Hello,
i am migrating from my opensuse to nethserver.
I need some settings for postfix for example relaymaps for outgoing mails to my providers web.de and gmx.de. Also I need saslauth for authenticating via smtp.
I learned that I have to use templates for persistent settings. But if I create a template in /etc/e-smith/templates-custom/etc/postfix/relaymaps/00relaymaps it isn’t used.
I have created a folder main.cf with a file called 70relay. That doesn’t work too.
Could you tell me in which logfile I have to look into to find some error?
What service do I have to restart to apply my changes in the template folder?
I need several smarthosts. One for Web.de, one for Google.com, …
This will only work with relaymaps in my opinion.
The logfiles are only for mail itself as far as I know.
I am searching for the logfiles which build the postfix config from the templates. Is there any?
Which process do I have to start to build the config from templates ?
I use nethserver as my one mailserver for incoming and outgoing Mails. I do not want to allow my Clients a direct connection to the providers via smtp. All Emails must pass my nethserver.
I have to authenticate on some smtp servers.
Where can I define the credentials for these domains?
I found only one at the smarthost configuration.
These szenario exists mostly with freemail accounts.
Example: User1 has an account at google.com.
User2 has an account at gmx.com
Both have to authenticate before they can use the smtp from these providers.
this doesn’t answer to the question: why do you need to auth to many external smtp servers?
I mean: usually you need only a single smarthost… this is true in 99% of cases… I know that if you’re using a solution like office365 it won’t work, as you must auth each user with its own credentials (this is how at Redmond try to fight spam…)
So what are the advantages of configuring the external providers as smarthosts on NethServer?
IMO it seems hard to maintain each account credentials. This configuration requires additional development of Postfix configuration and UI forms; I’m still not sure it is worth the effort.
However I like new ideas Could you share the Postfix configuration you have on OpenSuse?
I had written an really long explanation but if I click on reply I get the following error message:
Sorry, new users can only mention 2 users in a post.
A “mention” on Discourse is a @ followed by a username. A newly registered user has some limitations on the available features. Perhaps your text contains strings of that form?
Perhaps I explained the situation not detailed enough.
I have no idea how I can solve my situation without relaymaps and
sasl_passwd. If anybody has one please tell me.
The situation is the following. I cannot use only one smarthost because
all spamfilter would block the connection if you send mails with an open
relay.
So all mails have to send with the corresponding mailserver from which
domain you are sending the mail. Additional to that you have to
configure sasl_passwd for each emailaccount. I have replaced all @ with at.
First of all I’m happy to say welcome on our community @Linux4All! Our community guy @alefattorini uses to greet newcomers every week but I bet he’s on holiday (as me and many others from Italy).
Before analyzing the configuration, I have a question here: why you say “open relay”? By default NethServer allows relaying only to authenticated clients. In other words it knows the sender identity before sending the message to an external domain.
This is exactly what the other mail providers do, gmail, for instance.
However I’m assuming you have a registered MX in DNS
That’s exactly what I fighting against and what I try to explain all the time.
Hopefully there will be a solution with Nethserver.
I tried a lot of distributions and SBS editions. Nethserver was the only one which survived more than 30 minutes
I think I will find some more enhancements which I need but the base is very good.
@davidep avidep: What can I do to have a persistent postfix config, until this feature is implemented, hopefully it will.
