Guacamole 1.3.0 testing
:+1:
Yes, also fullname (displayname) for example.
No, Guacamole just goes through the user base dn using the ldap-user-search-filter so computer names or group names are not possible yet, except maybe if you change the search filter.
ldap-user-base-dn: cn=Users,dc=ad,dc=domain,dc=tld
ldap-user-search-filter: (&(objectClass=top)(objectClass=user)(objectClass=person)(objectClass=organizationalPerson))
The reminds me of how I can filter what groups can log into Nextcloud by defining those variables in the LDAP query. For my use case, I tie my defined connections in Guacamole to SAMBA-AD groups to define access at scale.
New default values for the login:
AD: samaccountname,userprincipalname
LDAP: uid,mail.
So one can login with username or username@serverdomain.tld.
The username attribute can now be set in the config database.
In this example only full name logins are allowed.
AD:
config setprop guacd usernameAttribute displayname
LDAP:
config setprop guacd usernameAttribute gecos
To remove the attribute and go back to default:
config setprop guacd usernameAttribute ''
Apply the changes:
signal-event nethserver-guacamole-update
Installation:
yum -y install https://mrmarkuz.dynu.net/mirror/devtest/nethserver-guacamole-0.0.1-3.ns7.noarch.rpm
If you already installed the testing package you need to reinstall:
yum -y reinstall https://mrmarkuz.dynu.net/mirror/devtest/nethserver-guacamole-0.0.1-3.ns7.noarch.rpm
Tested by updating exisiting 1.3 install and can confirm that both user1 & user1@domain.tdl work as described against SAMBA/AD.
EDIT/Update - Odd behavior but I thought I’d post it here. Initially to set up the guacamole LDAP I created a local user1 with group 1 in SAMBA-AD & Guacamole. I also created another user1 within Guacamole with a different password than SAMBA-AD that helped me verify the LDAP vs local login was actually working. After the update, I tested user1@domain.tdl and was able to login as expected. What I found odd is that Guacamole treated the SAMBA-AD logins of user1 & user1@domain.tdl as separate and different accounts with different permissions applied.
Second feature request if we are in the charitable giving season. How difficult would it be to add 2 Cockpit items for Guacamole?
  1. Add a Guacamole Tab within Cockpit like SOGo with a Settings & Logs section
  2. Under Settings - Ability to set vhost name via Cockpit - Guacamole akin to the SOGo module
It’s a shame that I didn’t learn enough about cockpit yet but I’ll have a look at it…
Is there anything else that you would like help with testing out before we can push this live?
It would be nice to have a solution for this Mac issue but unfortunately I have no Mac to play around with.
@Andy_Wismer wanted to do some testing (with Mac) too.
I guess we can push it live this week.
@mrmarkuz
I’m doing a restore of my Home NS - for another reason. But if it finishes timely, I’ll do the Guac test tonight…
I use a Microsoft AD which Nethserver is joined to:
In Guacamole I set:
config setprop guacd ldapPort 389
config setprop guacd Encryption none
I have several problems:
  1. The bind entry in /etc/guacamole/guacamole.properties is generated the wrong way. It reads ldap-search-bind-dn: cn=CN=Administrator,OU=Users,OU=MyBusiness,DC=MYDOMAIN,DC=LOKAL,cn=Users,DC=myadmin,DC=LOKAL instead of CN=Administrator,OU=Users,OU=MyBusiness,DC=MYDOMAIN,DC=LOKAL
  2. I see no users in Guacamole
  3. I cannot login with AD users.
    WARN o.a.g.r.auth.AuthenticationService - Authentication attempt from [192.168.42.52, 127.0.0.1] for user “xy” failed.
