I have installed NethServer in Virtualbox but I am having problems accessing the web-admin interface from host.
I followed this tutorial but it didn’t help. I know it is for version 6.7 but I thought the internet settings would not differ.
So I set the Network adapter as bridged/eth0 and the second as Internal Network/intnet. When the installation is finished I switch the second adapter to Host Only/Vboxnet0.
The host Opensuse Leap 42.2 is connected to the internet through ethernet.
The Firewall on Host is stopped. I am not sure if there is a Firewall on NethServer guest by default.
To check if everything was ok on my end I installed Zentyal 5. But here I left Internal Network/intnet. I did not switch to Host only.
After stopping the Firewall on Zentyal all connections were ok in host and in guest.
Is there a Firewall feature in NethServer by default? Something that might be stopping the host from connecting to the web-admin interface
I am new to this so I would appreciate simple terminology.
Hi Christos
I’m a newbie to Nethserver myself, but have just done a similar thing to you installing NS on VirtualBox and have it set up at the moment. If you want to compare any settings, processes running etc, I’d be happy to post whatever you want from my system.
I’d suggest (just to keep it simple) you do the install with just a single LAN interface and get that running before adding an extra interface.
Dave
So you mean instead of using both ethernet and wireless use just one of them?
Interesting, I wonder if that’s the reason. I thought that even if I have both only one is used at a time.
I will try reinstalling.
Yes, I would appreciate it if you could send over any settings you had when you installed. Especially the network ones. Did you have only one LAN and then you set the network to bridged (eth0 or wlan0)?
On the network configuration during the installation did you change anything?
And also did you enable PAE/NX on the processor settings? I don’t think that has to do with the network but I read somewhere that it helps.
Hi Ctek, I installed following the tutorial. I used two adapters. But it didn’t work. I wonder if it was because I had two LAN interfaces.
Since that tutorial has worked for others what I will do is reinstall with both adapters but having just one LAN interface. I will just use the ethernet.
