Information
Feature request: NxFilter for NethServer
This howto is for testing the DNS webfilters. Do not use in production.
Maybe we could improve it together. Please test and give feedback…
Installation
Get docker repo and install and enable nethserver-docker:
cd ~
wget https://download.docker.com/linux/centos/docker-ce.repo -O /etc/yum.repos.d/docker-ce.repo
yum -y install https://mrmarkuz.goip.de/mirror/mrmarkuz/7/noarch/nethserver-docker-0.0.0-1.7.gaaa415f.ns7.noarch.rpm
config setprop docker status enabled
signal-event nethserver-docker-update
Firewall
For testing purposes I decided to open the docker network by policy. In a production environment you should leave this step and set firewall rules.
mkdir -p /etc/e-smith/templates-custom/etc/shorewall/policy
cp /etc/e-smith/templates/etc/shorewall/policy/35aqua /etc/e-smith/templates-custom/etc/shorewall/policy/
cat << 'EOF' > /etc/e-smith/templates-custom/etc/shorewall/policy/35aqua
# 35aqua -- the Docker network policy
aqua net ACCEPT
$FW aqua ACCEPT
aqua $FW ACCEPT
loc aqua ACCEPT
EOF
signal-event firewall-adjust
Download and start containers
Install nxfilter and/or pihole to test them.
Edit TZ=Europe/Vienna to match your timezone:
Nxfilter
docker run -d --name nxfilter -v nxfilter-conf:/nxfilter/conf -v nxfilter-log:/nxfilter/log -v nxfilter-db:/nxfilter/db -e TZ=Europe/Vienna --net=aqua --restart=unless-stopped packetworks/nxfilter-base:latest
Pihole
docker run -d --name pihole -e TZ="Europe/Vienna" -e WEBPASSWORD="admin" -v "$(pwd)/etc-pihole/:/etc/pihole/" -v "$(pwd)/etc-dnsmasq.d/:/etc/dnsmasq.d/" --cap-add NET_ADMIN --net=aqua --restart=unless-stopped pihole/pihole:latest
Portainer
Browse to https://YOURNETH:980/portainer, setup admin username/password and select Local.
Now you can manage the containers via web UI.
Check the IPs of your machines, if you installed in a different order they may differ. In this howto 172.28.0.2 is the nxfilter, 172.28.0.3 is the pihole.
General rules for adding more docker containers
- don’t publish ports
- put the containers to aqua network
- set restart to policy to unless-stopped
Configuration
Nxfilter
Browse to http://172.28.0.2/admin and login with admin, password: admin
You may need to set upstream DNS:
NxFilter supports LDAP/AD and much more…
Pihole
Browse to http://172.28.0.3/admin and login with password: admin
Client access
You may use a static route on the internet gateway for the aqua network to go to the docker machine. This way all clients should be able to access it.
Scenarios
Clients use filter DNS
The clients use the DNS server of a webfilter. They may get the DNS server to use from Nethserver DHCP.
This webfilter uses the Nethserver as upstream DNS.
The Nethserver uses an outside upstream DNS like 8.8.4.4 (google).
This way the filter gets the client IP and you can see it in the logs. Nxfilter for instance can map the IP to AD/LDAP users.
Nethserver uses webfilter as upstream DNS
In this case the filter only gets the IP of the Nethserver and has no information who is surfing but blocks ads and more.
Clients use Nethserver proxy
You need to set the Nethserver upstream DNS to one of the filters. Now when clients use the proxy the DNS filter is involved.
Cascading
You may use more filters for testing. One filter uses the next one as upstream DNS. The last filter uses Nethserver as upstream DNS.
ToDo
- Testing
- More secure firewall
- Using rootless podman containers - I already tried but no success
