Hello,
First step, I have installed, NethServer on ESXI machine in OVH (NethServer ISO, default install).
Second step, first problem: I launch the NethServer VM and there is a message with network problem.
The problem is not new: Neth 7 Networking Problems with OVH Custom ip rules.
Do you have the solution for this problem?
Docs with CentOS configuration:
- Configuring a network bridge | OVH Guides
- VMware ESXI: https://support.us.ovhcloud.com/hc/en-us/articles/360002175944-How-to-Connect-a-VM-to-the-Internet-Using-VMware-ESXi
- Proxmox VE: https://support.us.ovhcloud.com/hc/en-us/articles/360002394324-How-to-Connect-a-VM-to-the-Internet-Using-Proxmox-VE
I think that the problem exist for Proxmox VE too.
First manual solution (not the best, it is not automatic):
I have edited: vi /etc/sysconfig/network-scripts/ifcfg-ensXXX (personal data has been replaced by GATEWAY_IP / IP_FAILOVER / VIRTUAL_MAC) instead of default settings:
DEVICE=ensXXX
BOOTPROTO=none
GATEWAY=GATEWAY_IP
IPADDR=IP_FAILOVER
NETMASK=255.255.255.255
NM_CONTROLLED=no
ONBOOT=yes
TYPE=Ethernet
USERCTL=no
IPV6INIT=no
PEERDNS=yes
ARP=yes
HWADDR=VIRTUAL_MAC
And I have created: vi /etc/sysconfig/network-scripts/route-ensXXX:
GATEWAY_IP dev ensXXX
default via GATEWAY_IP dev ensXXX
Next steps:
ifdown ensXXX
ifup ensXXX
Good, now it works on https://IP_FAILOVER:9090/.
But, there is a another problem after first connection, the FQDN must to be changed by NethServer.
I have changed it: Result, the connection is now lost (no ping, nothing) and network configuration is now by default (before my settings which work).
PS: in /etc/hosts, there an IP address that I have never selected:
192.168.1.1 fqdn hostname
