Should i remove the lvt.liv domain ?
That looks all correct, but those are ājustā mail domains, not where the users come from (Thatās the account provider part!).
And that link is probably missing, or not correctly initialized.
Result: postfix has no real users in itās aliases fileā¦
Maybe @mrmarkuz still has access to a working NS7 where the link can be verifiedā¦
Not really. Thats for systems which must report, but do not run mail themselvesā¦
Letās check the mail domain settings:
db domains show
Are the users available on the Users and Groups page?
Yes, but no external account provider to Win2019 yet.
I am downloading an NS 8, will spin up a new one and create a new AD (not jointo existing MS2019)
This may helpā¦
Good Luck!
Sorry, Iām a whole day out of officeā¦
Yes thank you Andy, I have the NS 8 qcow image downloaded for Proxmox just uploading the disk.
Iāld install it myself !
I have NS 8 up and running with a cluster configured I think, but where is the network, is it a different web login to administer the node?
You MUST use https:// IP or FQDN /cluster-admin/
(The trailing slash is important!)
Then login as (Cluster-) admin with the fefault password of Nethesis,1234.
A password change is mandatory.
See here:
https://docs.nethserver.org/projects/ns8/en/latest/install.html
There is no āadministrationā for the node. There is only a cluster admin.
You can install cockpit, as used in NS7 for the node, but thatās additional.
What will you change?
I would like to change the IP address, do I have to do it in the shell with nano or can I do it in the gui?
I think you have to do this in network settings of the underlying OS.
https://docs.nethserver.org/projects/ns8/en/latest/os_network.html#os-network-section
If your OS is Rocky 9, you can change the ip with the Networkmanager TUI, i think.
OK thanks got it with nmtui edit
Anyone know how to ger roundcube working ? Itās the only webmail I see in software for NS8 ?
There is also SOGo and Webtop. Both are groupwares. I personally use SOGo. But first you have to install and set up the mail server. Then you can install Roundcube and connect to the mail server.
Yes the mailserver is installed and have 2 users with email addresses I can telnet to port 25 ok, I also have roundcubemail installed but cant seem to log on to it. donāt see SOGo or is that pre installed?
I see webtop, I try installing that now.
