WEBTOP (nethserver 8)
Ciao a tutti, volevo sottoporre un problema legato a WEBTOP.
Ha smesso di funzionare e tutte le azioni che faccio dalla console mi vanno in errore. Non so cosa possa essere successo ma ho la necessità di forzare la rimozione dell’istanza. Potete darmi qualche indicazione su come operare dalla shell del server? Grazie in anticipo per il supporto.
Hi and welcome in the Nethservercommunity. Merry Christmas. Please be so kindly in future and post your problems in english language.
Thank you and have fun.
Uwe
Translate:
Hello everyone, I wanted to report a problem related to WEBTOP.
It has stopped working and all the actions I perform from the console result in an error. I don’t know what could have happened, but I need to force the removal of the instance. Can you give me some guidance on how to do this from the server shell? Thank you in advance for your support.
I think, this is the right command.
remove-module --no-preserve weptop1 (or what ever is the number of your webtop instance].
Hi Alberto,
could you please post some examples of the error you raise?
Hi Federico,
I tried the command you suggested, and the result is this:
<3>Cannot retrieve the NODE_ID of webtop1
The instance on nethserver 8 is as follows:
Does it help to use the force option?
Here’s a procedure to remove an app when the installation was interrupted:
Hi @mrmarkuz,
Your solution worked fine. Thank you for the quick and effective support.
Bye
