Error repository after upgrade to NS 7.6
NethServer Version: 7.6
Module: Software Center
Hi all,
when I go to software center I see some updates to apply. When I try to install them, I get an error: Resolving RPM dependencies -> Clear cache…
I already cleaned cache without any change.
I try to updates Nethserver from CLI whit yum update command. I get this:
Downloading packages:
Finishing delta rebuilds of 1 package(s) (837 k)
Some delta RPMs failed to download or rebuild. Retrying..            100% [===========================================================]  0.0 B/s | 837 kB  --:--:-- ETA
nethserver-cockpit-0.2.0-1.ns7 FAILED
http://mrmarkuz.dynu.net/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not Satisfiable
Trying other mirror.
https://mirror.alpix.eu/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTPS Error 416 - Requested Range Not Satisfiable
http://mirror.framassa.org/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not Satisfiable
http://server.liftingtrade.hu/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not Satisfiable
http://nethserver.de-labrusse.fr/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not Satisfiable
http://buck.goip.de/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not SatisfiableA
http://ketrax.eu/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 404 - Not FoundB/s |    0 B  --:--:-- ETA
To address this issue please refer to the below wiki article
https://wiki.centos.org/yum-errors
If above article doesn't help to resolve this issue please use https://bugs.centos.org/.
https://markusneuberger.at/mirror/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTPS Error 404 - Not Found-:-- ETA
http://mrmarkuz.goip.de/mirror/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not Satisfiable
http://nethserver.interlin.nl/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not Satisfiable
https://mirror.pcxlan.es/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTPS Error 416 - Requested Range Not Satisfiable
http://mirror.nethserver.org/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not Satisfiable
https://mirror.nethesis.it/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTPS Error 416 - Requested Range Not Satisfiable
http://mirror1.nethserver.org/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not Satisfiable
http://ns-mirror2.ibi.net.br/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not SatisfiableETA
http://ns-mirror1.ibi.net.br/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not SatisfiableETA
http://ns-mirror3.ibi.net.br/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not SatisfiableETA
http://mirror.nordest.systems/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not Satisfiable
Error downloading packages:
  nethserver-cockpit-0.2.0-1.ns7.noarch: [Errno 256] No more mirrors to try.
Any idea?
Thanks.
Thank you: it works.
I don’t know if it’s related but there’s a stale mirror
http://mirror-status.nethserver.org/
/Cc @mrmarkuz
Thanks, the rsync cron job was not running, should be fixed the next hour…
I am having this issue today - do not see any stale mirror on mirror-status.nethserver.org
Issue output:
# yum update
 * base: centos.s.uw.edu
 * epel: sjc.edge.kernel.org
 * extras: centos.s.uw.edu
 * nethforge: mirror.nethserver.org
 * nethserver-base: mirror.nethserver.org
 * nethserver-updates: mirror.nethserver.org
 * updates: centos.s.uw.edu
nethserver-base/7/x86_64/signature                       |  836 B     00:00
nethserver-base/7/x86_64/signature                       | 2.9 kB     00:00 !!!
nethserver-updates/7/x86_64/signature                    |  836 B     00:00
nethserver-updates/7/x86_64/signature                    | 4.1 kB     00:00 !!!
