How to make /etc/sysconfig/network/route-eth0 static
Hello,
I have a nethsever on my VMWare ESXI with OVH failover IP. Because of the infrastructure of OVH an static route is required. How can i make the above file stick in the filesystem?
Regards,
Jan
Just create all needed routes from the “Static route page”
Thanx Giacomo, i will try!
I’ve tried it but it is giving me a lot of trouble. The problem is that the moment i change anything in the static route, the whole machine becomes unreachable.
The static route has to be: (route-eth0)
xxx.xxx.xxx.254 dev eth0
default via xxx.xxx.xxx.254 dev eth0
Is there any other way to get this working?
Do you have a link to OVH documentation?
I may have a custom template to add support for this kind of setup.
Hi @filippo_carletti,
The link to the OVH documentation BridgeCLient
Thanks in advance.
You need to create an action and link it to the static-routes-save event.
Here’s an example (adjust GATEWAY_VM and/or ethX) of what to write in /etc/e-smith/events/actions/ovh-route
#!/bin/sh
GATEWAY_VM=1.2.3.4
cat <<EOF >>/etc/sysconfig/network-scripts/route-eth0
$GATEWAY_VM dev eth0
default via $GATEWAY_VM dev eth0
EOF
Then link the action:
ln -sf ../actions/ovh-route /etc/e-smith/events/static-routes-save/S33ovh-route
If someone has an idea on how to integrate this “strange” setup in the default NethServer configuration, I’ll try to create a patch.
Thank u very much! It’s working like a charm.
Currently, this bug is always here, rules are removed after configuration changes…
You can see:
I can’t test my solution, but I trust feedback.
Could you give me access to a system where the problem is not fixed by my solution?
Thank you @ElKorbo for your support.
I applied my fix above and I think it’s working as expected.
Could you please confirm?
@filippo_carletti; Thanks for your intervention.
I have sent you an email, I have updated your script but in the test VM, it had not done because there are a lot of problems to see before, look here:
I have specified you the steps (but it does not work in Cockpit, look all screenshots which show you errors) in previous links.
The goal is to integrate without any commands for users (installer, and cockpit)
Recall, 2 weeks ago: I have done several tests, I give you the process:
1/ Bug with Cockpit Dashboard Network: Impossible to select the good IP Address / Netmask / Gateway ( Validation failed: IP address can't be the network or broadcast address. ) and other options (there is only IP address / Netmask / Gateway / Label (optional)).
2/ Bug with the core: The /etc/sysconfig/network-scripts/route-ensXX1 manually route file is removed, I have found to add a “manual” action but it must be “automatic”.
In ESXI, for the NethServer VM:
2 virtual network cards, one for WAN with MAC Address, one for LAN.
Install NethServer “without connection”, after it, connect with root account in console.
WAN:
db networks set ensXX1 ethernet role red hwaddr AB:CD:EF:GH:IJ:KL
 ipaddr XXX.XXX.XXX.XXX netmask 255.255.255.255 gateway YYY.YYY.YYY.254
 onboot yes bootproto none nm_controlled no userctl no
 ipv6init no peerdns no arp yes
 name ensXX1 defroute yes
signal-event interface-update
LAN:
db networks set ensXX2 ethernet role green
 ipaddr 192.168.1.1 netmask 255.255.255.0 gateway 192.168.1.254
 name ensXX2
There is a problem: ip route show:
default via 192.168.1.254 dev ensXX2
192.168.1.0/24 dev ensXX2 proto kernel scope link src 192.168.1.1
It is in the code:
I have done for ensXX1 configuration: defroute yes .
Now, I must to create an action, the ip route del default must not be in this file…
vi /etc/e-smith/events/actions/ovh-route
#!/bin/bash
GATEWAY_VM=YYY.YYY.YYY.254
INTERFACE=ensXX1
cat > /etc/sysconfig/network-scripts/route-$INTERFACE << EOF
$GATEWAY_VM dev $INTERFACE
default via $GATEWAY_VM dev $INTERFACE
EOF
ln -sf /etc/e-smith/events/actions/ovh-route /etc/e-smith/events/static-routes-save/S33ovh-route
chmod 0554 /etc/e-smith/events/static-routes-save/S33ovh-route
chown root:root /etc/e-smith/events/static-routes-save/S33ovh-route
ip route show:
default via YYY.YYY.YYY.254 dev ensXX1
YYY.YYY.YYY.254 dev ensXX1 scope link
First Cockpit Dashboard connection:
→ FQDN
→ Organization settings
→ Updates
Could you please provide a diff or a pull request?
Code is easier to read for me, thank you.
It is not the first problem, the first problem is always here:
Please read all my messages, I will not repeat always same texts all times…
I think that you must to find a good solution to do not use “ip route del default” in the script.
But it is only a part of the solution, always all other specified problems.
Here for the route script, of course “GATEWAY_VM” and “INTERFACE” values must be auto detected.
#!/bin/bash
INTERFACE=ensXX1
EOF
@filippo_carletti, @giacomo: I do not find the solution after several weeks of patience.
Can you solve it?
In mire @Jan_Runhart, @lorentedford has same problem too…
I’m sorry, I was waiting for your pull request.
