Sorry, I changed it to not slow down the zabbix-update event, see the end of /etc/e-smith/events/actions/nethserver-zabbix-conf-db
You need to remove the zabbiximages dir /var/lib/pgsql/data/zabbiximages and put your images to /root/images.tar.gz before adding the images to the DB.
Thanks for your images, I’ll add them with next release.
I’ve seen - on Linux - people creating folders with names like action.exe (No, a folder, not a executable file!) and also the same for .tar.gz - also where this was a folder.
So I prefer to ask, rather than assume something, which may be influenced by ages old MS-Dos leanings on extensions…
Sitting in front of a (german) macbook, I think Mac also uses the term Folder (Along with Finder).
In german, the term is “Ordner”, corresponding to the english “Folder”…
Sometimes I think Windows can be more contagious than Corona…
Like the Linux guy using start.exe for his start script in Linux…
When removing the SNMP component in the old Server Manager, the nethserver-zabbix component also get’s removed, this should not happen!
Afterwards, Zabbix is effectively removed from NethServer…
Just discovered that, while preparing for next weeks Zabbix Hands-On training…
I think this may have to do with “deps”, not necessarily on Zabbix, but maybe somehow in the SNMP component of Nethserver…
I did not remove Zabbix, only the SNMP component. Afterwards, Zabbix was gone.
This is here not critical, this is an “empty” demo server…
But still, it should not happen, as SNMP is NOT dependent on Zabbix and neither is Zabbix dependent on SNMP…
Zabbix itself is not removed, but nethserver-zabbix…
Nethserver-zabbix actually requires net-snmp-utils and nethserver-net-snmp.
I think the requirement of nethserver-net-snmp leads to the issue. I’m going to remove this dependency and test…
SNMP is optional but I’d like to keep at least the net-snmp requirement just to ease installation and use of SNMP in Zabbix…
