I am facing 1 major issue with NS7. I have installed NS os on NVMe disk and attached 2 more HDD disks. I have configured software RAID 1 with Both HDD and mounted on /var/lib/nethserver/home directory on /dev/md0 device. df -Th - OUTPUT
/dev/mapper/VolGroup-lv_root xfs 224G 4.3G 220G 2% /
/dev/nvme0n1p2 xfs 1014M 195M 820M 20% /boot
/dev/nvme0n1p1 vfat 200M 12M 189M 6% /boot/efi
/dev/md0 xfs 1.4T 33M 1.4T 1% /var/lib/nethserver/home
Issue - When i am creating any user via GUI, its not creating user’s home directory and user profile. Even /home and /var/lib/nethserver/home is empty folder and all related system users and etc is missing.
So Kindly help me out where i am lacking to this config. Prompt Reply would be highly appreciated. Thanks a lot.
Name : mc.xxxxx.com:0 (local to host mc.xxxxxxx.com)
UUID : 58b38562:fb558473:2424f479:af4a8d11
Events : 2468
Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
1 8 17 1 active sync /dev/sdb1
Yes, i have created 2 files and successfully created. There has no permission issue. Even i have mounted in FSTAB. its permanently mounted.
There is no backup, newly system has created and few users created only
This looks REALLY strange!
Seems as something is badly screwed up on your setup…
Maybe a good idea, before further setup, to reinstall the whole box!
Your setup is very similiar to several I’ve done in the past, including later on adding in another disk for enlarging the storage.
A Symlink was enough for that.
