Hello @support_team, @webtop_team or @lucag,
Where in the Addressbook can I export all addresses we’ve entered?
Thank you.
Thank you.
you can do it with Thunderbird and the CardBook Addon.
I think there is now way to export the Adressbook directly in Webtop. There you can only import Calendar and Adressbook.
Regards…
Uwe
Hi @greavette,
you can also export contacts in CSV directly from the database, I wrote here how to do it ![]()
Thanks very much @lucag for this reply. I will give it a try.
But is there a reason why this wouldn’t be built into Webtop? I’m coming from Zarafa and it also did not have a native export function which makes it very difficult to move to a new mail server if needed/warranted. I would think exporting and importing addressbook data should be standard in Webtop. Is this on your roadmap and if not then why not?
Thank you.
I confirm that the export of contacts and events is on the roadmap … we hope to have them soon ![]()
That’s great news @lucag. Appreciate the confirmation!
