I have just fresh installed NS7 on my physical system. I have created AD and joined domain in windows 10 . I have created another user abc.
Issue is when i go to via ssh and look into directory /var/lib/nethserver/home there is nothing. No user nothing no profile nothing.
Is there any kind of bug ? or please help me to solve this issue.
i haven’t mounted any directory on RAID.
Raid created but not mounted. New user logged successfully but no profile has created.
don’t know whats issue.
Can you try accessing the server in the network neighborhood even if no share has been created, and after that check again if the home directory has been created?
Example: access \\yourserver.domain.tld
In NethServer 7 AD user ≠Unix/Linux User ≠Local user!
Except for root.
NethServer 7 via LDAP (local, remote) or other tools asks to the userbase (LDAP server or AD container aka NSDC) if there’s the user or not and if passwords match.
i have applied same on the server as custom template now. But no profile only few user folder has been created. But if create any file or folder on user’s desktop then where it will store on the server ?
because as i read its under /var/lib/nethserver/home
You would need to “Map” a Network Drive.
In Windows 10, for examlpe, open Windows Explorer and put in \IP_OF_YOUR_NETHSERVER.
Example:
\192.168.2.20
You will see folders there, if you created any “shares” (shared folders). Use a Right Mouse click, Map those folders as drives to any (free) letter you want.
The home folder is usually H:…
The User-Profile stuff is a bit more. I’ll search and post it in a few minutes.
Did you actually log in from a Windows PC as domain admin or domain administrator? If you haven’t logged in from Windows yet, the user folder remains empty.
If you get “SSSD generic Error.”, you might try with a Configuration Restore - this restores a configuration and, if needed, downloads programs/libraries/updates. This should get your AD back working - without any SSSD generic Error.
I’ve had the SSSD generic Error a few times (With my 25-30 clients) in the past 5 years, but always was able to use a Configuration Restore to fix it! But you do need a Configuration Backup to do this!
A configuration Backup is automatically done with any NethServer normal backup!
