flexisip:0.0.1","docker.io/library/redis:7.0.10-alpine","ghcr.io/nethesis/nethvoice-reports-ui:0.0.1","ghcr.io/nethesis/nethvoice-reports-api:0.0.1"]},"extra":{},"id":"0b0febf4-d308-48fc-85d3-2431ee5c1f90","parent":"01ebf395-d859-432a-9749-fec142206209"},"status":"aborted","progress":0,"subTasks":[],"result":{"error":"Add to module/nethvoice2 environment NETHVOICE_MARIADB_IMAGE=ghcr.io/nethesis/nethvoice-mariadb:0.0.1\nAdd to module/nethvoice2 environment NETHVOICE_FREEPBX_IMAGE=ghcr.io/nethesis/nethvoice-freepbx:0.0.1\nAdd to module/nethvoice2 environment NETHVOICE_ASTERISK_IMAGE=ghcr.io/nethesis/nethvoice-asterisk:0.0.1\nAdd to module/nethvoice2 environment NETHVOICE_CTI_SERVER_IMAGE=ghcr.io/nethesis/nethvoice-cti-server:0.0.1\nAdd to module/nethvoice2 environment NETHVOICE_CTI_UI_IMAGE=ghcr.io/nethesis/nethvoice-cti-ui:0.0.1\nAdd to module/nethvoice2 environment NETHVOICE_TANCREDI_IMAGE=ghcr.io/nethesis/nethvoice-tancredi:0.0.1\nAdd to module/nethvoice2 environment NETHVOICE_JANUS_IMAGE=ghcr.io/nethesis/nethvoice-janus:0.0.1\nAdd to module/nethvoice2 environment NETHVOICE_PHONEBOOK_IMAGE=ghcr.io/nethesis/nethvoice-phonebook:0.0.1\nAdd to module/nethvoice2 environment NETHVOICE_FLEXISIP_IMAGE=ghcr.io/nethesis/nethvoice-flexisip:0.0.1\nAdd to module/nethvoice2 environment REDIS_IMAGE=docker.io/library/redis:7.0.10-alpine\nAdd to module/nethvoice2 environment NETHVOICE_REPORTS_UI_IMAGE=ghcr.io/nethesis/nethvoice-reports-ui:0.0.1\nAdd to module/nethvoice2 environment NETHVOICE_REPORTS_API_IMAGE=ghcr.io/nethesis/nethvoice-reports-api:0.0.1\n<7>podman-pull-missing ghcr.io/nethesis/nethvoice-mariadb:0.0.1 ghcr.io/nethesis/nethvoice-freepbx:0.0.1 ghcr.io/nethesis/nethvoice-asterisk:0.0.1 ghcr.io/nethesis/nethvoice-cti-server:0.0.1 ghcr.io/nethesis/nethvoice-cti-ui:0.0.1 ghcr.io/nethesis/nethvoice-tancredi:0.0.1 ghcr.io/nethesis/nethvoice-janus:0.0.1 ghcr.io/nethesis/nethvoice-phonebook:0.0.1 ghcr.io/nethesis/nethvoice-flexisip:0.0.1 docker.io/library/redis:7.0.10-alpine ghcr.io/nethesis/nethvoice-reports-ui:0.0.1 ghcr.io/nethesis/nethvoice-reports-api:0.0.1\nTrying to pull ghcr.io/nethesis/nethvoice-mariadb:0.0.1...\nGetting image source signatures\nCopying blob sha256:57be5c3395d74b92b125c84be4e7ca30ea17df9e4c436f7afacd5996e934a3f4\nCopying blob sha256:15eaa4f76d30bf3e5eef5cd8d3521d13a613e7081e9c9d6f0a3239383e574b6c\nCopying blob sha256:6b079b1646fb26c08add16ebb33c790ff74a7cb833ee219e1921a4903c16b18a\nCopying blob sha256:79a78e7d08912b17136f071a312d4d1f7193860c0b26650ffeefb100386bb0a3\nCopying blob sha256:f900cbafbed96021dcac39aa3b09ed558eb9650f4b6452aa3012572028e527a7\nCopying blob sha256:1dad4dcc8166000a324b77561a700411e2796cf7ee76f5d57d4a8aedabd00baf\nCopying blob sha256:b2cc3023549ed13826117879b8247b059be2b26cbb081abffda96070f0f51597\nCopying blob sha256:d63c25abf8cfaddfd3f9d4827a95ddccee88cdb161b01c0cbb1b12d02d938435\nCopying blob sha256:6f46b6497e36aa050555ed78a8126286dcb5b50defaedc961410322106f571e8\nCopying