My bad: we do not have a document describing the road map. You can find some info in the forum, we also talked a bit together at FOSDE, and finally some marginal notes ares on my private workstation
Thanks for the explanation!
Would it be a good idea to move this information to the Project feature of GitHub?
I also noticed that the issue-tab is disabled in the cockpit repository, is that intentional?
Once we used the project board inside the cockpit repo to track the first alpha.
The problem is keeping it up to date, honestly I don’t have the time to do it
Okay, I understand that these things need fostering…
However this makes it difficult for new guys like my to find their way into the codebase and get an overview. Also a issue-list of not-too-hard bugs or easy features would be very helpful in order to find my way into the code. This is where a project board combined with a separate issue list would be very helpful!
Removing modules (and packages), compatibility with NethGUI
My test server was installed with NethGUI, then it was updated and I installed several packages (and modules) from NethGUI. Now also Cockpit is present.
But…
not all NethGUI packages are shown into “Applications”.
there’s quite differences between NethGUI software center and Cockpit software center (for instance, i cannot see what modules i already installed)
some packages seems needed (dependencies) for installing other (for instance, email seems to have dependencies likes rSpamd, nethserver-mail-filter, nethserver-mail-getmail)
for remove packages i must access to Application section because Software Center cannot be used
Just trying to point out the situation, that’s not a complain.
IMHO, at least from Software Center I should be able to:
