Hi @pike
I only switched to Strato because I have the same problem with pCloud as you.
Even with the help of the pCloud support there it is not solvable, they simply claim - we have no issue, all systems work fine.
WebDAV with Strato woks fine (apart from this error message, I do not see any effects. The backup is saved well), but I’m reluctant to use WebDAV, I’d much rather use SFTP. However, SFTP does not come up, although a connection with a smp,en ftp client works.
But I can’t interpret what “Nethserver’s backup module expects the target server to be smart and will not work with dumb, basic, passive, restricted, pure (S)FTP servers” means to confront Stratos Support with concrete requirements in their SFTP server.
I’ve some 50GB free accounts on box.com since ages, exploiting some “promotions” launched when iOS was not having box.net app. The service could be suitable for the size and speed, but price is not that interesting.
I’ve also nudged cubbit.io for adding WebDAV access for the service. Hope that someone will nudge them soon for implement the protocol on their nice infrastructure.
I mean that NS tries to log in the server through SSH and launch some shell commands before going to SFTP. That implies that the storage is “smart” and allows that, which is not the case for most storage offers I believe.
…and with your suggestion SFTP chroot howto you can work around the problem and still use such servers?
I believe not, because I have to use credentials from the remote server.
Nope : that howto was server side (NS side), to lock a distant SFTP user into a home folder. Here the problem is storage side, which doesn’t offer features or rights that the NS client expects.
it seems that centos7 has to be updated since 2020
You might try a newer version of davfs2, e.g. 1.5.6. It will be able to handle situations where /etc/mtab is a symbolic link to a kernel file system and not writable.
Maybe another webdav provider? I use stack from transip (transip.nl/stack). Unfortunately their website in currently only available in Dutch, but with Goole translate it should be possible to get the idea of what it is and does.
I use it with WebDav for over 4 years now as backup location for my NethServer based VPS’s
ps: when you have an account, you can change the interface into English…