Resolving Dependencies
--> Running transaction check
---> Package ghostscript.x86_64 0:9.07-31.el7_6.3 will be updated
---> Package ghostscript.x86_64 0:9.07-31.el7_6.6 will be an update
---> Package ghostscript-cups.x86_64 0:9.07-31.el7_6.3 will be updated
---> Package ghostscript-cups.x86_64 0:9.07-31.el7_6.6 will be an update
---> Package nethserver-backup-data.noarch 0:1.4.3-1.ns7 will be updated
---> Package nethserver-backup-data.noarch 0:1.4.4-1.ns7 will be an update
---> Package nethserver-base.noarch 0:3.6.1-1.ns7 will be updated
---> Package nethserver-base.noarch 0:3.6.2-1.ns7 will be an update
---> Package nethserver-cockpit.noarch 0:0.1.1-1.ns7 will be updated
---> Package nethserver-cockpit.noarch 0:0.2.0-1.ns7 will be an update
---> Package nethserver-mail-smarthost.noarch 0:2.4.2-1.ns7 will be updated
---> Package nethserver-mail-smarthost.noarch 0:2.4.3-1.ns7 will be an update
---> Package nethserver-nextcloud.noarch 0:1.3.0-1.ns7 will be updated
---> Package nethserver-nextcloud.noarch 0:1.4.0-1.ns7 will be an update
---> Package nethserver-release.noarch 0:7-11.ns7 will be updated
---> Package nethserver-release.noarch 0:7-12.ns7 will be an update
---> Package nethserver-samba.noarch 0:4.2.0-1.ns7 will be updated
---> Package nethserver-samba.noarch 0:4.2.1-1.ns7 will be an update
---> Package nethserver-subscription.noarch 0:3.2.1-1.ns7 will be updated
---> Package nethserver-subscription.noarch 0:3.3.0-1.ns7 will be an update
---> Package nethserver-subscription-ui.noarch 0:3.2.1-1.ns7 will be updated
---> Package nethserver-subscription-ui.noarch 0:3.3.0-1.ns7 will be an update
---> Package nextcloud.noarch 0:14.0.4-1.el7 will be updated
---> Package nextcloud.noarch 0:15.0.0-1.el7 will be an update
--> Processing Dependency: rh-php71-php-imagick for package: nextcloud-15.0.0-1.el7.noarch
---> Package sclo-php71-php-pecl-imagick.x86_64 0:3.4.3-2.el7 will be installed
--> Processing Dependency: libMagickWand.so.5()(64bit) for package: sclo-php71-php-pecl-imagick-3.4.3-2.el7.x86_64
--> Processing Dependency: libMagickCore.so.5()(64bit) for package: sclo-php71-php-pecl-imagick-3.4.3-2.el7.x86_64
---> Package ImageMagick.x86_64 0:6.7.8.9-15.el7_2 will be installed
--> Processing Dependency: libwmflite-0.2.so.7()(64bit) for package: ImageMagick-6.7.8.9-15.el7_2.x86_64
--> Processing Dependency: librsvg-2.so.2()(64bit) for package: ImageMagick-6.7.8.9-15.el7_2.x86_64
--> Processing Dependency: libjasper.so.1()(64bit) for package: ImageMagick-6.7.8.9-15.el7_2.x86_64
--> Processing Dependency: libgdk_pixbuf-2.0.so.0()(64bit) for package: ImageMagick-6.7.8.9-15.el7_2.x86_64
--> Processing Dependency: libImath.so.6()(64bit) for package: ImageMagick-6.7.8.9-15.el7_2.x86_64
--> Processing Dependency: libIlmThread.so.6()(64bit) for package: ImageMagick-6.7.8.9-15.el7_2.x86_64
--> Processing Dependency: libIlmImf.so.7()(64bit) for package: ImageMagick-6.7.8.9-15.el7_2.x86_64
--> Processing Dependency: libIexMath.so.6()(64bit) for package: ImageMagick-6.7.8.9-15.el7_2.x86_64
--> Processing Dependency: libIex.so.6()(64bit) for package: ImageMagick-6.7.8.9-15.el7_2.x86_64
--> Processing Dependency: libHalf.so.6()(64bit) for package: ImageMagick-6.7.8.9-15.el7_2.x86_64
---> Package OpenEXR-libs.x86_64 0:1.7.1-7.el7 will be installed
---> Package gdk-pixbuf2.x86_64 0:2.36.12-3.el7 will be installed
---> Package ilmbase.x86_64 0:1.0.3-7.el7 will be installed
