Good evening, I want the permission to use the Internet to be decided at the AD group level
Tell me how to solve this?
Clarify: two groups in AD, one has access to the Internet, the other does not, how to assign these groups access or denial?
Choose manual. The client is already set up to use WPAD, and NethServer has the file ready. If I’m not mistaken, you’ll find that file in /var/www/html/.
Apache distributes the file if a client requests it. Apache can be setup with group permissions, but you’ld need to check with Google.
Good evening, I still couldn’t figure it out a bit! Help me please!!! I found the wpad.dat file and there are already entries there! I need to create an A record in the domain controller on WPAD. On the Internet, I could not find how to prime the blood pressure groups to this wpad.dat file ???
In general, the task is the following! There are 4 groups in AD - squid-bed (access is denied to users on the Internet), squid-user (access is allowed), squid-admin (access to the Internet for the administrator), squid-limit (group of users with a limited speed), how to implement it all in nethserver ??? Now enabled in the authorization settings! I would be grateful if you can describe in detail how to implement this))) Thanks in advance !!!
I understand that with the help of the squid configuration file nothing will come out to solve such a problem! For example: / usr / lib / squid / ext_kerberos_ldap_group_acl -a -d -i -n -l ldap: //my.domain -u user -p password -g squid-internet
