Hi @mrmarkuz
With VirtualBox, I found the major error:
Exécution du scriptlet: sssd-client-2.8.2-2.el9.x86_64 270/974
Fatal glibc error: CPU does not support x86-64-v2
attention : %post(sssd-client-2.8.2-2.el9.x86_64) scriptlet échoué, état de sortie 127
Error in POSTIN scriptlet in rpm package sssd-client
Mise à jour de : sudo-1.9.5p2-9.el9.x86_64 271/974
Exécution du scriptlet: sudo-1.9.5p2-9.el9.x86_64 271/974
attention : %post(sudo-1.9.5p2-9.el9.x86_64) scriptlet échoué, état de sortie 127
What can I do with Virtualbox except switching to Proxmox???
Michel-André
mrmarkuz
(Markus Neuberger)
May 25, 2023, 8:13pm
2
You could try enabling “nested paging” in “System - Acceleration”, see also virtualbox.org • View topic - AVX and VirtualBox v6.1.18 r142142
Hi @mrmarkuz
I just tried “None” and doesn’t work.
Michel-André
mrmarkuz
(Markus Neuberger)
May 25, 2023, 8:28pm
5
@michelandre I moved it to a new thread.
I have a much more options available, I’m using phpVirtualBox 6.1-0:
Does your virtualbox host support virtualization and is it enabled in BIOS? Check out https://www.cyberciti.biz/faq/linux-xen-vmware-kvm-intel-vt-amd-v-support/
Hi @mrmarkuz
VirtualBox Version 6.1.38_Ubuntu r153438
$ grep --color vmx /proc/cpuinfo
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_good nopl cpuid aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm dca lahf_lm pti tpr_shadow dtherm
vmx flags : tsc_offset vtpr
I also have VirtualBox 7.0.8
On both Ubuntu and on Win-8.1, I have only one option to enable.
Michel-André
mrmarkuz
(Markus Neuberger)
May 25, 2023, 8:55pm
7
Which host processor is used?
Is virtualbox installed bare-metal or in a VM?
Did you install from ISO or image?
I use Virtual Box 6.1.36 (152435) on xigmanas (FreeBSD) and Virtual Box 7.0.6_SUSE r155176 (both bare-metal) and got Alma (should be no big difference to Rocky) working but I’m going to test Rocky…
In Virtual Box 7.0.6_SUSE r155176 I also have just one option.
Processor tab:
Hi @mrmarkuz
Not on bare metal, installed VirtualBox on Ubuntu-22.04 LTS
PRETTY_NAME="Ubuntu 22.04.2 LTS"
NAME="Ubuntu"
VERSION_ID="22.04"
VERSION="22.04.2 LTS (Jammy Jellyfish)"
# uname -a
Linux fred-kubuntu01-HP-xw6400-Workstation 5.15.0-72-generic #79-Ubuntu SMP Wed Apr 19 08:22:18 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
# /lib64/ld-linux-x86-64.so.2 --help
Subdirectories of glibc-hwcaps directories, in priority order:
x86-64-v4
x86-64-v3
x86-64-v2
I installed from ISO minimum and DVD
Options ar the same as mine.
Michel-André
EDIT: You might need minimum 2 processors. On some forum, some have error with just one CPU.
mrmarkuz
(Markus Neuberger)
May 25, 2023, 9:11pm
9
Good catch, did you try it?
Maybe try to import the vdi (in case there’s an issue regarding ISO/DVD installs):
There were similar issues with the Debian image in VMWare, please try a vmdk from here.
I tested converting the qcow image to vdi and it worked. I used a bridged virtual network adapter and could reach the cluster-admin page. If needed you can download the working vdi.
Hi @mrmarkuz
I tried with 1, 2, and 4.
On installation of Rocky-9.2, all same error: kernel panic.
I copied a working installation of Rocky-9.2 from Win-8.1 to Ubuntu 22.04 LTS and it gave also “kernel panic”
Michel-André
mrmarkuz
(Markus Neuberger)
May 25, 2023, 9:18pm
11
OK, so it works in virtualbox on Windows but doesn’t work in virtualbox in Ubuntu? So it’s an Ubuntu issue? Sorry for dumb questions, just to clarify…
Hi @mrmarkuz
I think it is not just on Ubuntu, I check many forum on different OS and many complained about “kernel panic” with VB or x86-64-v2.
