Whatever people did to break the frontend Web GUI with all this stupid JavaScript between NethSecurity 8-25 and 8.7 I don’t know…
I’m not a javascript person, I like to keep things simple, and making the entire thing just javascript is just asking to be break. I thought it was my machine that was slow, but no, it’s the javascript.
So there is something wrong, and I don’t know what it is with 8.7. I don’t know why it is 8 dash 25 and then it changes to eight point seven.. Was it meant to be eight point twenty five?
So yes I am very confused, and I can’t make much sense out of the console from what is wrong either. All I could say is that it’s broken, very broken in 8.7.
8-25 works fine, so I’m having no issues with that. Once people get 8.7+ working again I will be able to start things with that and get the WiFi going on 8.7+ as well as 8-25. So for now I’ll just keep adding to 8-25 and improving my system until 8.7+ is fixed.
All I do is download the image, DD it onto the drive, repair the GPT (Why it isn’t using MBR I’ll never know…
But that’s it, it boots up fine, and all filesystems are completely in tact.
I wish I could change it to just be a normal system though, that way I would have control over it and make things better easier.
After that, I just connect the cable to the right port and then go to the login page, and that’s where it all falls apart on 8.7.1
Edit: Yes I tried multiple times. Yes I tried a brand new fresh and clean browser. Yes I did all the things that make no difference. Yes I tried everything that should have made a difference that I could think of.
Version 8.7.1 was released end of October 2025 and there were no support requests like yours so I really don’t know what’s wrong with your installation.
I followed it close enough yes. I just don’t do it all in one hit like that.
First I extract it, then I DD it, then I run FDISK and that repairs the GPT records using the new record and overwrites the backups with the new one. Thus making it work flawlessly on the drive.
Ahh, that explains the versioning….
I can load it up on the again maybe. I’ll just have to remove everything off the system externally first…
How do I get rid of the stuff on screen for the dropped connection attempts?
I can’t use the CLI while that’s hapenning…