blob sha256:4c85255d41ceb279581627da42660f73cb64f5cb9fec3fb95dfbeb55f242e154\nCopying blob sha256:e93a069f1e2451b9af516ffc18ab2a1c5da13e6aa058cee12aa9d7c36cdf86d6\nCopying blob sha256:d82a9b8433e180e4c563eda6a095f9730d58549e83c768683fd202e90651dd3c\nCopying config sha256:1657b8c29c382ecc0710a30d51aee2d066800ed6977ff0027dd202230c0d8148\nWriting manifest to image destination\n1657b8c29c382ecc0710a30d51aee2d066800ed6977ff0027dd202230c0d8148\nTrying to pull ghcr.io/nethesis/nethvoice-freepbx:0.0.1...\nGetting image source signatures\nCopying blob sha256:be5b2dad98b12b7f9eddca3ce4d6af66ce99483fd78a7ca3b5c1a4290589530a\nCopying blob sha256:39e3d9efeaecd2d4cf12d51cd4e803ffcc3ca0c14dbfb00965b5c0e539186e91\nCopying blob sha256:56c44bef69b8e40afec9e3a00720162e6cd0dea7fbe47b68611049b0439aa377\nCopying blob sha256:6e7dcf557ed7efb8b48c18b67d09c227a0011dda132e30caac70856397e4288f\nCopying blob sha256:144b0ee7c81a2ce9800187d70ab0fbab2c28dc4dd17d52b4f9a8e13926122840\nCopying blob sha256:f9958846018c6fe706623efc70bb32fb876cf08667bf694639bf192119992c12\nCopying blob sha256:9d6bac6565a090a4683fabeacdca4a254558b88465f5591429428571277d5a5b\nCopying blob sha256:f7bd7f3dcacac07b0032538ce04cc9c890b618f0e62211cf8717c5d51e541937\nCopying blob sha256:573f91a5ef58c8ec0b2cc7854313f9fd6ecafe5562f8c16c38feed2963328aec\nCopying blob sha256:762c4a6412e15c0d5f8e9ec6d3a06aab031cf7056c925172ef5d189c88dc4a63\nCopying blob sha256:da3a88f6140c3a4bb127b23265e9ff8476aad83a57fc9497b3615c281a584313\nCopying blob sha256:7337b3e9d4d8d062b5f4809ef4301077799ac8dc8aa5078720abeb052dee6816\nCopying blob sha256:0f5c740b055da9faf14216777314410b1efaf3273c1b8695993a6394905b815e\nCopying blob sha256:dc08c62c313d53ae5848f30e2d81c88ecd5fba53bd657fb788e8426b1132f01a\nCopying config sha256:547835b2d12d4422e0c4ff2dad5600e770bd58bfaa8cfa2b0d59c3d3426244a0\nWriting manifest to image destination\n547835b2d12d4422e0c4ff2dad5600e770bd58bfaa8cfa2b0d59c3d3426244a0\nTrying to pull ghcr.io/nethesis/nethvoice-asterisk:0.0.1...\nGetting image source signatures\nCopying blob sha256:521bfb66ac4487c9962d8e20fbb7ab46aa45708ef6f2023ce6dc208777ca4361\nCopying blob sha256:b7c881a3bf2a0dc2fbde7d890088ac77af6b443df08f7dcc6e2116ca50e22d4c\nCopying blob sha256:dc42a7f8d67da58319a5573403477280e33079847b8c6f0a932a2ba34fe63a9e\nCopying blob sha256:72d220a1b442eeec3410898c5df64173a6c5e2e2334d4b7c413cd3fb946f2493\nCopying blob sha256:057d8bbfa91f38cefc85300507247751d57c1cad5beb13a7c08fe10cc5ed246d\nCopying blob sha256:0b2dc63a68b9b80b6e261e0c71119894a739d353f8263d6b2f1394c66a45f5af\nCopying blob sha256:fb0da86033df1db95612d4567ca3f32ac98ad97c1ff5ad2b698dfbba9da3935b\nCopying blob sha256:1b386f88b5811798924a62b3e0077ff73b0c66b5c7f81807a55363f83b657b6f\nCopying blob sha256:466b15ea743b240ddd984c2dc1e8d3d07db0564b43219ec047dc901ff1c35a82\nCopying blob sha256:32e6c609529c7c952462ef7e1c3785735d51b8ae066cee0d05128f67f947ea16\nCopying blob