Even with Proxmox, you have to set a parameter to “NONE ”, as you wrote somewhere, to have Rocky-9.2 to work.
I installed Rocky-8.8 on both Ubuntu and it works.
I found a link to upgrade Rocky-8.8 to 9.2 and after reboot => kernal panic.
While upgrading:
As I wrote before with:
x86-64-v4
x86-64-v3
x86-64-v2
Then, I think the CPU should support x86-64-v2.
Michel-André
mrmarkuz
(Markus Neuberger)
May 25, 2023, 9:56pm
13
I found a lot of forum threads but no solution, maybe this works?
I assume you chose Red Hat 9 (64-Bit) in the General/Basic settings:
Hi @mrmarkuz
I tried quite a few of them: Linux 2.4, Linux 2.6/3.x/4.x, Red Hat, and Other.
SSE4 was announced on September 27, 2006 => Then, I have some doubts. But I have to try…
Michel-André
mrmarkuz
(Markus Neuberger)
May 25, 2023, 10:53pm
15
I’m having doubts too but it was the only “solution” I found…
Use SSE4 to have other instructions like CPUID =>
This instruction was introduced by Intel in 1993 with the launch of the Pentium and SL-enhanced 486 processors.[1]
This reinforces my doubts !
Michel-André
mrmarkuz
(Markus Neuberger)
May 25, 2023, 11:14pm
17
You’re right, as said I have doubts too.
But the solution could be in changing the CPU to host-passthrough or something else like in Proxmox but I don’t know how
I’m going to test Rocky in vbox tomorrow…
Hi @mrmarkuz
After reading this link:
Now, I am a bit confused. Might be an interesting test to add SSE4 but where is the file to modify ?
Thank you so much for your help,
Michel-André
I found the command to do both 4.1.0 & 4.2.0:
VBoxManage setextradata VM-name VBoxInternal/CPUM/IsaExts/SSE4.1 0
VBoxManage setextradata VM-name VBoxInternal/CPUM/IsaExts/SSE4.2 0
I can not find the VM-name with the command:
VBoxManage list vms
The output is blank…
Michel-André
Hi @mrmarkuz
I managed to install both 4.1.0 & 4.2.0
# cd /media/fred-kubuntu01/VIRTUALBOX/Rocky92/
# pwd
# ls -als
total 104
4 drwx------ 3 fred-kubuntu01 fred-kubuntu01 4096 mai 26 18:48 .
4 drwxrwxrwx 11 root root 4096 mai 26 18:23 ..
4 drwx------ 2 fred-kubuntu01 fred-kubuntu01 4096 mai 26 18:47 Logs
4 -rw------- 1 fred-kubuntu01 fred-kubuntu01 4003 mai 26 18:48 Rocky92.vbox
4 -rw------- 1 fred-kubuntu01 fred-kubuntu01 4003 mai 26 18:48 Rocky92.vbox-prev
84 -rw------- 1 fred-kubuntu01 fred-kubuntu01 2097152 mai 26 18:48 Rocky92.vdi
# VBoxManage registervm /media/fred-kubuntu01/VIRTUALBOX/Rocky92/Rocky92.vbox
# VBoxManage list vms
"Rocky92" {4f573c5e-0269-45c7-b551-f80111329e5a}
# VBoxManage setextradata Rocky92 VBoxInternal/CPUM/IsaExts/SSE4.1 0
# VBoxManage setextradata Rocky92 VBoxInternal/CPUM/IsaExts/SSE4.2 0
Still kernel panic .
I have no more ideas…
Michel-André
Setting those to 0 disables the parameters.
I tried 1 and still “kernel panic”
Michel-André
mrmarkuz
(Markus Neuberger)
May 27, 2023, 12:19am
20
I couldn’t reproduce it.
Rocky 9.2 is working here with Virtualbox on:
xigmanas/FreeBSD 12, Intel Celeron G1610T
OpenSUSE 15.4 Leap, Intel Core i3-8100
Ubuntu 22.04.2, Intel Core i7-8750H
I just created a new virtual machine, respected the minimum requirements , set network to bridged, kept the hard disk on the SATA (IDE should work too) controller and installed from IDE ISO, setup network, installed NS8 and created the cluster.