---> Package jasper-libs.x86_64 0:1.900.1-33.el7 will be installed
---> Package librsvg2.x86_64 0:2.40.20-1.el7 will be installed
---> Package libwmf-lite.x86_64 0:0.2.8.4-41.el7_1 will be installed
Dependencies Resolved
 Package                     Arch   Version            Repository          Size
Updating:
 ghostscript                 x86_64 9.07-31.el7_6.6    updates            4.3 M
 ghostscript-cups            x86_64 9.07-31.el7_6.6    updates             59 k
 nethserver-backup-data      noarch 1.4.4-1.ns7        nethserver-updates  65 k
 nethserver-base             noarch 3.6.2-1.ns7        nethserver-updates 247 k
 nethserver-cockpit          noarch 0.2.0-1.ns7        nethserver-updates 837 k
 nethserver-mail-smarthost   noarch 2.4.3-1.ns7        nethserver-updates  45 k
 nethserver-nextcloud        noarch 1.4.0-1.ns7        nethserver-updates  28 k
 nethserver-release          noarch 7-12.ns7           nethserver-updates  25 k
 nethserver-samba            noarch 4.2.1-1.ns7        nethserver-updates  52 k
 nethserver-subscription     noarch 3.3.0-1.ns7        nethserver-updates  50 k
 nethserver-subscription-ui  noarch 3.3.0-1.ns7        nethserver-updates  24 k
 nextcloud                   noarch 15.0.0-1.el7       nethserver-updates  33 M
Installing for dependencies:
 ImageMagick                 x86_64 6.7.8.9-15.el7_2   base               2.1 M
 OpenEXR-libs                x86_64 1.7.1-7.el7        base               217 k
 gdk-pixbuf2                 x86_64 2.36.12-3.el7      base               570 k
 ilmbase                     x86_64 1.0.3-7.el7        base               100 k
 jasper-libs                 x86_64 1.900.1-33.el7     base               150 k
 librsvg2                    x86_64 2.40.20-1.el7      base               132 k
 libwmf-lite                 x86_64 0.2.8.4-41.el7_1   base                66 k
 sclo-php71-php-pecl-imagick x86_64 3.4.3-2.el7        centos-sclo-sclo   115 k
Transaction Summary
Install              ( 8 Dependent packages)
Upgrade  12 Packages
Total size: 42 M
Total download size: 837 k
Is this ok [y/d/N]: y
Some delta RPMs failed to download or rebuild. Retrying..| 837 kB     --:-- ETA
https://markusneuberger.at/mirror/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTPS Error 416 - Requested Range Not Satisfiable
http://ketrax.eu/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: [Errno 14] HTTP Error 416 - Requested Range Not Satisfiable
Installed http://mrmarkuz.goip.de/mirror/nethserver/7.6.1810/base/x86_64/Packages/kmod-xt_ndpi-2.4.0-1.ns7.x86_64.rpm – but does not seem pertinent to mirror issues
Turned off sonicwall in services, retried # yum update
There’s got to be a simple solution, I can see the packages in both http://mrmarkuz.goip.de/mirror/nethserver/7.6.1810/Updates/x86_64/Packages/ and http://mirror.nethserver.org/nethserver/7.6.1810/updates/x86_64/Packages/
Manual download of rpm files attempted with wget but # rpm -i produces errors for some packages, e.g.:
# rpm -i nethserver-nextcloud-1.4.0-1.ns7.noarch.rpm
error: Failed dependencies:
        nextcloud >= 15.0.0 is needed by nethserver-nextcloud-1.4.0-1.ns7.noarch
Current workaround:
# yum check-update
manually download all listed rpms from http://mirror.nethserver.org/nethserver/7.6.1810/updates/x86_64/Packages/
# yum -y localinstall --nogpgcheck *
Examining kmod-xt_ndpi-2.4.0-1.ns7.x86_64.rpm: kmod-xt_ndpi-2.4.0-1.ns7.x86_64
kmod-xt_ndpi-2.4.0-1.ns7.x86_64.rpm: does not update installed package.