sha256:0486742426caa8f4f20f6b35ab18e84c37684a3371ced5151a55de9d73930e7e\nCopying blob sha256:1ffcf88582a4ab078feed32d4581126c83f48f458bb5bb8bcd63061a38f17eb7\nCopying blob sha256:a0516cb6898a563740016e868ce74dd6c264142e65bf0759fbbab9e95d58b2c5\nCopying blob sha256:0c7f01990d46a0a60796795ff6a4c79fed0bf534f2a1d8dea6ba1f473bd02044\nError: writing blob: adding layer with blob \"sha256:dc42a7f8d67da58319a5573403477280e33079847b8c6f0a932a2ba34fe63a9e\": processing tar file(write /usr/lib64/python3.6/xml/dom/minidom.py: no space left on device): exit status 1\nTraceback (most recent call last):\n File \"/usr/local/agent/bin/podman-pull-missing\", line 35, in <module>\n subprocess.run(['podman', 'pull', image_url]).check_returncode()\n File \"/usr/lib64/python3.11/subprocess.py\", line 502, in check_returncode\n raise CalledProcessError(self.returncode, self.args, self.stdout,\nsubprocess.CalledProcessError: Command '['podman', 'pull', 'ghcr.io/nethesis/nethvoice-asterisk:0.0.1']' returned non-zero exit status 125.\nTraceback (most recent call last):\n File \"/usr/local/agent/actions/create-module/05pullimages\", line 45, in <module>\n agent.run_helper('podman-pull-missing', *images).check_returncode()\n File \"/usr/lib64/python3.11/subprocess.py\", line 502, in check_returncode\n raise CalledProcessError(self.returncode, self.args, self.stdout,\nsubprocess.CalledProcessError: Command '('podman-pull-missing', 'ghcr.io/nethesis/nethvoice-mariadb:0.0.1', 'ghcr.io/nethesis/nethvoice-freepbx:0.0.1', 'ghcr.io/nethesis/nethvoice-asterisk:0.0.1', 'ghcr.io/nethesis/nethvoice-cti-server:0.0.1', 'ghcr.io/nethesis/nethvoice-cti-ui:0.0.1', 'ghcr.io/nethesis/nethvoice-tancredi:0.0.1', 'ghcr.io/nethesis/nethvoice-janus:0.0.1', 'ghcr.io/nethesis/nethvoice-phonebook:0.0.1', 'ghcr.io/nethesis/nethvoice-flexisip:0.0.1', 'docker.io/library/redis:7.0.10-alpine', 'ghcr.io/nethesis/nethvoice-reports-ui:0.0.1', 'ghcr.io/nethesis/nethvoice-reports-api:0.0.1')' returned non-zero exit status 1.\n","exit_code":1,"file":"task/module/nethvoice2/0b0febf4-d308-48fc-85d3-2431ee5c1f90","output":""}}],"validated":true,"result":{"error":"<7>podman-pull-missing ghcr.io/nethesis/nethvoice:0.0.1\n<7>extract-ui ghcr.io/nethesis/nethvoice:0.0.1\nExtracting container filesystem ui to /var/lib/nethserver/cluster/ui/apps/nethvoice2\nui/css/\nui/css/about~f71cff67.64a6b2de.css\nui/css/app~748942c6.722f2699.css\nui/i18n/\nui/i18n/en/\nui/i18n/en/translation.json\nui/i18n/it/\nui/i18n/it/translation.json\nui/img/\nui/img/nethvoice-logo.4288a1ee.svg\nui/index.html\nui/js/\nui/js/about~f71cff67.6da89031.js\nui/js/about~f71cff67.6da89031.js.map\nui/js/app~748942c6.cdd326e5.js\nui/js/app~748942c6.cdd326e5.js.map\nui/js/chunk-vendors~02576867.44c88c8d.js\nui/js/chunk-vendors~02576867.44c88c8d.js.map\nui/js/chunk-vendors~0605657e.7f254d6a.js\nui/js/chunk-vendors~0605657e.7f254d6a.js.map\nui/js/chunk-vendors~0f485567.a4fd29dc.js\nui/js/chunk-vendors~0f485567.a4fd29