System Configuration Backup - Configuration backup settings won't adjust upon save
Hello,
I was trying to adjust the retention # of days from 3 to 5 (any number) but when selecting “Save” after input the dialog box in Cockpit doesn’t go away and only a little small circle to the left of the “Cancel” button appears briefly. Exiting & re-entering the dialog box does not retain the desired changes. I am using Firefox latest update.
Hi @royceb, I can reproduce.
Tomorrow I will investigate on it.
Here is the issue
@royceb, could you test the fix by @federico.ballarini?
Run this command to install the package to test:
yum -y --enablerepo=nethserver-testing update nethserver-cockpit\*
Not sure if the update got pushed or is availble to me yet.
[root@ns1 ~]# yum -y --enablerepo=nethserver-testing update nethserver-cockpit\*
 * ce-base: centos.mirror.garr.it
 * ce-extras: centos.mirror.garr.it
 * ce-sclo-rh: centos.mirror.garr.it
 * ce-sclo-sclo: centos.mirror.garr.it
 * ce-updates: centos.mirror.garr.it
 * epel: mirror.sfo12.us.leaseweb.net
 * nethforge: nethserver.interlin.nl
 * nethserver-base: nethserver.interlin.nl
 * nethserver-updates: nethserver.interlin.nl
nethserver-testing/7/x86_64/signature                                             |  836 B  00:00:00
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-NethServer-7
Importing GPG key 0x39BAF5C1:
 Userid     : "NethServer 7 (NethServer 7 Official Signing Key) <security@nethserver.org>"
 Fingerprint: 594c 3fd8 fae1 8ff5 32fe ae23 9cb2 8ea0 39ba f5c1
 Package    : nethserver-release-7-16.ns7.noarch (@nethserver-updates)
nethserver-testing/7/x86_64/signature                                             | 2.9 kB  00:00:00 !!!
nethserver-testing/7/x86_64/primary_db                                            | 158 kB  00:00:00
No packages marked for update
You’re right, the package was missing from the testing repo (due to an upstream mirror issue, but that’s another story…).
Now it should work. But clear YUM cache before:
 yum --enablerepo=nethserver-testing clean all
If you’re behind a web proxy more parameters are needed: let me know…
Just updated and verified the bug has been fixed. Thank you.
