nethserver-pihole is a module now
Thank you for this Wiki-Article.
I am taking my first steps with Docker and trying to install Pihole.
- Iinstalled Docker
- activated standard repository
- Portainer is accessible via Web-Gui
- set up Macvlan
- tried to create the container for pihole within my Macvlan
My Qurstion
Where within the Wiki-Article is documented the installation of the pihole scripts?
https://wiki.nethserver.org/doku.php?id=pihole#create_the_container
I can find only steps to…
- show the config
- change the admin password
- set up upstrem DNS Server
- check docker pihole is up
in my case
[root@DAHO-Nethserver ~]# docker ps
f18aea56d211 portainer/portainer-ce “/portainer -H unix:…” 57 minutes ago Up 24 minutes 8000/tcp, 9000/tcp, 9443/tcp portainer
Between these steps I assume and miss the installation of the pihole scripts.
Within Portainer I also cannot find a pihole container.
This allows only one conclusion: if you follow the instructions, something is missing that is necessary to create the container.
Sincerley, MArko
ps.:
[root@DAHO-Nethserver ~]# config show pihole
pihole=configuration
DNS1=192.168.3.1
DNS2=192.168.3.20
PhpMemoryLimit=512M
mac=00:60:2f:6c:be:19
password=####
piholeAquaIP=172.28.45.1
piholeMacVlanIP=192.168.3.225
piholeNetwork=macvlan
timezone=UTC
[root@DAHO-Nethserver ~]# pihole start
# pihole start
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
Error: failed to start containers: pihole
i think this does it, yum install nethserver-pihole --enablerepo=stephdl
at the begining of the wiki
[root@DAHO-Nethserver ~]# yum install nethserver-pihole --enablerepo=stephdl
- sb-base: u3.nethserver.com
- sb-centos-sclo-rh: u3.nethserver.com
- sb-centos-sclo-sclo: u3.nethserver.com
- sb-epel: u3.nethserver.com
- sb-extras: u3.nethserver.com
- sb-nethserver-base: u3.nethserver.com
- sb-nethserver-updates: u3.nethserver.com
- sb-updates: u3.nethserver.com
stephdl: mirror.de-labrusse.fr
docker-ce-stable | 3.5 kB 00:00:00
Package nethserver-pihole-1.0.1-1.ns7.noarch already installed and latest version
Nothing to do
signal-event nethserver-pihole-update
then
docker ps
I think the easier now is to use aqua and trust it
I rolled back my VM and repeated the installtion.
# yum install nethserver-pihole –enablerepo=stephdl
# config setprop docker macVlanGateway 192.168.3.1 macVlanLocalNetwork 192.168.3.0/24 macVlanNetwork 192.168.3.224/27 macVlanNic br0
# signal-event nethserver-docker-update
# config setprop pihole piholeNetwork macvlan piholeMacVlanIP 192.168.3.225
# config setprop pihole DNS1 192.168.3.20 DNS2 192.168.3.1
# signal-event nethserver-pihole-update
Now the container exists
181701480cc3 pihole/pihole:latest “/s6-init” 27 seconds ago Up 7 seconds (health: starting) pihole
f18aea56d211 portainer/portainer-ce “/portainer -H unix:…” About an hour ago Up 2 minutes 8000/tcp, 9000/tcp, 9443/tcp portainer
Thank you.
from time to time, think to update the container (you will see the warning inside the UI) : pihole upgrade
After some experiences I want to remove pihole and docker. I cannot find any documentation.
Do you have instructions for me?
Sincerely, Marko
docker rm pihole
docker rm portainer
yum remove nethserver-pihole nethserver-docker docker-ce
I did yum autoremove nethserver-pihole –enablerepo=stephdl before.
Sincerely, Marko
A request because I am unsure…
Is the configured network (Aqua, Aeria, Macvlan) also removed?