dc.js.map\nui/js/chunk-vendors~17faf02d.7f68aab6.js\nui/js/chunk-vendors~17faf02d.7f68aab6.js.map\nui/js/chunk-vendors~1d97ff09.290bda9d.js\nui/js/chunk-vendors~1d97ff09.290bda9d.js.map\nui/js/chunk-vendors~2a42e354.0df57e14.js\nui/js/chunk-vendors~2a42e354.0df57e14.js.map\nui/js/chunk-vendors~2aa62147.38204dba.js\nui/js/chunk-vendors~2aa62147.38204dba.js.map\nui/js/chunk-vendors~41d44f25.e7779fa1.js\nui/js/chunk-vendors~41d44f25.e7779fa1.js.map\nui/js/chunk-vendors~46852254.0b6d19c2.js\nui/js/chunk-vendors~46852254.0b6d19c2.js.map\nui/js/chunk-vendors~57473a66.f586d2ed.js\nui/js/chunk-vendors~57473a66.f586d2ed.js.map\nui/js/chunk-vendors~5bb1f863.3efba861.js\nui/js/chunk-vendors~5bb1f863.3efba861.js.map\nui/js/chunk-vendors~5eba3806.b8428291.js\nui/js/chunk-vendors~5eba3806.b8428291.js.map\nui/js/chunk-vendors~690b702c.fd888ae3.js\nui/js/chunk-vendors~690b702c.fd888ae3.js.map\nui/js/chunk-vendors~7274e1de.b9a8e23f.js\nui/js/chunk-vendors~7274e1de.b9a8e23f.js.map\nui/js/chunk-vendors~86f6b1bc.6953e08f.js\nui/js/chunk-vendors~86f6b1bc.6953e08f.js.map\nui/js/chunk-vendors~b5906859.deff14e4.js\nui/js/chunk-vendors~b5906859.deff14e4.js.map\nui/js/chunk-vendors~bc21d4b3.68b10b46.js\nui/js/chunk-vendors~bc21d4b3.68b10b46.js.map\nui/js/chunk-vendors~c8728516.dd1ccc58.js\nui/js/chunk-vendors~c8728516.dd1ccc58.js.map\nui/js/chunk-vendors~d2305125.6a99a4ff.js\nui/js/chunk-vendors~d2305125.6a99a4ff.js.map\nui/js/chunk-vendors~d9886323.1a1a66f6.js\nui/js/chunk-vendors~d9886323.1a1a66f6.js.map\nui/js/chunk-vendors~db300d2f.ddb8641c.js\nui/js/chunk-vendors~db300d2f.ddb8641c.js.map\nui/js/chunk-vendors~ec8c427e.5c1734c3.js\nui/js/chunk-vendors~ec8c427e.5c1734c3.js.map\nui/js/chunk-vendors~fdc6512a.81c5c86c.js\nui/js/chunk-vendors~fdc6512a.81c5c86c.js.map\nui/js/lang-en-translation-json~9b60384d.40489e67.js\nui/js/lang-en-translation-json~9b60384d.40489e67.js.map\nui/js/lang-it-translation-json~e043826f.4031e2b6.js\nui/js/lang-it-translation-json~e043826f.4031e2b6.js.map\nui/metadata.json\nui/shortcuts.json\n19115857ba217a10425a02ace9c5e4d0d7d928fb703331ee27e6dba71e9d9300\nAssertion failed\n File \"/var/lib/nethserver/cluster/actions/add-module/50update\", line 223, in <module>\n agent.assert_exp(create_module_result['exit_code'] == 0) # Ensure create-module is successful\n","exit_code":2,"file":"task/cluster/01ebf395-d859-432a-9749-fec142206209","output":""}}
TAsk Create Module
Error: writing blob: adding layer with blob "sha256:dc42a7f8d67da58319a5573403477280e33079847b8c6f0a932a2ba34fe63a9e": processing tar file(write /usr/lib64/python3.6/xml/dom/minidom.py: no space left on device): exit status 1
File "/usr/local/agent/bin/podman-pull-missing", line 35, in <module>
File "/usr/lib64/python3.11/subprocess.py", line 502, in check_returncode
File "/usr/local/agent/actions/create-module/05pullimages", line 45, in <module>
Remove the failed instance and try with a new one. There could be a download issue.
