Username is not displayed correctly (no UTF8?)
NethServer Version: NethServer 7.7.1908
Module: Cockpit
Hello,
I have a name which has some specific characters. These characters are not displayed in cockpit top right corner.
Complete name: Ertan Küçükoğlu
Cockpit visual:
Seemingly anything not in ASCII table is removed from display.
Is there anything I can do to fix this?
Thanks & regards,
Ertan
Hi @ertank,
may I ask you which is the nationality of your name?
IMVHO should be not user-workable this issue, but, maybe Dev Team may report to Cockpit Project.
Or the “default config” of Cockpit should be changed…
Hello, It is a Turkish name.
cc @dev_team
what account provider do you use, nethserver-dc (SAmba AD) or nethserver-directory (openldap)
As far I know, we have validators that block username not ascii
It is openldap server.
Problem is not username, top right corner, it is “Name” displayed.
I intentionally use ascii characters on username.
Name, I write as in its original, and see just as I typed in user list.
I also find it just fine when I “edit”
It is only removed from non-ascii characters on top right corner.
BTW, I failed to login using a regular user (just the above one I created for test purposes). I see below in /var/log/messages
May 12 09:53:11 neth cockpit-session: pam_ssh_add: Failed adding some keys
May 12 09:53:11 neth systemd: Created slice User Slice of ascii_username@greenkey.com.
May 12 09:53:11 neth systemd: Started Session 45 of user ascii_username@greenkey.com.
May 12 09:53:11 neth systemd-logind: New session 45 of user ascii_username@greenkey.com.
On browser, I only see below:
After sometime about 30 seconds I see on browser
Authentication failed: Timeout
and on /var/log/messages
May 12 09:53:41 neth cockpit-ws: cockpit-session: session timed out during authentication
May 12 09:53:41 neth cockpit-ws: cockpit-session: authentication timed out
May 12 09:53:41 neth systemd-logind: Removed session 45.
May 12 09:53:41 neth systemd: Removed slice User Slice of ascii_username@greenkey.com.
I can login just fine using root user.
Just for the record, I am behind a Squid Proxy server if that makes any difference.
for the timeout, check the user has a shell access (advanced menu of the user), you have a checkbox
Relative to UTF8 caracters, we have no validators for the gecos (Name), therefore you are not limited to use what you want but maybe cockpit does not use it well
in /usr/libexec/nethserver/api/system-users/validate:
$v->declareParameter('gecos', Validate::NOTEMPTY);
I can reproduce the bug, updating a user with ü in gecos (long name of the user : firstname lastname), it is not displayed in the upper right corner
@edoardo_spadoni can we do something or it is an upstream bug ?
The upper right corner is not controlled by us, it’s upstream. So yes it’s an upstream bug.
I don’t think it is an upstream issue.
The gecos field charset is filtered in the user-create event
Let’s call 911 :slight_smile: Task #911: UI: enforce Ldap charset limitations - NethServer 6 - NethServer.org
Interesting commit note (7 yrs ago):
Note: a validator must be implemented on UI modules.