Examining nethserver-base-3.6.2-1.ns7.noarch.rpm: nethserver-base-3.6.2-1.ns7.noarch
Marking nethserver-base-3.6.2-1.ns7.noarch.rpm as an update to nethserver-base-3.6.1-1.ns7.noarch
Examining nethserver-cockpit-0.2.0-1.ns7.noarch.rpm: nethserver-cockpit-0.2.0-1.ns7.noarch
Marking nethserver-cockpit-0.2.0-1.ns7.noarch.rpm as an update to nethserver-cockpit-0.1.1-1.ns7.noarch
Examining nethserver-mail-smarthost-2.4.3-1.ns7.noarch.rpm: nethserver-mail-smarthost-2.4.3-1.ns7.noarch
Marking nethserver-mail-smarthost-2.4.3-1.ns7.noarch.rpm as an update to nethserver-mail-smarthost-2.4.2-1.ns7.noarch
Examining nethserver-nextcloud-1.4.0-1.ns7.noarch.rpm: nethserver-nextcloud-1.4.0-1.ns7.noarch
Marking nethserver-nextcloud-1.4.0-1.ns7.noarch.rpm as an update to nethserver-nextcloud-1.3.0-1.ns7.noarch
Examining nethserver-release-7-12.ns7.noarch.rpm: nethserver-release-7-12.ns7.noarch
Marking nethserver-release-7-12.ns7.noarch.rpm as an update to nethserver-release-7-11.ns7.noarch
Examining nethserver-samba-4.2.1-1.ns7.noarch.rpm: nethserver-samba-4.2.1-1.ns7.noarch
Marking nethserver-samba-4.2.1-1.ns7.noarch.rpm as an update to nethserver-samba-4.2.0-1.ns7.noarch
Examining nethserver-subscription-3.3.0-1.ns7.noarch.rpm: nethserver-subscription-3.3.0-1.ns7.noarch
Marking nethserver-subscription-3.3.0-1.ns7.noarch.rpm as an update to nethserver-subscription-3.2.1-1.ns7.noarch
Examining nethserver-subscription-ui-3.3.0-1.ns7.noarch.rpm: nethserver-subscription-ui-3.3.0-1.ns7.noarch
Marking nethserver-subscription-ui-3.3.0-1.ns7.noarch.rpm as an update to nethserver-subscription-ui-3.2.1-1.ns7.noarch
--> Processing Dependency: nextcloud >= 15.0.0 for package: nethserver-nextcloud-1.4.0-1.ns7.noarch
base/7/x86_64/filelists_db                               | 7.1 MB     00:00
centos-sclo-rh/x86_64/filelists_db                       |  11 MB     00:00
centos-sclo-sclo/x86_64/filelists_db                     | 882 kB     00:00
epel/x86_64/filelists                                    |  10 MB     00:00
extras/7/x86_64/filelists_db                             | 189 kB     00:00
nethforge/7/x86_64/filelists_db                          |  46 kB     00:00
nethserver-base/7/x86_64/filelists_db                    | 660 kB     00:00
nethserver-updates/7/x86_64/filelists_db                 | 139 kB     00:00
updates/7/x86_64/filelists_db                            | 1.4 MB     00:00
Updating:
nethserver-base             noarch 3.6.2-1.ns7      /nethserver-base-3.6.2-1.ns7.noarch
        674 k
nethserver-cockpit          noarch 0.2.0-1.ns7      /nethserver-cockpit-0.2.0-1.ns7.noarch
        4.8 M
nethserver-mail-smarthost   noarch 2.4.3-1.ns7      /nethserver-mail-smarthost-2.4.3-1.ns7.noarch
        69 k
nethserver-nextcloud        noarch 1.4.0-1.ns7      /nethserver-nextcloud-1.4.0-1.ns7.noarch
        45 k
nethserver-release          noarch 7-12.ns7         /nethserver-release-7-12.ns7.noarch
        46 k
nethserver-samba            noarch 4.2.1-1.ns7      /nethserver-samba-4.2.1-1.ns7.noarch
        100 k
nethserver-subscription     noarch 3.3.0-1.ns7      /nethserver-subscription-3.3.0-1.ns7.noarch
        96 k
nethserver-subscription-ui  noarch 3.3.0-1.ns7      /nethserver-subscription-ui-3.3.0-1.ns7.noarch
        58 k
Updating for dependencies:
Transaction Summary
Upgrade  8 Packages (+1 Dependent package)
Total size: 42 M
Running transaction test
Transaction test succeeded
Running transaction
Warning: RPMDB altered outside of yum.