ip a is your friend
be sure to restart the server eventually
not removed
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master br0 state UP group default qlen 1000
link/ether 2a:d0:95:1b:3e:62 brd ff:ff:ff:ff:ff:ff
inet6 fe80::28d0:95ff:fe1b:3e62/64 scope link
3: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.3.20/24 brd 192.168.3.255 scope global br0
4: vb-nsdc@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
link/ether 9e:84:6b:2b:df:25 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::9c84:6bff:fe2b:df25/64 scope link
5: aqua0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
link/ether 02:42:92:db:06:66 brd ff:ff:ff:ff:ff:ff
inet 172.28.0.1/16 brd 172.28.255.255 scope global aqua0
inet6 fe80::42:92ff:fedb:666/64 scope link
6: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:65:65:66:2a brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
8: vetheb0870f@if7: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master aqua0 state UP group default
link/ether fa:1d:7b:44:03:e3 brd ff:ff:ff:ff:ff:ff link-netnsid 1
inet6 fe80::f81d:7bff:fe44:3e3/64 scope link
10: macvlan0@br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 32:22:a6:8c:25:51 brd ff:ff:ff:ff:ff:ff
inet 192.168.3.224/27 scope global macvlan0
inet6 fe80::3022:a6ff:fe8c:2551/64 scope link
I assume you can live with or if you want to remove docker0, aqua and macvlan like you can see docker created them, I assume that docker can delete them
I removed docker and learned the danger of yum autoremove…
Package Arch Version Repository Size
Removing:
docker-ce x86_64 3:20.10.10-3.el7 @docker-ce-stable 96 M
nethserver-docker noarch 1.0.13-1.ns7 @nethforge 58 k
Removing for dependencies:
certbot noarch 1.11.0-2.el7 @sb-epel 104 k
container-selinux noarch 2:2.119.2-1.911c772.el7_8 @sb-extras 41 k
containerd.io x86_64 1.4.11-3.1.el7 @docker-ce-stable 108 M
dante x86_64 0.5.1-1.ns7 @sb-nethserver-updates 91 M
docker-ce-cli x86_64 1:20.10.10-3.el7 @docker-ce-stable 139 M
docker-ce-rootless-extras x86_64 20.10.10-3.el7 @docker-ce-stable 20 M
docker-scan-plugin x86_64 0.9.0-3.el7 @docker-ce-stable 13 M
fuse-overlayfs x86_64 0.7.2-6.el7_8 @sb-extras 116 k
fuse3-libs x86_64 3.6.1-4.el7 @sb-extras 270 k
libcgroup x86_64 0.41-21.el7 @nethserver 134 k
nethserver-backup-config noarch 2.5.2-1.ns7 @sb-nethserver-updates 127 k
nethserver-backup-data noarch 1.7.6-1.ns7 @nethserver-updates 169 k
nethserver-base noarch 3.9.0-1.ns7 @sb-nethserver-updates 675 k
nethserver-cgp noarch 2.4.1-1.ns7 @sb-nethserver-updates 567 k
nethserver-cockpit noarch 1.10.6-1.ns7 @sb-nethserver-updates 3.0 M
nethserver-collectd noarch 3.1.1-1.ns7 @nethserver 39 k
nethserver-dante noarch 1.0.6-1.ns7 @sb-nethserver-updates 1.9 M
nethserver-dc x86_64 1.8.2-1.ns7 @sb-nethserver-updates 15 M
nethserver-dnsmasq noarch 1.7.2-1.ns7 @nethserver 93 k
nethserver-dokuwiki noarch 1.3.3-1.ns7.sdl @stephdl 345 k
nethserver-duc noarch 1.7.0-1.ns7 @nethserver 212 k
nethserver-firewall-base noarch 3.17.2-1.ns7 @sb-nethserver-updates 332 k
nethserver-firewall-base-ui noarch 3.17.2-1.ns7 @sb-nethserver-updates 9.1 M
nethserver-hosts noarch 1.2.2-1.ns7 @nethserver 65 k
nethserver-httpd noarch 3.12.2-1.ns7 @sb-nethserver-updates 5.6 M
nethserver-httpd-admin noarch 2.7.0-1.ns7 @nethserver-base 5.2 M
nethserver-httpd-admin-service noarch 2.7.0-1.ns7 @nethserver-base 7.6 k
nethserver-httpd-virtualhosts noarch 3.12.2-1.ns7 @sb-nethserver-updates 100 k
nethserver-lsm noarch 1.2.4-1.ns7 @nethserver-updates 38 k
nethserver-mail-smarthost noarch 2.31.4-1.ns7 @sb-nethserver-updates 78 k
nethserver-net-snmp noarch 1.1.0-1.ns7 @nethserver-base 37 k
nethserver-netdata noarch 2.0.2-1.ns7 @sb-nethserver-updates 38 k
nethserver-ntopng noarch 3.1.2-1.ns7 @nethserver-updates 3.6 M
nethserver-ntp noarch 1.1.3-1.ns7 @nethserver 54 k
nethserver-openssh noarch 1.8.0-1.ns7 @nethserver 51 k
nethserver-phonehome noarch 1.4.0-1.ns7 @nethserver 41 k
nethserver-php noarch 1.3.0-1.ns7 @nethserver 35 k
nethserver-postgresql noarch 1.1.0-1.ns7 @nethserver-base 38 k
nethserver-restore-data noarch 2.0.7-1.ns7 @sb-nethserver-updates 2.9 M
nethserver-smartd noarch 1.1.0-1.ns7 @nethserver 34 k
nethserver-sssd noarch 1.7.1-1.ns7 @nethserver-updates 318 k
nethserver-subscription noarch 3.6.8-1.ns7 @nethserver-updates 88 k
nethserver-subscription-ui noarch 3.6.8-1.ns7 @nethserver-updates 59 k
nethserver-vsftpd noarch 1.1.1-1.ns7 @nethserver-base 53 k
nethserver-zabbix noarch 0.0.1-10.ns7 @mrmarkuz 6.3 M
policycoreutils-python x86_64 2.5-34.el7 @nethserver 1.2 M
slirp4netns x86_64 0.4.3-4.el7_8 @sb-extras 169 k
Fortunately I was able to cancel.
yum remove... does the job.
The networks still exist… a reboot helps and the networks are gone.