Sometimes public registries are really slow and download fails.
no matter trying to remove and adding, it refused, then finally, i was unable to remove any of the items, with some errors,
i did an update that was made available then,and finally my server broke, i can access cluster admin, but i can ssh into the server.
EDIT: weired enough, seems the seerver has run out of storage, not sure if it was because of multiple nethvoice installs that were failing.
does rm -rf these folders remove the said modules as well
After deleting those folders, i was able to run dnf upgrade, after which i rebooted the server to be able toa ccess the cluster admin, and it was a sucess.
I tried to install new core updates, and now its paused at 78% for a long time.
I noticed the nethvoice instaces are still installed, so i try to uninstall them, i only get an error, somethign went wrong
File "/var/lib/nethserver/cluster/actions/remove-module/50update", line 55, in <module>
destroy_module_result = agent.tasks.run(
File "/usr/local/agent/pypkg/agent/tasks/run.py", line 39, in run
results = runp([taskrq], **kwargs)
File "/usr/local/agent/pypkg/agent/tasks/run.py", line 50, in runp
return asyncio.run(_runp(tasks, **kwargs))
File "/usr/lib64/python3.11/asyncio/runners.py", line 190, in run
return runner.run(main)
File "/usr/lib64/python3.11/asyncio/runners.py", line 118, in run
return self._loop.run_until_complete(task)
File "/usr/lib64/python3.11/asyncio/base_events.py", line 653, in run_until_complete
return future.result()
File "/usr/local/agent/pypkg/agent/tasks/run.py", line 120, in _runp
return await asyncio.gather(*runners, return_exceptions=(len(tasks) > 1))
File "/usr/local/agent/pypkg/agent/tasks/run.py", line 127, in _run_with_protocol
return await run_redisclient(taskrq, **pconn)
File "/usr/local/agent/pypkg/agent/tasks/redisclient.py", line 77, in run_redisclient
await _task_submission_check_client_idle(rdb, taskrq, kwargs['check_idle_time'])
File "/usr/local/agent/pypkg/agent/tasks/redisclient.py", line 41, in _task_submission_check_client_idle
raise TaskSubmissionCheckFailed(f"Client \"{taskrq['agent_id']}\" was not found")
agent.tasks.exceptions.TaskSubmissionCheckFailed: Client "module/nethvoice3" was not found
Exception ignored in: <function StreamWriter.__del__ at 0x7f924538f060>
File "/usr/lib64/python3.11/asyncio/streams.py", line 396, in __del__
File "/usr/lib64/python3.11/asyncio/streams.py", line 344, in close
File "/usr/lib64/python3.11/asyncio/selector_events.py", line 860, in close
File "/usr/lib64/python3.11/asyncio/base_events.py", line 761, in call_soon
File "/usr/lib64/python3.11/asyncio/base_events.py", line 519, in _check_closed
RuntimeError: Event loop is closed
above is the error details
i am not sure if th error is as a result that i deleted the module folders from ssh, or if its as a result of the failed install from before.
i could attemtp this with a module that installed compeltely, so that as developers you could work out how to handlethis situation before prod.
Could we also have a way to update the core modules from the command line as opposed to only the admin page
After Playing too much woth the server, i think the server is broken, and now alot of things seem to be erratic and operating with errors and issues.
I have resolved to end this test and begin another test on the same, this will also be a new install based on RC1 and therefore, i expect fewer errors.
