Hello All
I’m having an issue with the web proxy functionality. It seems more often than not when I get back into work in the morning it is no longer working, as in, can not navigate to any webpages.
I’m fairly new to NethServer and just testing things out at the moment. It is a fresh install with only backup and web proxy installed as extras. I am running in a virtual machine with only red (eth0) and green (eth1) networks setup.
I have tried to disable the proxy and re-enable but that doesn’t fix the issue, I have to reboot NethServer. Both interfaces are displaying OK in the dashboard. I’ve had a look around the log files but am a bit unfamiliar with them so I didn’t see anything that would lead me in the right direction.
Any information would be greatly appreciated.
Thanks,
Jason
EDIT I’m running the proxy in Transparent Mode, Cache Enabled…