 Updating   : nethserver-base-3.6.2-1.ns7.noarch                          1/26
 Updating   : nethserver-subscription-3.3.0-1.ns7.noarch                  2/26
 Installing : jasper-libs-1.900.1-33.el7.x86_64                           3/26
 Installing : gdk-pixbuf2-2.36.12-3.el7.x86_64                            4/26
 Installing : ilmbase-1.0.3-7.el7.x86_64                                  5/26
 Installing : OpenEXR-libs-1.7.1-7.el7.x86_64                             6/26
 Installing : librsvg2-2.40.20-1.el7.x86_64                               7/26
 Installing : libwmf-lite-0.2.8.4-41.el7_1.x86_64                         8/26
 Installing : ImageMagick-6.7.8.9-15.el7_2.x86_64                         9/26
 Installing : sclo-php71-php-pecl-imagick-3.4.3-2.el7.x86_64             10/26
 Updating   : nextcloud-15.0.0-1.el7.noarch                              11/26
 Updating   : nethserver-nextcloud-1.4.0-1.ns7.noarch                    12/26
 Updating   : nethserver-subscription-ui-3.3.0-1.ns7.noarch              13/26
 Updating   : nethserver-cockpit-0.2.0-1.ns7.noarch                      14/26
 Updating   : nethserver-samba-4.2.1-1.ns7.noarch                        15/26
 Updating   : nethserver-mail-smarthost-2.4.3-1.ns7.noarch               16/26
 Updating   : nethserver-release-7-12.ns7.noarch                         17/26
 Cleanup    : nethserver-nextcloud-1.3.0-1.ns7.noarch                    18/26
 Cleanup    : nethserver-cockpit-0.1.1-1.ns7.noarch                      19/26
 Cleanup    : nethserver-mail-smarthost-2.4.2-1.ns7.noarch               20/26
 Cleanup    : nethserver-subscription-ui-3.2.1-1.ns7.noarch              21/26
 Cleanup    : nethserver-subscription-3.2.1-1.ns7.noarch                 22/26
 Cleanup    : nethserver-samba-4.2.0-1.ns7.noarch                        23/26
 Cleanup    : nethserver-base-3.6.1-1.ns7.noarch                         24/26
 Cleanup    : nextcloud-14.0.4-1.el7.noarch                              25/26
 Cleanup    : nethserver-release-7-11.ns7.noarch                         26/26
 Verifying  : nethserver-release-7-12.ns7.noarch                          1/26
 Verifying  : gdk-pixbuf2-2.36.12-3.el7.x86_64                            2/26
 Verifying  : nethserver-samba-4.2.1-1.ns7.noarch                         3/26
 Verifying  : nethserver-subscription-3.3.0-1.ns7.noarch                  4/26
 Verifying  : ilmbase-1.0.3-7.el7.x86_64                                  5/26
 Verifying  : nethserver-subscription-ui-3.3.0-1.ns7.noarch               6/26
 Verifying  : OpenEXR-libs-1.7.1-7.el7.x86_64                             7/26
 Verifying  : libwmf-lite-0.2.8.4-41.el7_1.x86_64                         8/26
 Verifying  : nextcloud-15.0.0-1.el7.noarch                               9/26
 Verifying  : nethserver-mail-smarthost-2.4.3-1.ns7.noarch               10/26
 Verifying  : librsvg2-2.40.20-1.el7.x86_64                              11/26
 Verifying  : nethserver-cockpit-0.2.0-1.ns7.noarch                      12/26
 Verifying  : sclo-php71-php-pecl-imagick-3.4.3-2.el7.x86_64             13/26
 Verifying  : jasper-libs-1.900.1-33.el7.x86_64                          14/26
 Verifying  : nethserver-base-3.6.2-1.ns7.noarch                         15/26
 Verifying  : ImageMagick-6.7.8.9-15.el7_2.x86_64                        16/26
 Verifying  : nethserver-nextcloud-1.4.0-1.ns7.noarch                    17/26