It looks like a CN in a CN, weird…
Which Windows server version (the DC) do you use? I’ll try to reproduce…
Maybe your binddn is not in user@domain.tld format?
config show sssd
AdDns=192.168.xx.yy
BaseDN=DC=mydomain,DC=LOKAL
BindDN=CN=Administrator,OU=Users,OU=MyBusiness,DC=MYDOMAIN,DC=LOKAL
BindPassword=xxx,
DiscoverDcType=dns
GroupDN=OU=Groups,OU=MyBusiness,DC=mydomain,DC=lokal
LdapURI=ldap://hal9001.straightec.lokal
Provider=ad
Realm=MYDOMAIN.LOKAL
ShellOverrideStatus=enabled
StartTls=disabled
UserDN=OU=Users,OU=MyBusiness,DC=mydomain,DC=lokal
Workgroup=MYDOMAIN
status=enabled
Hm, I assume a format like that in guacamole.properties (see /etc/e-smith/templates/etc/guacamole/guacamole.properties/10base:
BindDN=admin@domain.tld
Does that setting work? Do you see users/groups in cockpit?
I’m going to check, if not possible another way I could add a db prop binddn to be flexible for such cases.
I removed and readded the domain membership and then it asked for a principal name as bindDN. I used administrator@myadmin.lokal and it seems to be correct also in Guacamole. However I still don’t see any users in guacamole (however in Cockpit of NS, I see users).
Another strange thing is, that the connection to Windows 7 machines is dropping all the time. Especially when trying to open the start menu.
Thanks for testing! I’m starting up some VMs to check…
Did you already play with the guacamole connection settings?
Did you update your guacamole from old 0.9 version?
Do you use a VPN?
I did update from old 0.9 version. I did run the db upgrade scripts.
No VPN. Yes I tried all connection settings.
Very strange: I get a connection to the login screen but as soon I enter user/password it disconnects. A similar thing is when I provide the username/password in guacamole. It connects but when opening the start menu, it disconnects.
Mar 12 00:35:19 myneths guacd[12117]: Connection closed.
Mar 12 00:35:19 myneths guacd: guacd[12117]: ERROR:#011Connection closed.
Mar 12 00:35:19 myneths guacd: guacd[12117]: INFO:#011User@c3d367af-b946-459a-8b5a-4d5b5ecfe0ef” disconnected (0 users remain)
Mar 12 00:35:19 myneths guacd: guacd[12117]: INFO:#011Last user of connection “$8ad00a2c-4144-4742-b04d-a52183f68ef9” disconnected
Mar 12 00:35:19 myneths guacd[12117]: User “@c3d367af-b946-459a-8b5a-4d5b5ecfe0ef” disconnected (0 users remain)
Mar 12 00:35:19 myneths guacd[12117]: Last user of connection “$8ad00a2c-4144-4742-b04d-a52183f68ef9” disconnected
Mar 12 00:35:19 myneths guacd: guacd[12117]: INFO:#011Internal RDP client disconnected
Mar 12 00:35:19 myneths guacd[12117]: Internal RDP client disconnected
Mar 12 00:35:19 myneths guacd[6107]: Connection “$8ad00a2c-4144-4742-b04d-a52183f68ef9” removed.
Mar 12 00:35:19 myneths guacd: guacd[6107]: INFO:#011Connection “$8ad00a2c-4144-4742-b04d-a52183f68ef9” removed.
Mar 12 00:35:19 myneths daemon.sh: 00:35:19.346 [http-nio-8080-exec-9] INFO o.a.g.tunnel.TunnelRequestService - User “guacadmin” disconnected from connection “3”. Duration: 13646 millisecond
I have similar problems but with VNC on an updated machine. I have no solution so far, it works on a test VM with a fresh nethserver-guacamole install.
I’ll check on a Win 7 VM and report…
Tested with Win 2019 Server as DC and Neth as domain member and guacamole login worked with port 389 and encryption “none” but for guacamole the users “Name” has to match, not the account / user logon name.
Usually the logon name has to match as it is in Neth. I tried with all attributes but no change. Need to test more…
In the following example markus works but admin does not work (nethadmin would work in guacamole but not in neth).
For testing just edit guacamole.properties and restart tomcat8.
The disconnect when clicking on the start menu looks similar to the following bug: https://issues.apache.org/jira/browse/GUACAMOLE-950
or this
BTW: How to enable more detailed tracing for guacamole and where are the log files?
I solved the disconnection problem. The glyph-caching is the problem and must be disabled in the guacamole settings for the connection.
grafik
