Thank you @Neustradamus for pointing this out. It is highly appreciated you make us all aware of these points.
You might have noticed it is not possible anymore to open new bugs on github for the nethserver project. This has been done to avoid discussion on multiple places. We would like to invite you to do the discussion here on our forums. Please tell us here what you have found and what you think is necessary to fix the problem.
The technical progress will be mentioned on Github, but, again, discussion is preferably here in our forums.
Thx again for your activity and additions. Please continue to point out problems and possible enhancements.
I have: “This topic is unlisted; it will not be displayed in topic lists, and can only be accessed via a direct link”
I will publish remarks/questions/problems/features here.
It is really hard to speak with team.
In feature part:
There is a problem, I can not publish a message in feature:
“Sorry you cannot post a link to that host.”
-> I can not link to github ticket, software links…
For some reason the forum software marked your topic for review. I cleared the topic so it is listed now.
I had a look at your account and gave you a bit more clearance for the forums. You should be able to post links now.
And thank you again for contributing with patches.
Give us some time to review them. I’m working on a feature discussed one month ago
The forum platform sets some reasonable limits for newcomers to prevent abuses. Please be patient and consider also that people needs time to reply with a good answer.
This is important to improve the value of our discussions.