 Verifying  : nethserver-subscription-3.2.1-1.ns7.noarch                 18/26
 Verifying  : nethserver-samba-4.2.0-1.ns7.noarch                        19/26
 Verifying  : nethserver-base-3.6.1-1.ns7.noarch                         20/26
 Verifying  : nethserver-nextcloud-1.3.0-1.ns7.noarch                    21/26
 Verifying  : nethserver-cockpit-0.1.1-1.ns7.noarch                      22/26
 Verifying  : nextcloud-14.0.4-1.el7.noarch                              23/26
 Verifying  : nethserver-mail-smarthost-2.4.2-1.ns7.noarch               24/26
 Verifying  : nethserver-release-7-11.ns7.noarch                         25/26
 Verifying  : nethserver-subscription-ui-3.2.1-1.ns7.noarch              26/26
Dependency Installed:
Updated:
Dependency Updated:
Complete!
This is a cumbersome workaround but it appears to have been successful. Would like a better long-term solution if anyone has one. Thanks!
I can reproduce the error. I think it is due to invalid delta-rpms (like requesting a byte-range outside the file boundaries) for nethserver-cockpit (at least), similar to this issue:
Oh, that’s great news. Do you think uninstalling deltarpm might solve the problem?
Yes. But you can disable it at runtime, globally in yum.conf, or per repository.
You know these Xmas dates, if you are not in a hurry I’d rather wait some days till devs can take a look at it.
Yep, sounds great!
Thanks for the better solution than the one I came up with. I will probably disable deltarpm for NethServer.repo - what great community support this has been :slight_smile:
Happy Holidays
I issued a rebuild of repository metadata: let’s see if this fix the problem.
rad, thanks :slight_smile:
I’ve got this problem as well even after yum --enablerepo=* clean all
Specifically in my case I get
check the repository enabled
yum repolist
you could check deeply also
yum repolist -v | less
repo id                                     repo name                                                     status
!ce-base/7/x86_64                           CE-Base-7.6.1810                                              10,019
!ce-extras/7/x86_64                         CE-Extras-7.6.1810                                               321
!ce-updates/7/x86_64                        CE-Updates-7.6.1810                                              624
!centos-sclo-rh/x86_64                      CentOS-7 - SCLo rh                                             7,857
!centos-sclo-sclo/x86_64                    CentOS-7 - SCLo sclo                                             724
!epel/x86_64                                Extra Packages for Enterprise Linux 7 - x86_64                12,776
!nethforge/7/x86_64                         NethForge 7                                                       25
!nethserver-base/7/x86_64                   NethServer-7 - Base                                              322
!nethserver-updates/7/x86_64                NethServer-7 - Updates                                            24
repolist: 32,692
[root@mattlabs ~]# yum repolist -v | less
Loading "changelog" plugin
Loading "fastestmirror" plugin
Loading "nethserver_events" plugin
Loading "product-id" plugin
Loading "search-disabled-repos" plugin
Loading "subscription-manager" plugin
Updating Subscription Management repositories.
Unable to read consumer identity
This system is not registered with an entitlement server. You can use subscription-manager to register.
