Optional packages are now installed by default from Software Center. If a packages has not been installed, each application should detect it a display a button to add the missing package.
Just fiddling a bit with this. @filippo_carletti do you happen to know to what interface the cockpit-machines option is listening/accessable?
Is it possible to check and make sure it is only available through a GREEN interface?
Exacly… how you think that this is achievable? It’s a part of an application server which use port 9090.
So… or you allow connection to port 9090 (reducing footprint specifing allowed addresses to connect)… or you dont. At least… combining Shorewall and Cockpit settings.
Thnx for the insight @pike
I made the thinking-error between the interface and the VM’s that are running, managed through the interface.
I would like to make sure the VM is behind NAT (from NethServer). I perfectly am able to disable RED interface for NethServer-cockpit (so it is only available from GREEN, through VPN)
So basically I need to know how networking is set for VM’s. I probably need to just launch a VM and see what happens.
BTW, in my recollection I seem to remember cockpit can also handle containers. Is that another module and if so, would it be possible to use that too on nethserver-cockpit?
Fellow @ertank view a part of his Complete name contains characters different than ASCII.
Maybe some of the configuration about Cockpit should be enhanced for use UTF8?