Config time: 0.135
Yum version: 3.4.3
 * ce-base: mi.mirror.garr.it
 * ce-extras: mi.mirror.garr.it
 * ce-updates: mi.mirror.garr.it
 * epel: mirror.infonline.de
 * nethforge: mirror.framassa.org
 * nethserver-base: mirror.framassa.org
 * nethserver-updates: mirror.framassa.org
Setting up Package Sacks
pkgsack time: 0.024
Repo-id      : ce-base/7/x86_64
Repo-name    : CE-Base-7.6.1810
Repo-revision: 1543161601
Repo-updated : Sun Nov 25 17:00:34 2018
Repo-pkgs    : 10,019
Repo-size    : 9.4 G
Repo-mirrors : http://mirrorlist.nethserver.org/?release=7&repo=ce-base&arch=x86_64&nsrelease=7.6.1810
Repo-updated : Mon Dec 10 17:00:03 2018
Repo-pkgs    : 321
Repo-size    : 392 M
Repo-mirrors : http://mirrorlist.nethserver.org/?release=7&repo=ce-extras&arch=x86_64&nsrelease=7.6.1810
Repo-baseurl : http://mi.mirror.garr.it/mirrors/CentOS/7.6.1810/extras/x86_64/ (8 more)
Repo-expire  : 21,600 second(s) (last: Fri Dec 28 11:56:48 2018)
  Filter     : read-only:present
Repo-filename: /etc/yum.repos.d/NsReleaseLock.repo
Repo-id      : ce-updates/7/x86_64
Repo-name    : CE-Updates-7.6.1810
Repo-revision: 1545413965
Repo-updated : Fri Dec 21 18:42:32 2018
Repo-pkgs    : 624
Repo-size    : 3.5 G
Repo-mirrors : http://mirrorlist.nethserver.org/?release=7&repo=ce-updates&arch=x86_64&nsrelease=7.6.1810
Repo-baseurl : http://mi.mirror.garr.it/mirrors/CentOS/7.6.1810/updates/x86_64/ (8 more)
Repo-expire  : 21,600 second(s) (last: Fri Dec 28 11:56:49 2018)
Repo-id      : centos-sclo-rh/x86_64
Repo-name    : CentOS-7 - SCLo rh
Repo-revision: 1544056569
Repo-updated : Thu Dec  6 01:38:08 2018
Repo-pkgs    : 7,857
Repo-size    : 6.5 G
Repo-baseurl : http://mirror.centos.org/centos/7/sclo/x86_64/rh/
Repo-filename: /etc/yum.repos.d/CentOS-SCLo-scl-rh.repo
Repo-id      : centos-sclo-sclo/x86_64
Repo-name    : CentOS-7 - SCLo sclo
Repo-revision: 1545675716
Repo-updated : Mon Dec 24 19:22:00 2018
Repo-pkgs    : 724
Repo-size    : 231 M
Repo-baseurl : http://mirror.centos.org/centos/7/sclo/x86_64/sclo/
Repo-filename: /etc/yum.repos.d/CentOS-SCLo-scl.repo
Repo-id      : epel/x86_64
Repo-name    : Extra Packages for Enterprise Linux 7 - x86_64
Repo-revision: 1545977379
Repo-updated : Fri Dec 28 07:10:52 2018
Repo-pkgs    : 12,776
Repo-size    : 14 G
Repo-metalink: https://mirrors.fedoraproject.org/metalink?repo=epel-7&arch=x86_64
  Updated    : Fri Dec 28 07:10:52 2018
Repo-baseurl : https://mirror.infonline.de/epel/7/x86_64/ (47 more)
Repo-filename: /etc/yum.repos.d/epel.repo
Repo-id      : nethforge/7/x86_64
Repo-name    : NethForge 7
Repo-revision: 1545139738
Repo-updated : Tue Dec 18 14:28:59 2018
Repo-pkgs    : 25
Repo-size    : 129 M
Repo-mirrors : http://mirrorlist.nethserver.org/?release=7&repo=nethforge&arch=x86_64&nsrelease=7.6.1810
Repo-baseurl : http://mirror.framassa.org/nethserver/7.6.1810/nethforge/x86_64/ (17 more)
Repo-filename: /etc/yum.repos.d/NethForge.repo
Repo-id      : nethserver-base/7/x86_64
Repo-name    : NethServer-7 - Base
Repo-revision: 1544698988
Repo-updated : Thu Dec 13 12:03:18 2018
Repo-pkgs    : 322
Repo-size    : 1.0 G
Repo-mirrors : http://mirrorlist.nethserver.org/?release=7&repo=base&arch=x86_64&nsrelease=7.6.1810
Repo-baseurl : http://mirror.framassa.org/nethserver/7.6.1810/base/x86_64/ (17 more)
Repo-expire  : 21,600 second(s) (last: Fri Dec 28 11:56:50 2018)
Repo-filename: /etc/yum.repos.d/NethServer.repo
Repo-id      : nethserver-updates/7/x86_64
Repo-name    : NethServer-7 - Updates
Repo-revision: 1545904974
Repo-updated : Thu Dec 27 11:02:55 2018
Repo-pkgs    : 24
Repo-size    : 150 M
Repo-mirrors : http://mirrorlist.nethserver.org/?release=7&repo=updates&arch=x86_64&nsrelease=7.6.1810
Repo-baseurl : http://mirror.framassa.org/nethserver/7.6.1810/updates/x86_64/ (17 more)
repolist: 32,692
NB / This looks closely related to 7.6. I think all my servers exhibits this problem, wether they are upgraded or fresh installed.
After almost a week of dealing with this problem it’s good to know I’m not alone
As commented before, disabling rpm-deltas made the update work:
yum --setopt=deltarpm=0 update nethserver-cockpit
I don’t know if it is the correct way to test this or it’s of any use for the repo maintainers, but when applying deltarpm to nethserver-cockpit or when generating delta-rpm from the packages the resulting checksum differs:
# applydeltarpm -r nethserver-cockpit-0.1.1-1.ns7.noarch.rpm nethserver-cockpit-0.1.1-1.ns7_0.2.0-1.ns7.noarch.drpm nethserver-cockpit.rpm
# makedeltarpm nethserver-cockpit-0.1.1-1.ns7.noarch.rpm nethserver-cockpit-0.2.0-1.ns7.noarch.rpm nethserver-cockpit.drpm
# sha256sum *.drpm
0ff5da42a7474b544008cfbc22694a17700a2a8e2b707aa96fcdc5698a9537e4  nethserver-cockpit-0.1.1-1.ns7_0.2.0-1.ns7.noarch.drpm
73b91db4a5b0fe0b9b112d2180035b4c57ec8bf2a1ca916a2da3740a4089892e  nethserver-cockpit.drpm
# sha256sum *.rpm
a9bd1125bc989dc382cda9ad607d6c460421e3a55fdac1c4f4bc842deabaa22c  nethserver-cockpit-0.1.1-1.ns7.noarch.rpm
fd4e709cab94499fd046f4b2ad82b6ff14a2a5cbef36c734288950a439b06c67  nethserver-cockpit-0.2.0-1.ns7.noarch.rpm
61e8373a2536e6cdb87ed87c1400d6e90a7ed3c0eef19e5943ffc98df961600a  nethserver-cockpit.rpm   # shouldn't it be the same as nethserver-cockpit-0.2.0-1.ns7.noarch.rpm ?
I did:
rpm -Uvh http://mrmarkuz.goip.de/mirror/nethserver/7/updates/x86_64/Packages/nethserver-cockpit-0.2.0-1.ns7.noarch.rmp
and that removed cockpit-0.1.1-1.ns7 and installed cockpit-0.2.0-1.ns7
After that the Gui update was able to run successfully.
